- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
Nextcloud Hub 25 Autumn (32.0.1)- Operating system and version (e.g., Ubuntu 24.04):
Debian 12 bookworm ARM
in Container
nginx/1.22.1
- PHP version (e.g, 8.3):
in Container
replace me
with 32.0.1
AIO
No
When opening Nextcloud AIO Interface from Admin Menu:
Slim Application Error
A website error has occurred. Sorry for the temporary inconvenience.
use Arm VPS (Hetzner) with Debian and AIO 32.0.1
Open Nextcloud AIO Interface
See error
docker logs nextcloud-aio-mastercontainer
Trying to fix docker.sock permissions internally...
Creating docker group internally with id 996
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
/usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
import pkg_resources
[Thu Nov 13 11:23:09.317854 2025] [mpm_event:notice] [pid 141:tid 141] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.4 configured -- resuming normal operations
[Thu Nov 13 11:23:09.318801 2025] [core:notice] [pid 141:tid 141] AH00094: Command line: 'httpd -D FOREGROUND'
[13-Nov-2025 11:23:09] NOTICE: fpm is running, pid 147
[13-Nov-2025 11:23:09] NOTICE: ready to handle connections
{"level":"info","ts":1763032989.3566098,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1763032989.356774,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7313500569,"previous":9223372036854775807}
{"level":"info","ts":1763032989.3568263,"msg":"using config from file","file":"/Caddyfile"}
{"level":"info","ts":1763032989.3583379,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1763032989.3609264,"msg":"serving initial configuration"}
NOTICE: PHP message: Slim Application Error
Type: Exception
Code: 0
Message: Could not create the nextcloud-aio network: {"message":"client version 1.41 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"}
File: /var/www/docker-aio/php/src/Docker/DockerActionManager.php
Line: 838
Trace: #0 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(868): AIO\Docker\DockerActionManager->ConnectContainerIdToNetwork('nextcloud-aio-m...', '')
#1 /var/www/docker-aio/php/public/index.php(83): AIO\Docker\DockerActionManager->ConnectMasterContainerToNetwork()
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): Closure->{closure:/var/www/docker-aio/php/public/index.php:74}(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#3 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Object(Closure), Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#5 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#10 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#12 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#13 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#17 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#18 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#19 /var/www/docker-aio/php/public/index.php(198): Slim\App->run()
#20 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
Type: Exception
Code: 0
Line: 838
#20 {main}
Type: Exception
Code: 0
Line: 838
#20 {main}
Deleting duplicate sessions
NOTICE: PHP message: 404 Not Found
Type: Slim\Exception\HttpNotFoundException
Code: 404
Message: Not found.
File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
Line: 76
Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
#1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#12 /var/www/docker-aio/php/public/index.php(198): Slim\App->run()
#13 {main}
Type: Exception
Code: 0
Line: 838
#20 {main}
Type: Exception
Code: 0
Line: 838
#20 {main}
Type: GuzzleHttp\Exception\ClientException
Code: 400
Message: Client error: `GET http://127.0.0.1/v1.41/containers/nextcloud-aio-apache/json` resulted in a `400 Bad Request` response:
{"message":"client version 1.41 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer (truncated...)
File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
Line: 111
Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
#1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::{closure:{closure:{closure:GuzzleHttp\Middleware::httpErrors():60}:61}:67}(Object(GuzzleHttp\Psr7\Response))
#2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
#3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::{closure:GuzzleHttp\Promise\Promise::settle():156}()
#4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
#5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
#6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
#7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
#8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
#9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(189): GuzzleHttp\Promise\Promise->wait()
#10 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/ClientTrait.php(44): GuzzleHttp\Client->request('GET', 'http://127.0.0....', Array)
#11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(42): GuzzleHttp\Client->get('http://127.0.0....')
