How to use OCC management console for Nextcloud snap
OCC (Own Cloud Console) is a commandline management interface requiring root privileges and is accessed from the Nextcloud snap host shell
grafik
Nextcloud management console usage
sudo nextcloud.occ
TIP
Some systems don’t add /snap/bin to the $PATH. Try
sudo /snap/bin/nextcloud.occ
Nextcloud management console help
sudo nextcloud.occ --help
View status
sudo nextcloud.occ status
List console functions
sudo nextcloud.occ list
View system configuration
sudo nextcloud.occ config:list system
View apps in Nextcloud
sudo nextcloud.occ app:list
Enable apps
sudo nextcloud.occ app:enable <appname>
Enable contacts birthday calendar
sudo nextcloud.occ dav:sync-birthday-calendar
Disable apps
sudo nextcloud.occ app:disable <appname>
Update apps
sudo nextcloud.occ app:update <appname>
Update all apps
sudo nextcloud.occ app:update --all
Update/enable unstable apps (development)
sudo nextcloud.occ app:update --allow-unstable <appname>
List installed apps
Further app functions:
      app:disable
      app:enable
      app:getpath
      app:install
      app:list
      app:remove
      app:update
      config:app:delete
      config:app:get
      config:app:set
      files:scan-app-data
      files_external:applicable
      integrity:check-app
      integrity:sign-app
      user:add-app-password
View all app and system configurations
sudo nextcloud.occ config:list all
Further config functions:
      config:app:delete
      config:app:get
      config:app:set
      config:import
      config:list
      config:system:delete
      config:system:get
      config:system:set
Reset user password
sudo nextcloud.occ user:resetpassword USERNAME
  • Enter a new password:
  • Confirm the new password:
Successfully reset password for USERNAME
Reset admin password
sudo nextcloud.occ user:resetpassword admin
Successfully reset password for admin
Add user
sudo nextcloud.occ user:add USERNAME
Repair Nextcloud
sudo nextcloud.occ maintenance:repair
Configuration options
Nextcloud snap wiki & support
How to edit config.php for Nextcloud snap
Je ne trouve pas le dossier nextcloud pour utiliser la commande occ
No access to the Nextcloud snap - who can help
How-to/FAQ WIKI
Internal server error: "no app in context"
always use HTTPS on production servers - where is the Apache VirtualHosts configuration file
How to manage failed automatic update in Nextcloud snap
Unable to log in and not able to understand the log in nextcloud/data/
How to install Nextcloud snap
Calendar app on Android does not sync with NextCloud anymore
How to configure Nextcloud snap
Problems installing recognize dependencies
How do I use occ commands?
INVALID_HASH of Collabora_Online.AppImage
Nextcloud snap, welcome - automatic update failed
Nextcloud SNAP install suddenly satuats WAN on connection to github
MySql crashes on startup - Snap installation
Issue with CLAMAV
Android Nextcloud app upload errors
Error in Desktop Notifications for Nextcloud Progressive Web App instance
Nextcloud Snap server stops working after installing custom SSL certificate from GoDaddy
Let nextcloud listen on one IP address only
Cookbook and reverse proxy
Let's Encrypt Zertifikat abgelaufen
Limiting RAM Use
Nextcloud (Snap) 0770 Permission Denied on rclone Google Drive Mount (chown has no effect)
Unable to see added storage of 2TB hdd within System disk free space.
Photos tab groups a JST JPEG under the next month despite EXIF OffsetTimeOriginal=+09:00 — known issue?
Cannot login with correct password and no error message
Snap updated to 32.0.9snap1 and encountering internal server error, reverting does not fix.
How to change SNAP_DATA
Snap: Can't update, add, or remove apps
temporary 2fa code generated by 2fa admin tools not accepted when client uses it
Nextcloud Snap with Collabora Online - Android problems
No Log file rotation even when set, logs excessive size crashed server
Nextcloud Snap Ai message in overwiev
On Core24 with NC31 and after a snap restore: Missing nextcloud.log
Untrusted Domain message on my Cell phone running tailscale
Intégration suite office Nextcloud Snap
Nextcloud web UI not responding
Delete spreed signaling server account on Nextcloud Snap
Using Acme/LetsEncrypt for TLS Certificate for NextCloud and for VPN on Firewall
Nextcloud snap, welcome - missing support template
How to manage security brute force protection and throttling in Nextcloud snap
Self-Hosted Nextcloud, Data Directory to SSD Error
