I have problems connecting iOS devices with my nextcloud calendars using caldav. I have already tried several things from passed topics, but nothing seems to work:
So setting a 301 redirect, using simple passwords, with and without ssl, all the connection tries crashed with an error. The log of a failed connection try looks like this:
{âreqIdâ:âeLGLrXbKAk9fPuwCyQ3lâ,âlevelâ:0,âtimeâ:â2018-10-30T21:48:15+00:00â,âremoteAddrâ:â92.107.148.11â,âuserâ:âââ,âappâ:âwebdavâ,âmethodâ:âPROPFINDâ,âurlâ:â/remote.php/dav/principals/users/Wolfstufe/â,âmessageâ:âException: {"Exception":"Sabre\\DAV\\Exception\\NotAuthenticated","Message":"No public access to this resource., No âAuthorization: Basicâ header found. Either the client didnât send one, or the server is misconfigured, No âAuthorization: Bearerâ header found. Either the client didnât send one, or the server is mis-configured, No âAuthorization: Basicâ header found. Either the client didnât send one, or the server is misconfigured","Code":0,"Trace":"#0 [internal function]: Sabre\\DAV\\Auth\\Plugin->beforeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#1 \/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#2 \/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(466): Sabre\\Event\\EventEmitter->emit(âbeforeMethodâ, Array)\n#3 \/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#4 \/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/apps\/dav\/lib\/Server.php(293): Sabre\\DAV\\Server->exec()\n#5 \/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/apps\/dav\/appinfo\/v2\/remote.php(35): OCA\\DAV\\Server->exec()\n#6 \/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/remote.php(164): require_once(â\/home\/pfadimo1\/âŚâ)\n#7 {main}","File":"\/home\/pfadimo1\/public_html\/nextcloud\/nextcloud\/3rdparty\/sabre\/dav\/lib\/DAV\/Auth\/Plugin.php","Line":168}â,âuserAgentâ:âiOS/12.1 (16B92) dataaccessd/1.0â,âversionâ:â13.0.6.1â}
Nextcloud: v13.0.6
PHP: v7.1.19
Is there anything I can do to fix this problem?
