Hi, I’m new in the community.
I’m experiencing a similar problem updating from 16.0.3 to 16.0.6
Installed on a shared hosting, via Cpanel.
PHP version: 7.2.7
Apache version: 2.4.41
in my case the extra files found are:
.htq3ifvbjmycgq.data
error_log (no problem deleting this one)
The first one is the storage directory of my installation.
I suppose I cannot simply move it somewhere else without updating the database.
I don’t know if this is related in any way to the matter but: in the storage directory there is a huge amount on files named like “sess_00010e6f8d18a79bc745b97769ab38f8”
from the quick look i had it appears the sess files are temp files.
have a look in one and see if it gives you any pointers as to why they’re being created and not deleted automatically.
i’ve had more than a few issues with the updater and rogue files. i understand why it is so ‘strict’ but i do feel that the exclude process could be more refined. others, no doubt, will disagree.
glad you got it fixed.
I replaced the php.ini with an identical one, but this time I did it using the Cpanel editor, and it mysteriously worked: know I don’t have hundreds of garbage session files around.
thanks again
Unfortunately the upgrade issue still remains unfixed.
Could you explain me how to get trough the exclude process?
Are you sure? Nextcloud usually stores the data in a directory or with a symbolic link called “data”. You can find this directory or link in the Nextcloud document root, like e.g.:
../nextcloud/3rdparty
/apps
/config # <<< directory which contains the config.php file !!!
/core
/data # <<< !!!
/lib
Hi @j-ed, there is a /data dir, but it is empty (well it only contains .htaccess and index.html).
the .jtq5ifvbymrcgq.data is a directory, it contains __groupfolder admin user1 user2 appdata_ocn5b3kqwbqm updater_ocn5b3kqwbqm nextcloud.log update.log sess_66db0cf49f65287c783c7cc6e287bbdb
The config.php file can be found be accessing the “/config” directory within the Nextcloud document root folder, see the directory structure which I’ve already posted.
Thanks @lupinehorror, I tried that as you suggested, but than I wasn’t able to login with any user (nor admin itself) so it was impossible to perform any update.
Fortunately, going back to the initial situation, I’m able to login again and… nothing changed
Is there a way to import my user data to a fresh installation?
Would that make any sense?
