The fifth beta of Nextcloud 33 is now available on download servers! ![]()
If you notice anything out of order, please report back on the appropriate GitHub repository! ![]()
We will follow up with RC1 on Thursday, stay tuned! ![]()
Downloads
Changelog
server
- Fix: support longer index and table names (server#51593)
- Fix: update unified search folder picker text (server#54234)
- Docs(settings): Removing the developerDocsUrl (server#56794)
- Chore: Update minimum supported desktop version to 3.1.50 (server#57082)
- Chore: Change preview image in README.md (server#57164)
- Enhancement(files): remove redundant success toast on file rename (server#57168)
- Feat(files_sharing): implement partial mount providers (server#57292)
- Fix(FilesAppSettings): Add icons to default view (server#57296)
- Build(deps): bump the github-actions group across 1 directory with 11 updates (server#57303)
- Fix(files): properly handle currently active node and files action hotkeys (server#57352)
- Fix(files): properly handle viewer integration of sidebar (server#57393)
- Fix(psalm): Fix static analysis issues in apps/*/tests (server#57404)
- Feat(profile): show Teams memberships on account details (server#57439)
- Build(deps-dev): bump the vite group across 2 directories with 1 update (server#57466)
- Build(deps-dev): bump eslint-plugin-cypress from 5.2.0 to 5.2.1 (server#57467)
- Build(deps-dev): bump sass from 1.97.1 to 1.97.2 (server#57469)
- Build(deps-dev): bump msw from 2.12.6 to 2.12.7 in /build/frontend-legacy (server#57472)
- Build(deps-dev): bump sass from 1.97.1 to 1.97.2 in /build/frontend-legacy (server#57473)
- Perf(UserMountCache): Optimize loop (server#57525)
- Perf(View): Optimize getDirectoryContent hot-loop (server#57549)
- Refactor(core): migrate web updater to Vue (server#57556)
- Ci(phpunit): thin out testing matrix (server#57561)
- Feat(files_sharing): Support multiples users in UserShareAccessUpdatedEvent (server#57564)
- Ci(lint): Lint multiple files at once when possible (server#57566)
- Refactor(core): migrate public share authentication to Vue (server#57571)
- Fix(files_sharing): Fix BeforeZipCreatedListener path handling (server#57573)
- Fix: dont error on missing path_hash/checksum CacheEntry fields (server#57576)
- Refactor(core): migrate OCP.AppConfig from jQuery to axios (server#57584)
- Chore(i18n): Improved grammar (server#57585)
- Chore: update `@nextcloud/files` to v4.0.0-rc.0 (server#57586)
- Refactor: migrate `OC.*QueryString` from jQuery (server#57587)
- Refactor(QueryException): Remove most usage of QueryException (server#57591)
- Refactor(core): migrate `OC.msg` away from jQuery (server#57592)
- Refactor(core): migrate `OCP.Comments` away from jQuery (server#57594)
- Build(deps-dev): bump rector/rector from 2.3.0 to 2.3.1 in /vendor-bin/rector (server#57600)
- Build(deps-dev): bump the vitest group across 2 directories with 3 updates (server#57601)
- Build(deps-dev): bump cypress from 15.8.1 to 15.9.0 (server#57602)
- Build(deps-dev): bump @types/dockerode from 3.3.47 to 4.0.0 (server#57605)
- Build(deps-dev): bump @zip.js/zip.js from 2.8.14 to 2.8.15 (server#57606)
- Build(deps-dev): bump @babel/plugin-transform-private-methods from 7.27.1 to 7.28.6 in /build/frontend-legacy (server#57607)
- Build(deps): bump @nextcloud/vue from 8.35.0 to 8.35.2 in /build/frontend-legacy (server#57608)
- Chore(version): Hub 25 Autumn → Hub 26 Winter (server#57629)
- Build(deps-dev): bump @nextcloud/stylelint-config from 3.1.1 to 3.2.0 (server#57634)
- Build(deps): bump p-queue from 9.0.1 to 9.1.0 in /build/frontend-legacy (server#57635)
- Build(deps-dev): bump @babel/node from 7.28.0 to 7.28.6 in /build/frontend-legacy (server#57636)
- Build(deps): bump @nextcloud/dialogs from 7.1.0 to 7.2.0 in /build/frontend-legacy (server#57637)
- Build(deps): bump libphonenumber-js from 1.12.31 to 1.12.34 in /build/frontend-legacy (server#57638)
- Build(deps): bump the github-actions group with 3 updates (server#57639)
- Fix(TaskProcessing): Fix occ commands to cast strings to integer (server#57641)
- Chore: drop duplicated legacy Ajax error handling (server#57642)
- Refactor(core): migrate `OC.EventSource` from jQuery to native API (server#57644)
- Fix(theming): Fix favicon and touchicon ratios (server#57653)
- Fix(apps): Enable TwoFactor TOTP by default (server#57658)
3rdparty
activity
- Chore(deps-dev): Bump @vitest/coverage-v8 from 4.0.16 to 4.0.17 (activity#2312)
- Chore(deps-dev): Bump happy-dom from 20.0.11 to 20.3.1 (activity#2314)
- Ci(deps): Bump actions/setup-node from 6.1.0 to 6.2.0 in /.github/workflows (activity#2316)
- [master] Update nextcloud/ocp dependency (activity#2318)
app_api
- Fix(manual-install): prevent duplicate port in ExApp URLs (app_api#750)
- Fix(setup-check): change missing daemon from error to info (app_api#751)
- Chore(readme-description): update app description and README.md (app_api#753)
bruteforcesettings
circles
- Fix(population): exclude nested circles from population counts (circles#2300)
- [master] Update nextcloud/ocp dependency (circles#2301)
- Perf: use getExistingUser for getUsersForShare (circles#2307)
logreader
- Chore(deps-dev): bump @vitest/coverage-istanbul from 4.0.16 to 4.0.17 (logreader#1876)
- Chore(deps-dev): bump happy-dom from 20.1.0 to 20.3.1 (logreader#1877)
- [master] Update nextcloud/ocp dependency (logreader#1878)
nextcloud_announcements
- [master] Update nextcloud/ocp dependency (nextcloud_announcements#562)
- Fix(crawler): Skip notifications code completely in first run (nextcloud_announcements#563)
notifications
- [master] Update nextcloud/ocp dependency (notifications#2729)
- Build(deps): Bump ua-parser-js from 2.0.7 to 2.0.8 (notifications#2731)
- Build(deps-dev): Bump rector/rector from 2.3.0 to 2.3.1 in /vendor-bin/rector (notifications#2732)
- Fix: Make app version stable (notifications#2734)
photos
related_resources
serverinfo
- [master] Update nextcloud/ocp dependency (serverinfo#931)
- Chore(ci): update workflows (serverinfo#932)
suspicious_login
text
- [main] Update nextcloud/ocp dependency (text#8157)
- Chore(deps): update vitest monorepo to ^4.0.17 (main) (text#8163)
- Chore(deps): update dependency cypress to ^15.9.0 (main) (text#8164)
- [main] Update nextcloud/ocp dependency (text#8167)
- [main] Fix npm audit (text#8168)
- Chore(test): use retrying assertion (text#8170)
- Feat(tables): enable text alignment rendering in HTML output (text#8171)
twofactor_nextcloud_notification
- [main] Update nextcloud/ocp dependency (twofactor_nextcloud_notification#1166)
- Fix: Make app version stable (twofactor_nextcloud_notification#1168)
