Frequent Nextcloud 32 "Hub 25 Autumn" update issues
Hi community, the next release of Nextcloud 32 (Hub 25 Autumn) is is released!
it’s time to bundle frequent issues into a WIKI post (where everybody is welcome to add content) to help users to find solutions for frequent issues after update to NC32. This helps to avoid flooding forum with similar topics and helps everybody to identify and solve known issues.
..sometimes issues repeat/reoccur - please look at
as well, especially if you jump over the previous release.
Github references
Important changes
see Upgrade to Nextcloud 32 — Nextcloud latest Administration Manual latest documentation for details
supported PHP versions
  • PHP 8.1 end-of-life by PHP project, deprecated but still supported by Nextcloud. php81
    • PHP 8.1 stops receiving security updates on 2025-12-31T00:00:00Z php81
  • PHP 8.2 will receive security patches until 2026-12-31T00:00:00Z php82
  • PHP 8.4 is now supported, but 8.3 is recommended. php84
Web server configuration
Setup checks do not check for the X-XSS-Protection response header anymore. It has been removed from Nextcloud’s .htaccess and you may want to adjust your webserver config to not serve it anymore. XSS filtering was supported only until Chromium 78 and similarly old browsers, but had been found to cause more issues, including attack vectors, than it solved. Nowadays, aside of not serving the header at all, the only generally recommended value is 0. More context can be found in the OWASP Cheat Sheet Series.
list of incompatible apps
maps app results in many issues
groupfolders aka “team folders” app
Solution: update to v20.1.1
Logs filled with A non-numeric value encountered at /var/www/html/apps/dav/lib/Files/FileSearchBackend.php#485
Issues
