- most of office issues are handled in Collabora integration guide
- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
31.0.5
Truenas Scale ElectricEel-24.10.2.2
replace me
Nginx 2.12.3
- PHP version (e.g, 8.3):
replace me
No
After install of office
replace me
Yes
[Nextcloud is asking to Make sure to set this URL: https://nextcloud.xxxxxxxxxxxxxxxx.com/apps/richdocuments/settings/fonts.json in the coolwsd.xml file of your Collabora Online server to ensure the added fonts get loaded automatically. Please note that http:// will only work for debug builds of Collabora Online. In production you must use https:// for remote font config.
<remote_font_config>
</remote_font_config>
For ideal document compatibility we recommend you to install commonly used fonts. If your users are working with Microsoft Office, installing their proprietary fonts can be done following the documentation. Custom fonts documentation]
How would i do this in truenas scale as everything is different. Thank you
Log entries (none)
None
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
