Nextcloud Box OS images
Here are the images we can share with the public and that you can flash on a Nextcloud Box.
Pi2
Image-20161018
MD5
SHA256
Pi3
Images have been delayed until January
Flashing guide
Should we add them to https://nextcloud.com/install/#instructions-server and/or https://nextcloud.com/box/ :thinking: @jospoortvliet
If it helps, this is what I’ve provided with my backup image:
Details on how to restore the dd *.bin file:
NOTE
This image backup will format the attached PiDrive to a fresh install of Nextcloud. To maintain the version previously installed prior to the sdcard failing, follow the instructions on the below link, changing the target drive back to /dev/sda2
Username and password are the default:
u: ubuntu
p: ubuntu
Change this as soon as is convenient:
$ sudo adduser yournewusername
$ sudo adduser yournewusername sudo
(the second line gives the user account sudo privileges)
Log out and in with the new user
$ sudo passwd -l ubuntu
This will disable the default ubuntu user and all further logins would need to be done with the newly created user.
yeah would be good to provide links and info on the wiki, nextcloud.com/box isn’t very technical so I don’t think it fits there.
Can i also suggest instructions on using Etcher.io app to write the img image to SD card as well… a bit more user friendly esp for novices/less linuxy folks
-J
If you’re familiar with it, feel free to put something together and it may end up there :slight_smile:
It definitely will be added to the FAQ. I just haven’t found the time to write a decent guide.
I’ve posted a guide for Windows:
Feel free to add instructions for Linux and OSX.
For OSX you can use the app “Pi Filler 1.3” [for OS X 10.5 Leopard through 10.10 Yosemite]
download it at this website.
http://ivanx.com/raspberrypi/
Works very easy.
Open the app, select the image file.
Insert SD and wait till it says its ready.
