The fourth beta of Nextcloud 31 is now available on our download server!
If you notice anything out of order, please report back on the appropriate github repository!
We will follow up with frequent betas over the next weeks.
Downloads
Previous announcements
Changelog
- feat: Make it possible to customize share link tokens #49317
- perf: use more optimized way to get user storage info in ocs user info #49476
- feature: added new FavouriteWidget to display favorite files in dashboard widget #49534
- fix: skip transfering shares that we canβt find #49761
- feat(lexicon): configurable default value #49848
- feat: file conversion provider #49922
- fix(settings): Fix mail server settings form #50046
- fix: Remove duplicate propfind call #50109
- feat: Allow rich formatting of profile text #50130
- fix(files): sort not working after changing views #50161
- Limit ldap user count #50171
- fix: Show full template name #50172
- fix(files): hide move dialog action if destination has no CREATE permission #50177
- test(dashboard): Add regression test for loading unneeded data #50179
- fix(command-compile): cache restore action #50188
- fix(files_sharing): Stop overwriting the share expiration date with the default expiration date #50192
- fix(missing-index): update preferences table #50195
- docs: Use proper return type for custom template listing #50196
- fix(systemtags): objecttype index registration #50200
- Fix path to image resources files_pdfviewer#1106
- fix(composer): fix running composer with
--no-dev
option files_pdfviewer#1112 - feat(CI): add update-workflows.yml workflow firstrunwizard#1482
- Revert βfeat(CI): add update-workflows.yml workflowβ firstrunwizard#1484
- ci: Update GitHub workflows notifications#2154
- Chore(deps-dev): Bump @nextcloud/vite-config from 1.4.2 to 1.5.0 password_policy#715
