The fifth (and latest) beta of Nextcloud 31 is now available on our download server!
If you notice anything out of order, please report back on the appropriate GitHub repository!
We will follow up with first RC on Thursday.
Downloads
Previous announcements
Changelog
- Fix: add eol in dav command and use success const as return code (server#48800)
- Fix(files): File type filter UI sync with filter state (server#49259)
- Chore: Resolve ESLint warnings (server#49348)
- Feat: Two Factor API (server#49443)
- Chore(i18n): Improved grammar (server#49717)
- Fix(settings): Make header style inline with other pages (server#49820)
- Chore(deps-dev): bump @pinia/testing from 0.1.6 to 0.1.7 (server#49951)
- Chore(deps-dev): bump mime from 4.0.4 to 4.0.6 (server#49952)
- Improve ldap avatar handling (server#50162)
- Fix(settings): Correctly parse and display default quota (server#50187)
- Feat(contacts): Show time difference for users in different timezones (server#50214)
- Fix(conversion): missing target file extension (server#50219)
- Fix: Log exceptions that happen during file conversion (server#50227)
- Feat(settings): advanced deploy options (server#50230)
- Fix(files): more conversion tests and translate error messages (server#50240)
- Fix(UnifiedSearch): request data only when opening modal (server#50241)
- Build(deps-dev): bump eslint-plugin-cypress from 3.5.0 to 3.6.0 (server#50245)
- Fix(sharing): Set correct password context for share password validation (server#50255)
- Build(deps): bump core-js from 3.38.1 to 3.40.0 (server#50257)
- Build(deps): bump libphonenumber-js from 1.11.9 to 1.11.18 (server#50261)
- Fix(encryption): handle empty encryptionModules fine (server#50265)
- Fix(TemplateManager): Remove warning message (server#50271)
- Fix: prepare() threw \InvalidArgumentException which is deprecated (activity#1859)
- Feat: advanced deploy options (app_api#497)
- Ci: Update workflows from organization - fixes compile command (files_pdfviewer#1118)
- Chore(deps-dev): Bump sass from 1.83.1 to 1.83.4 (firstrunwizard#1485)
- Chore(deps-dev): bump vitest and @vitest/coverage-istanbul (logreader#1472)
- Chore(deps-dev): bump happy-dom from 16.5.3 to 16.6.0 (logreader#1473)
- [master] Update nextcloud/ocp dependency (logreader#1474)
- [master] Update nextcloud/ocp dependency (nextcloud_announcements#423)
- [master] Update nextcloud/ocp dependency (notifications#2156)
- Chore(deps-dev): Bump nextcloud/coding-standard from 1.2.3 to 1.3.2 (password_policy#673)
- Chore(deps-dev): Bump symfony/process from 6.4.8 to 6.4.14 in /vendor-bin/phpunit (password_policy#695)
- [master] Fix npm audit (password_policy#697)
- Chore(deps-dev): Bump sass from 1.83.1 to 1.83.4 (password_policy#716)
- [master] Update nextcloud/ocp dependency (photos#2764)
- Feat(storage): add size of appdata folder to statistics (serverinfo#728)
- Fix(freebsd): fix cpu count for load graph (serverinfo#733)
- [master] Update nextcloud/ocp dependency (serverinfo#735)
- Fix(deps): Make psr/log:3 compatible by rubix upgrade (suspicious_login#970)
- Chore(deps): update dependency @rollup/rollup-linux-x64-gnu to ^4.31.0 (main) (text#6845)
- Chore(dep): bump relative-ci/agent-upload-artifact-action (text#6859)
- Chore(deps): bump katex from 0.16.10 to 0.16.21 (text#6861)
- Fix(deps): update dependency yjs to ^13.6.23 (main) (text#6862)
- [main] Update nextcloud/ocp dependency (twofactor_nextcloud_notification#941)
