Collabora integration guide
Nextcloud integrates functionality to edit office documents online (even collaborative - meaning multiple users can work on the same document at the same time). This integration primarily happens with Collabora Online, but other integrations using the same protocol exist with OnlyOffice and Microsoft Online. As this forum primarily targets private users this article covers CODE (Collabora Online Development Edition) which is a free self-hosted Collabora Online variant for testing and home use. The integration builds on a protocol called WOPI which is widely used for similar integrations e.g. in Microsoft 365.
integration overview
Integration between Nextcloud and Collabora (or other WOPI clients) differs from classical web request/response models and results in confusion sometimes. The integration is not one-way where Nextcloud “pulls” integration from Collabora but it’s rather a “communication triangle” between clients, Nextcloud and Collabora, where each component accesses and provides resources from/to another. The requirements might become more clear by reading the process of file editing with the WOPI protocol (see below).
flowchart LR
clientint(client)
clientint ---> Nextcloud;
clientint ---> Collabora;
Nextcloud(Nextcloud)
Collabora(Collabora)
Nextcloud --> Collabora
Collabora --> Nextcloud
prerequisites
- Nextcloud (WOPI server)
- with “Nextcloud Office (richdocuments)” app
- public DNS name
- valid TLS certificate
- Collabora CODE (WOPI client)
- public DNS name
Technically integration might be possible without a public DNS and TLS certificates. But such integration without TLS makes no sense in most scenarios so we won’t discuss it here.
edit file using WOPI protocol
sequenceDiagram
participant client
participant NC as Nextcloud<br>https://cloud.mydomain
participant CODE as Collabora<br>https://office.mydomain
loop Healthcheck
NC->>CODE: GET https://office.mydomain.tld/hosting/discovery
Note right of CODE: "green checkmark in Nextcloud UI"
end
client->>NC: open document "the bill.odt"<br>(which is fileid=1234546)
NC->>client: "use CODE server to open document online<br>the url is https://office.mydomain/???open"
client->>CODE: GET "https://office.mydomain/?????open&https://cloud.mydomain.tld/richdocuments/fileid=123456"
CODE->>NC: GET "https://cloud.mydomain/richdocuments/fileid=123456"
CODE->>client: edit document bill.odt (fileid=123456)
protocol references
implementation and troubleshooting checklist
while the process described above sounds complicated in real life it’s fairly easy to setup and troubleshoot.
Often only need to complete the checklist and your integration likely will work.
- from the client, verify access to the Nextcloud UI
(use a browser or runcurl https://cloud.mydomain/status.php) - from the client, verify access to Collabora
(use browser or runcurl https://office.mydomain/hosting/discovery)- the result must be an XML document describing the capabilities of the WOPI client
(long list of different file types which could be opened) - review the content of the XML document reflect the right public hostname
- verify the content of the document reflect the right -
https://- URL scheme
- from Nextcloud server console, verify access to Collabora, run:
curl https://office.mydomain/hosting/discovery- it should return a long XML doc (same as in previous check) with valid https:// URLs
- from Collabora, verify access to the Nextcloud UI - from CODE console run
curl https://cloud.mydomain/status.php- it should return a JSON document similar to
{"installed":true,"maintenance":false,"needsDbUpgrade":false,"version":"33.0.2.2","versionstring":"33.0.2","edition":"","productname":"Nextcloud","extendedSupport":false}
from any client access Collabora WOPI check endpoint
curl https://office.mydomain/hosting/wopiAccessCheck -d {"callbackUrl":"https://cloud.mydomain/status.php"} --header "Content-Type: application/json"- if the result is
{"status": "Ok"}you are good
otherwise check CollaboraOnline Troubleshooting Guide #network connectivity for more help
install richdocuments app
occ app:enable richdocuments# adopt to your system e.g. add sudo, www user etc.. occ app:enable richdocuments # docker CLI docker exec --user www-data ${name of NC container} php occ app:enable richdocuments # docker compose docker compose exec ${service name} php occ app:enable richdocuments -
configure CODE server URL
# adopt to your system e.g. add sudo, www user etc.. occ config:app:set richdocuments wopi_url --value ${CODE_URL} occ richdocuments:activate-config # command for docker compose docker compose exec ${service name} php occ config:app:set richdocuments wopi_url --value ${CODE_URL} docker compose exec ${service name} php occ richdocuments:activate-config# GUI "Administration Settings" > Administration > Office # (https://cloud.mydomain/settings/admin/richdocuments) -
verify “Allow list for WOPI requests” entries
- this list should contain Collabora IP address where the request is coming from (often public IP)
- empty the list for testing then add IPs as needed
troubleshooting tips
if one of the above steps fail - often curl error message help - search the internet to understand the problem
if the error doesn’t help increase verbosity by adding -v to curl command
- double check your DNS (for all systems!) - especially in the case of docker or a VM.
