Calling all Nextcloud enthusiasts! ![]()
We need your help testing Nextcloud 29 RC2!
Dive in, explore features, uncover bugs, and share your insights.
Download now: https://download.nextcloud.com/server/prereleases/nextcloud-29.0.0rc2.zip
Happy testing! ![]()
Previous betas and RCs
- First beta of Nextcloud 29
- Second beta of Nextcloud 29
- Third beta of Nextcloud 29
- Fourth beta of Nextcloud 29
- Fifth beta of Nextcloud 29
- Sixth beta of Nextcloud 29
- First RC of Nextcloud 29
Changelog (from RC1)
- Fix(files): Fix translation of “Delete file” (server#44553)
- Feat(trashbin): Show original location of deleted file (server#44584)
- Fix(files_sharing): Create passwords when enforced for mail shares (server#44591)
- Fix(files_sharing): Disable autocomplete for share label and password (server#44617)
- Build(deps): bump nextcloud/coding-standard from 1.1.1 to 1.2.1 in /vendor-bin/cs-fixer (server#44622)
- Fix(dav): Fix quota check for chunk upload (server#44624)
- Fix(federation): ICloudId->getRemote() should contain the protocol (server#44626)
- Fix(SetupChecks): Add hint about dns/firewall if
mjscheck can’t run (server#44628) - Fix(encryption): Clicking default module in UI sets bogus value (server#44634)
- Fix(files): breadcrumbs drag-and-drop & unifying methods (server#44653)
- Chore(CI): Adjust testing matrix for Nextcloud 29 on stable29 (circles#1534)
- Fix npm audit (files_pdfviewer#943)
- Chore(deps): Bump @nextcloud/vue from 8.11.0 to 8.11.1 (firstrunwizard#1148)
- Chore(CI): Adjust testing matrix for Nextcloud 29 on stable29 (recommendations#722)
- Chore(CI): Adjust testing matrix for Nextcloud 29 on stable29 (related_resources#382)
- Chore(CI): Adjust testing matrix for Nextcloud 29 on stable29 (text#5577)
- Feat/5524 link preview add button to delete links in preview mode (text#5580)
- Always initialize with the same yjs document if no state is present (text#5593)
- Fix: workspace tables expand correctly (text#5595)
- Fix: Make edit mode in interactive widgets opt-in (text#5596)
- Fix(css): Adjust heading sizes (Fixes: #5515) (text#5598)
- Test(cypress): Wait for syncs after opening+editing in in
sync.spec.js(text#5602) - Chore(deps): update dependency cypress-split to ^1.21.2 (text#5612)
- Chore(deps): update dependency vite to ^5.2.8 (text#5613)
- Fix(deps): update tiptap to ^2.2.4 (text#5614)
- Fix(LinkBubble): Treat links to hashes in same page directly (text#5615)
- Chore(CI): Adjust testing matrix for Nextcloud 29 on stable29 (twofactor_totp#1507)
