Nextcloud version (eg, 20.0.5): 23
Operating system and version (eg, Ubuntu 20.04): unraid
Apache or nginx version (eg, Apache 2.4.25): nginx reverse proxy v2.9.12
PHP version (eg, 7.4): replace me
Can acces from outside but not from LAN
Is this the first time you’ve seen this error? Y
- Install mariadb docker
- Install nextcloud docker
- Config nextcloud to point mariadb and create admin user
- All works (only inside lan)
- Modify config.php so can use nginx reverse proxy
- From WAN works OK, from lan stops working. Inside lan redirects to mynextcloud.duckdns.org but nothing or error on browser.
PASTE HERE
GNU nano 5.3 config.php
'datadirectory' => '/data',
'instanceid' => 'XXXXXXXXXX',
'passwordsalt' => 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX',
'secret' => 'XXXXXXXXXXXXXXXXXXXXXXX',
0 => '192.168.1.20',
1 => 'mynextcloud.duckdns.org',
'trusted_proxies' =>
0 => '192.168.2.2',
'version' => '23.0.0.10',
'overwrite.cli.url' => 'https://mynextcloud.duckdns.org',
'overwritehost' => 'mynextcloud.duckdns.org',
'dbname' => 'nextcloud',
'dbhost' => '192.168.2.10:3306',
'dbuser' => 'nextcloud',
'dbpassword' => 'XXXXXXXXXXXX',
Don't find it on my unraid server
