The second beta of Nextcloud 31 is now available on our download server!
If you notice anything out of order, please report back on the appropriate github repository!
We will follow up with frequent betas over the next weeks.
Downloads
Previous announcements
Changelog
- Fix(Http): Only allow valid HTTP status code values via template (server#49882)
- Feat(ocp): calendar event builder api (server#49888)
- Fix(preview): Do not try to parse M3U files as MP3 (server#50051)
- Docs(HTTP): Add proper docs for CORS attribute (server#50070)
- Chore(deps): bump @nextcloud/vue from ^8.20.0 to ^8.22.0 (server#50074)
- Fix(files): updateAll method (server#50078)
- Fix: Correct typo in accessibility toggle in config.sample.php (server#50082)
- Add licenses by SPDX identifier, mark shorthand aliases as deprecated (server#50085)
- Fix broken taskprocessing api /tasktypes endpoint (server#50094)
- [master] Fix npm audit (bruteforcesettings#696)
- Revert βremove caching for sharesβ (circles#1830)
- [master] Update nextcloud/ocp dependency (notifications#2140)
- Chore: Update Administrator access wording (privacy#1142)
- Switch index to ocs (recommendations#829)
- Chore(ci): Add phpunit workflows (recommendations#834)
- Fix(deps): Bump symfony/process (suspicious_login#956)
- Chore(deps-dev): Bump cross-spawn from 7.0.3 to 7.0.6 (viewer#2617)
- Chore(deps): update dockerode (master) (viewer#2628)
- Chore(deps): update dependency cypress to ^13.17.0 (master) (viewer#2667)
- Fix(deps): update dependency @nextcloud/vue to ^8.22.0 (master) (viewer#2668)
- Chore(deps): lock file maintenance (master) (viewer#2669)
- Tests: Allow running cypress on different instance (viewer#2678)
