FQDN (Fully Qualified Domain Name)
A fully qualified domain name (a.k.a absolute domain name) is a complete address that specifies its exact location in the internet’s domain name system DNS and resolves a “human readable domain name” to an IP address. It includes the hostname and the domain name, which uniquely identify a specific server on the internet. This specifies all domain levels, including the top-level domain (TLD), in hostname.domain.tld format.
FQDN for Nextcloud snap on internet facing instance
Setting FQDN (Fully Qualified Domain Name) is best practice and is optional on self-hosted internet facing Nextcloud snap instance and may improve site response.
- Discover hostname:
- issue command
hostnamectl
or
hostname
- Set or change hostname:
- issue command
hostnamectl set-hostname NEW-HOSTNAME
- Set FQDN on internet facing device:
- edit
/etc/hostson internet facing host using your favourite editor as root$ sudo nano /etc/hostsand add second line replacing<your.domain.xyz>and<hostname>with your own domain name and hostname:
- edit
127.0.0.1 localhost
127.0.1.1 <your.domain.xyz> <hostname>
## The following lines are desirable for IPv6 capable hosts
::1 ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
FQDN for Nextcloud snap instance on internet facing vm or container
Setting FQDN (Fully Qualified Domain Name) is best practice and may be required on some hosted vm’s or containers, but optional on self-hosted vm’s or containers running Nextcloud snap instance and may improve site response.
- issue command
hostnamectl
or
hostname
- issue command
- Set FQDN on internet facing vm or container:
- edit
/etc/hostsin vm or container using your favourite editor as root$ sudo nano /etc/hostsand add second line replacing<your.domain.xyz>and<hostname>with your own domain name and hostname:
- edit
127.0.0.1 localhost
FQDN for Nextcloud snap instance, vm or container behind reverse proxy with termination
Setting FQDN (Fully Qualified Domain Name) is best practice and is optional on self-hosted Nextcloud snap instances running on vm or container behind reverse proxy with termination and may improve site response.
- issue command
hostnamectl
or
hostname
- issue command
- Set FQDN on instance behind reverse proxy with termination:
- edit
replacing<your.reverse.proxy.ip> <your.domain.xyz>and<hostname>with your own domain name and hostname:
- edit
127.0.0.1 localhost
<your.reverse.proxy.ip> <your.domain.xyz> <hostname>
FQDN for Nextcloud snap instance, vm or container behind pass through reverse proxy without termination
Setting FQDN (Fully Qualified Domain Name) is best practice and is optional on self-hosted Nextcloud snap instances running on vm or container behind pass through reverse proxy without termination and may improve site response.
- issue command
hostnamectl
or
hostname
- issue command
- Set FQDN on instance behind pass through reverse proxy without termination:
- edit
- edit
127.0.0.1 localhost
Trusted proxies in Nextcloud snap
- Set trusted proxies in config-php if your Nextcloud snap instance is behind a reverse proxy.
'trusted_proxies' =>
0 => 'your.reverse.proxy.ip',
1 => 'your.other.proxy.ip',
or issue command on host (iterating values 0, 1, 2…):
sudo nextcloud.occ config:system:set trusted_proxies 0 --value="your.reverse.proxy.ip"
CAUTION
Be aware that these values must be IPv4 or IPv6 addresses or IPv4 or IPv6 ranges in CIDR notation see reverse proxy documentation
TIP
Local DNS
Make your Nextcloud snap instance known to your local DNS or Pihole by adding the instance IP and hostname to
/etc/hostson local DNS. This may improve site response as well as local up/download in your local network.
NOTE
Be aware of differences between reverse proxy configurations where;
- the reverse proxy manages encryption and handles termination (see instance behind reverse proxy) and (letting reverse proxy handle encryption)
- the reverse proxy passes through encryption without termination (see internet facing vm or container) and (putting Nextcloud snap behind a reverse proxy)
Also be aware of port configuration;
