Built-in Collabora CODE server is not working behind reverse proxy and prefix
    • 31.0.6.2
    • opensuse-tumbleweed 20250501
    • Apache 2.4.62
    • nginx:latest (asdfaasdfasdf, 5 month ago)
    • 4.2.27
    • Yes
    • since installation
    • docker pull nextcloud:latest
The build-in CODE server is auto-configured and shows “Collabora Online server is reachable.”. When opening an office document, the error “Document loading failed” is shown.
The CODE server works when the document is opened via a the internal server using http and no prefix.
  1. Open the document “Documents/Welcome to Nextcloud Hub.docx”
In the firefox web console, a POST request fails with a 400 error.
https://mydomain/custom_apps/richdocumentscode/proxy.php?req=/browser/636e10a2b1/cool.html?WOPISrc=https://mydomain/prerix/index.php/apps/richdocuments/wopi/files/7_oc4n3n6qtbyt&lang=en&closebutton=1&revisionhistory=1
The prefix is not honored in the request
See above.
172.16.0.2 - - [03/Jul/2025:20:35:13 +0000] "GET /nextcloud/custom_apps/richdocumentscode/proxy.php?status HTTP/1.1" 200 15 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:137.0) Gecko/20100101 Firefox/137.0" "-"
172.16.0.2 - - [03/Jul/2025:20:35:13 +0000] "POST /nextcloud/apps/richdocuments/token HTTP/1.1" 200 338 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:137.0) Gecko/20100101 Firefox/137.0" "-"
172.16.0.2 - - [03/Jul/2025:20:35:13 +0000] "PROPFIND /nextcloud/remote.php/dav/files/admin/Documents/Welcome%20to%20Nextcloud%20Hub.docx/ HTTP/1.1" 207 789 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:137.0) Gecko/20100101 Firefox/137.0" "-"
172.16.0.2 - - [03/Jul/2025:20:35:13 +0000] "POST /custom_apps/richdocumentscode/proxy.php?req=/browser/636e10a2b1/cool.html?WOPISrc=https%3A%2F%2Fmydomain%2FyC8u%2Fnxcl%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F7_oc4n3n6qtbyt&lang=en&closebutton=1&revisionhistory=1 HTTP/1.1" 400 154 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:137.0) Gecko/20100101 Firefox/137.0" "-"
172.16.0.2 - - [03/Jul/2025:20:35:14 +0000] "GET /nextcloud/index.php/apps/files/preview-service-worker.js HTTP/1.1" 200 5253 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:137.0) Gecko/20100101 Firefox/137.0" "-"
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "upgrade.disable-web": true,
            "mydomain",
            "localhost",
            "172.16.10.15"
        "overwritehost": "mydomain",
        "overwriteprotocol": "https",
        "overwrite.cli.url": "https:\/\/mydomain\/nextcloud",
        "overwritewebroot": "\/nextcloud",
        "overwritecondaddr": "^172\\.16\\.0\\.2$",
        "dbtype": "mysql",
        "version": "31.0.6.2",
        "dbport": "",
        "mysql.utf8mb4": true,
        "loglevel": 2,
        "app_install_overwrite": []
  - activity: 4.0.0
  - app_api: 5.0.2
  - bruteforcesettings: 4.0.0
  - calendar: 5.3.2
  - circles: 31.0.0
  - comments: 1.21.0
  - contacts: 7.1.3
  - contactsinteraction: 1.12.0
  - dashboard: 7.11.0
  - dav: 1.33.0
  - federation: 1.21.0
  - files: 2.3.1
  - files_downloadlimit: 4.0.0
  - files_pdfviewer: 4.0.0
  - files_reminders: 1.4.0
  - files_sharing: 1.23.1
  - files_trashbin: 1.21.0
  - files_versions: 1.24.0
  - firstrunwizard: 4.0.0
  - logreader: 4.0.0
  - mail: 5.1.3
  - notes: 4.12.1
  - notifications: 4.0.0
  - oauth2: 1.19.1
  - oidc: 1.7.2
  - password_policy: 3.0.0
  - photos: 4.0.0-dev.1
  - privacy: 3.0.0
  - profile: 1.0.0
  - provisioning_api: 1.21.0
  - recommendations: 4.0.0
  - related_resources: 2.0.0
  - richdocuments: 8.7.1
  - richdocumentscode: 25.4.202
  - serverinfo: 3.0.0
  - settings: 1.14.0
  - sharebymail: 1.21.0
  - spreed: 21.1.0
  - support: 3.0.0
  - survey_client: 3.0.0
  - systemtags: 1.21.1
  - text: 5.0.0
  - theming: 2.6.1
  - updatenotification: 1.21.0
  - user_status: 1.11.0
  - viewer: 4.0.0
  - weather_status: 1.11.0
  - workflowengine: 2.13.0
  - admin_audit: 1.21.0
  - encryption: 2.19.0
  - files_external: 1.23.0
  - nextcloud_announcements: 3.0.0 (installed 3.0.0)
  - suspicious_login: 9.0.1
  - user_ldap: 1.22.0
  - webhook_listeners: 1.2.0 (installed 1.2.0)
The location section of the nginx default.conf
location /nextcloud/ {
    rewrite ^/nextcloud/(.*)$ /$1 break;
    proxy_pass http://172.16.10.15:8086/;
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-Host $host; # Recommended for Nextcloud behind proxy
    # CalDav and friends
    proxy_buffering off;
    proxy_request_buffering off; # Needed for WebDAV PUT
    proxy_redirect off; # Prevent Nginx from rewriting redirects from Nextcloud
    proxy_http_version 1.1;
    proxy_connect_timeout 600s;
    proxy_read_timeout 720s;
	proxy_send_timeout 720s;
I don’t recall exactly but there are few things to check
  • richdocuments and built-in CODE don’t take into account Nextcloud OVERWRITE* config settings - they fully rely on reverse proxy headers (x-forwarded..etc)
  • I remember there was an issue with subfolder at all maybe this doesn’t work in general.
we had some related topics here use search :slight_smile:
The issue is caused by the CODE server not properly handling the reverse proxy prefix (/nextcloud). The built-in CODE expects to run at the root path, so requests to /nextcloud/custom_apps/... fail with a 400 error because the prefix isn’t respected. To fix this, ensure the overwritewebroot setting is correctly set in config.php (which you have), but also configure the CODE server or reverse proxy to correctly rewrite URLs, or use a dedicated subdomain without a prefix for CODE. The built-in CODE has limited support for reverse proxy prefixes, so separate domain setups are recommended.
:check_mark:
you’re not using the snap, but How to manage Hosts and FQDN for Nextcloud snap may give you some pointers