DNS resolution of the server might differ from the client - verify the TLS certificates of cloud and office
- verify that both severs trust the assigned TLS certificate of the other system
- verify that the client trusts TLS certificates of both office and cloud
common issues
- don’t use
localhost- this reserved hostname is always different depending on the point of view:
- for client, this means “the service running on the client”
- for Nextcloud it means “the service running on Nextcloud server”
- for CODE it means “the service running on the CODE server”
- don’t use local virtual or Docker names and IPs e.g.
http://127.0.0.1,http://office:9980,http://192.168.0.7:80- this might allow communication from cloud to office and result in a
within Nextcloud Office settings… but communication from the client will fail
- don’t use plain http://
http://office:9980,http://cloud:80,http://cloud- technically it’s possible to run the whole stack without TLS but you should never expose your system on the internet without TLS.
related forum posts
- Collabora CODE for Nextcloud with Docker
- How to Install Nextcloud Office
- HowTo: Ubuntu + Docker + Nextcloud + Talk + Collabora
- Docker Compose for Nextcloud + Collabora + Traefik?
- Important changes regarding Collabora COOL/CODE 26.04
- Important changes regarding COOL/CODE docker versions from v21.11.3.6 on (multiple domains setup)
- Collabora/CODE not working with NC 24.0.3 in Docker
- Opening documents fail because of content security policy violation
- configure local shortcut avoiding all communications going through the internet (on Docker)
→ splitbraindns for Docker
Probably DNS help with NC Docker + Collabora + Wireguard tunnel - #5 by wwe - Collabora, websocket, nginx, self-hosted issues. Solved. // Fixed Collabora WebSocket issues behind nginx - complete troubleshooting guide
- Collabora Online + Nextcloud + Nginx Proxy – Success! A Quick Write-Up
- search for unauthorized WOPI host look at wopi_allowlist as well!
- issues with traefik 3.6 Traefik reverse proxy v3.6.4 causes issues with CollaboraOnline (Nextcloud office)
other references
- CollaboraOnline Troubleshooting Guide
- Reverse proxy — Nextcloud 34 Administration Manual
- Making sure you're not a bot!
- Collabora forum: Debugging help - Nextcloud- coolwsd servers
- Collabora forum: unauthorized WOPI host
- Nextcloud snap - configure CODE and Nextcloud office
- Arno Welzel blog / Nextcloud Office
AiO
AiO uses a “separated” CODE not a built-in version.
The biggest speciality is it is sharing the public fqdn for office and cloud so you will see same domain for https://cloud.mydomain/status.php and https://office.mydomain/hosting/discovery but other troubleshooting steps remain untouched.
some time ago an ugly hack was implemented to allow internal connection through Docker networks
→ see Local access for Collabora for details
Nextcloud Office aka Built-In CODE collabora-built-in
There is nothing wrong with this installation method but I feel it is harder to troubleshoot, especially for not very skilled admins who look for a “simple” solution. In general if you run Docker(-compose) setup I would recommend separate CODE container which is easier to understand and control.
All above mechanics apply to built-in CODE as well. The most important difference is CODE doesn’t have it’s own public DNS records and lives in a subdirectory of Nextcloud application. Office URLs to check are (replace in the above guide)
https://mydomain.tld/apps/richdocumentscode/proxy.php?req=/hosting/capabilitieshttps://mydomain-tld/apps/richdocumentscode/proxy.php?req=/hosting/discovery
another important learning - built-in CODE does not understand/adopt Nextcloud integrated reverse proxy OVERWRITE* settings. Running collabora-built-in behind a reverseproxy highly depends on reverse proxy X_FORWARDED* http headers - make sure your proxy adds them!
discussion on custom webroot (subdirectory): richdocuments ignores custom webroot · Issue #3420 · nextcloud/richdocuments · GitHub
Valuable Github discussion regarding built-in CODE: Collabora Online - Built-in CODE Server in Nextcloud docker. Documents do not load · Issue #1896 · nextcloud/docker · GitHub
Key learning’s
- Docker
-alpineimage variant don’t work - additional volume
-tmpfsmight be required - additional variable
APPIMAGE_EXTRACT_AND_RUN=1might be required
NGINX reverse proxy with built-in CODE
- Missing public hostname in /hosting/discovery, documents don't load
- Nextcloud can't open documents in Nextcloud Office - #12 by ardinusawan
