The third release candidate of Nextcloud 33 is now available on download servers! ![]()
If you notice anything out of order, please report back on the appropriate GitHub repository! ![]()
We will follow up other RCs on next Thursdays, stay tuned! ![]()
Downloads
Changelog
server
- Fix: don’t rely on share providers being avaiable in CleanupShareTarget (server#57927)
- Fix(files_external): Respect explicit port configuration (server#57997)
- Fix(files): keep current folder on drag-n-drop (server#57998)
- Feat: Add twofactor applications to most of the presets (server#57999)
- GetById: don’t setup for all users with access by default (server#58000)
- Fix(app-settings): limit app to group initial state (server#58005)
- Fix(federation): Don’t ask the database for an empty url (server#58014)
- Test(dispatcher): Add some tests with input 0 (server#58017)
- Fix(external-storage): Rtrim trailing slash at the end (server#58024)
- Fix: Migrate `getById` to `getFirstNodeById` (server#58028)
- Feat: Add office switcher with feature comparison (server#58030)
- Fix(comments): Put a limit to the limit (server#58044)
- Test(Updater): Harden flaky test (server#58054)
- Fix(snowflakes): create file lock files into lock directory (server#58055)
- Fix(files_sharing): stop ignoring shares without a usergroup entry when filtering by path (server#58061)
- Chore(openmetrics): export only “real” files count (server#58090)
- Feat(sharing): Make share permission in bundled edit configurable (server#58091)
- Feat(dav): allow extending propfind properties via event (server#58093)
- Feat(files): warn when file would be hidden (server#58097)
- Chore: Improve SVG handling in link previews (server#58101)
activity
- Chore(CI): Adjust testing matrix for Nextcloud 33 (activity#2322)
- Test: fix cypress file frontend test (activity#2341)
- Fix: rework attributes (activity#2358)
app_api
- Feat(HaRP): automatically register HaRP when it is installed (app_api#768)
- Ci(actions): Update actions and satisfy zizmor (app_api#771)
- Chore(deps): update NPM packages (app_api#774)
- Fix(HaRP): use correct path for FRP address validation (app_api#781)
circles
- Admin settings endpoint (circles#2327)
- Feat(admin): add admin settings section for configuring federated teams (circles#2331)
- Add trusted servers as external (circles#2335)
files_pdfviewer
firstrunwizard
- Refactor: adjust code to comply with recent deprecations (firstrunwizard#1903)
- Fix: resolve Typescript issues (firstrunwizard#1909)
- Fix: start with HUB release animation when only updating (firstrunwizard#1912)
- Feat: add changelog for Nextcloud 33 (firstrunwizard#1914)
- Fix: do not show scrollbars on animation (firstrunwizard#1918)
- Fix: properly handle closing the modal (firstrunwizard#1920)
logreader
notifications
photos
related_resources
suspicious_login
text
- Chore(test): remove assertion broken by viewer regression (text#8222)
- Chore(test): only consider src for codecov patch status (text#8226)
- Chore: Improve session validation (text#8235)
