Nextcloud AIO Interface Slim Application Error
    • Debian 6.12.57-1~bpo12+1 (2025-11-17) x86_64
    • Yes
    • Today
    • AIO
When attempting to load the AIO interface on port 8080, I am shown a webpage that says only: “Slim Application Error // A website error has occurred. Sorry for the temporary inconvenience. // Go Back”. There is no further detail.
The main Nextcloud website on port 80 loads and is fully functional. I haven’t found any other errors. It has been a while since I have updated my containers, and I know that the master container has been out of date for ~ a couple of weeks. Since last accessing the AIO interface I have updated Debian packages, but have not touched the Nextcloud installation.
I have read Slim Application Error in AIO Interface and Slim Application Error when accessing AIO but their issues seem to be different, and they have more information presented to them. Not sure how to proceed to debug further so any help is appreciated!
  1. Fail to update Nextcloud AIO containers, including master container
  2. Wait for a couple of weeks to pass, and update other system packages.
  3. Attempt to load Nextcloud AIO to update containers.
[no mention of "slim" anywhere within the log files, only:]
ConnectException cURL error 7: Failed to connect to nextcloud.edsilver.uk port 443 after 4 ms: Could not connect to server (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://nextcloud.edsilver.uk/hosting/discovery
GET
https://192.168.0.37:8080/containers
[HTTP/1.1 500 Internal Server Error 80ms]
GET
https://192.168.0.37:8080/favicon.ico
[HTTP/1.1 404 Not Found 82ms]
not sure how to find this...
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nextcloud.edsilver.uk",
        "overwriteprotocol": "https",
            "localhost",
        "dbtype": "pgsql",
        "version": "30.0.13.1",
        "overwrite.cli.url": "https:\/\/nextcloud.edsilver.uk\/",
        "dbport": "",
        "loglevel": "2",
        "log_type": "file",
        "log_rotate_size": "10485760",
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": "2048",
        "preview_max_y": "2048",
        "jpeg_quality": "60",
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": "30",
        "share_folder": "\/Shared",
        "one-click-instance": true,
        "htaccess.RewriteBase": "\/",
        "appsallowlist": false,
        "dbpersistent": false,
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "updatechecker": false,
        "DOMAIN": "nextcloud.edsilver.uk"
  - activity: 3.0.0
  - admin_audit: 1.20.0
  - bruteforcesettings: 3.0.0
  - calendar: 5.3.6
  - camerarawpreviews: 0.8.7
  - circles: 30.0.0
  - comments: 1.20.1
  - contacts: 7.2.0
  - contactsinteraction: 1.11.0
  - dashboard: 7.10.0
  - dav: 1.31.1
  - deck: 1.14.5
  - federation: 1.20.0
  - files: 2.2.0
  - files_downloadlimit: 3.0.0
  - files_pdfviewer: 3.0.0
  - files_reminders: 1.3.0
  - files_sharing: 1.22.0
  - files_trashbin: 1.20.1
  - files_versions: 1.23.0
  - firstrunwizard: 3.0.0
  - logreader: 3.0.0
  - nextcloud-aio: 0.8.0
  - notifications: 3.0.0
  - notify_push: 1.3.0
  - oauth2: 1.18.1
  - password_policy: 2.0.0
  - photos: 3.0.2
  - privacy: 2.0.0
  - provisioning_api: 1.20.0
  - recommendations: 3.0.0
  - related_resources: 1.5.0
  - richdocuments: 8.5.13
  - serverinfo: 2.0.0
  - settings: 1.13.0
  - sharebymail: 1.20.0
  - support: 2.0.0
  - survey_client: 2.0.0
  - systemtags: 1.20.0
  - tasks: 0.16.1
  - text: 4.1.0
  - theming: 2.6.0
  - twofactor_totp: 12.0.0-dev
  - updatenotification: 1.20.0
  - user_status: 1.10.0
  - viewer: 3.0.0
  - weather_status: 1.10.0
  - whiteboard: 1.5.4
  - workflowengine: 2.12.0
  - app_api: 4.0.6 (installed 4.0.6)
  - encryption: 2.18.0
  - files_external: 1.22.0
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - suspicious_login: 8.0.0
  - user_ldap: 1.21.0
federatedfilesharing: 1.20.0
federation: 1.20.0
files: 2.2.0
logreader: 3.0.0
lookup_server_connector: 1.18.0
nextcloud_announcements: 2.0.0
notify_push: 1.3.0
oauth2: 1.18.1
photos: 3.0.2
privacy: 2.0.0
serverinfo: 2.0.0
settings: 1.13.0
sharebymail: 1.20.0
support: 2.0.0
systemtags: 1.20.0
tasks: 0.16.1
text: 4.1.0
theming: 2.6.0
twofactor_backupcodes: 1.19.0
user_status: 1.10.0
viewer: 3.0.0
webhook_listeners: 1.1.0-dev
whiteboard: 1.5.4
encryption: 2.18.0
twofactor_nextcloud_notification: 4.0.0
user_ldap: 1.21.0
Hi, can you please post the output of sudo docker logs nextcloud-aio-mastercontainer here?
Hi szaimen,
I can post the log in full if needed, but I’ve just found in it the following
Tips: To display error details in HTTP response set “displayErrorDetails” to true in the ErrorHandler constructor.
NOTICE: PHP message: Slim Application Error
Type: Exception
Code: 0
Message: Could not create the nextcloud-aio network: {“message”:“client version 1.41 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version”}
File: /var/www/docker-aio/php/src/Docker/DockerActionManager.php
Line: 916
Trace: #0 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(946): AIO\Docker\DockerActionManager->ConnectContainerIdToNetwork(‘nextcloud-aio-m
which I presume is the root of the error!
I have seen on Slim Application Error in AIO Interface the command:
sudo docker exec nextcloud-aio-mastercontainer bash -lc “sed -i ‘s/1.41/1.44/g’ /var/www/docker-aio/php/src/Docker/DockerActionManager.php”
is something like this suitable here? I am of course slightly wary of running random commands in case I bungle the installation further!
Thanks, Ed
Hi, see GitHub - nextcloud/all-in-one: 📩 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
Running the following command to replace a single instance of the version number in DockerActionManager.php and restarting the mastercontainer docker allowed the web interface to run - and thus allowed me to update my containers. This saved me reconfiguring the docker from scratch!
Thanks for the help @szaimen
