- most of office issues are handled in Collabora integration guide
- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Hello there,
I’m running NextCloud AIO on my Synology NAS. I’ve also enabled the Collabora CODE container for NextCloud Office. I have a problem whereby my service provider regularly changes my IP address, and as soon as that happens, all WOPI access requests are denied.
I know I could set that setting to null (or 0.0.0.0/0) but I’d rather have something more secure than that. I have tried to set it to the URL of my NextCloud instance (e.g. cloud.mydomain.com) but it does not appear that such URL is translated into an IP address to check if a connection is allowed. I’ve tried to change the wopi_allowlist both from the WebUI and using the occ command but it (quite as expected) does not make a difference.
As soon as I update the IP address in that field to my new IP address, things work again… until the next change.
Is it possible to specify the list of connections allowed using FQDN instead of an IP (or IP range)?
If not, what are my options (besides opening up to the entire world by leaving it blank)?
One thought I had was to change the X-Real-IP setting of my reverse proxy so that such WOPI requests would always have the proxy’s IP address as the source… I have not tried that and I’m wondering if I should expect other problematic side-effect if I do it?
Thanks!|
Geoffroy