#12 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(103): AIO\Docker\DockerActionManager->GetContainerRunningState(Object(AIO\Container\Container))
#13 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(952): AIO\Docker\DockerActionManager->GetContainerStartingState(Object(AIO\Container\Container))
#14 /var/www/docker-aio/php/public/index.php(148): AIO\Docker\DockerActionManager->isLoginAllowed()
#15 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(39): Closure->{closure:/var/www/docker-aio/php/public/index.php:143}(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#16 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(362): Slim\Handlers\Strategies\RequestResponse->__invoke(Object(Closure), Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#17 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#18 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#19 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(321): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#20 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(74): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
#21 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#23 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#25 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(36): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#27 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#28 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#29 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#30 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#31 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#32 /var/www/docker-aio/php/public/index.php(198): Slim\App->run()
#33 {main}
Type: Exception
Code: 0
Line: 838
#20 {main}
Type: Exception
Code: 0
Line: 838
#20 {main}
not related
PASTE HERE
"one-click-instance": true,
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"appsallowlist": false,
"redis": {
"port": 6379
"overwritehost": "...",
"overwriteprotocol": "https",
"trusted_domains": {
"0": "localhost",
"1": "...",
"3": "...",
"4": "...",
"5": "...",
"6": "..."
"dbtype": "pgsql",
"version": "32.0.1.2",
"overwrite.cli.url": "https:\/\/...\/",
"dbport": "",
"loglevel": "2",
"app_install_overwrite": [
"nextcloud-aio",
"tasks",
"imageconverter",
"facerecognition",
"metadata",
"duplicatefinder",
"backup",
"admin_notifications",
"news",
"snappymail",
"memories",
"files_fulltextsearch",
"fulltextsearch_elasticsearch",
"fulltextsearch",
"bookmarks",
"appointments",
"passwords"
"log_type": "file",
"log_rotate_size": "10485760",
"log.condition": {
"apps": [
"admin_audit"
"preview_max_x": 2048,
"preview_max_y": 2048,
"jpeg_quality": 60,
"enabledPreviewProviders": {
"1": "OC\\Preview\\MarkDown",
"2": "OC\\Preview\\MP3",
"3": "OC\\Preview\\TXT",
"4": "OC\\Preview\\OpenDocument",
"5": "OC\\Preview\\Movie",
"6": "OC\\Preview\\Krita",
"7": "OC\\Preview\\HEIC",
"8": "OC\\Preview\\TIFF",
"enable_previews": true,
"upgrade.disable-web": true,
"mail_smtpmode": "smtp",
"activity_expire_days": "30",
"share_folder": "\/Shared",
"htaccess.RewriteBase": "\/",
"dbpersistent": false,
"mail_sendmailmode": "smtp",
"mail_smtpauth": 1,
"mail_smtpport": "587",
"memories.exiftool": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/exiftool-aarch64-musl",
"memories.vod.path": "\/var\/www\/html\/custom_apps\/memories\/bin-ext\/go-vod-aarch64",
"twofactor_enforced": "true",
"admin"
"defaultapp": "dashboard",
"default_phone_region": "DE",
"updater.release.channel": "beta",
"updatechecker": true,
"theming_domain": {
"config_preset": 1,
"DOMAIN": "..."
appointments: 2.6.1
bookmarks: 16.0.1
calendar: 6.0.4
cloud_federation_api: 1.16.0
contacts: 8.0.6
dav: 1.34.2
federatedfilesharing: 1.22.0
files: 2.4.0
files_fulltextsearch: 32.0.2
files_pdfviewer: 5.0.0-dev.0
files_sharing: 1.24.0
files_trashbin: 1.22.0
files_versions: 1.25.0
fulltextsearch: 32.0.0
fulltextsearch_elasticsearch: 32.0.0
imageconverter: 2.1.0
lookup_server_connector: 1.20.0
mail: 5.5.14
memories: 7.7.0
nextcloud-aio: 0.8.0
notifications: 5.0.0-dev.0
notify_push: 1.2.1
oauth2: 1.20.0
passwords: 2025.11.20
previewgenerator: 5.10.0
profile: 1.1.0
provisioning_api: 1.22.0
richdocuments: 9.0.1
serverinfo: 4.0.0-dev.0
settings: 1.15.1
sharebymail: 1.22.0
spreed: 22.0.2
support: 4.0.0-dev.0
tasks: 0.17.1
text: 6.0.1
theming: 2.7.0
twofactor_backupcodes: 1.21.0
twofactor_totp: 14.0.0
updatenotification: 1.22.0
user_status: 1.12.0
viewer: 5.0.0-dev.0
workflowengine: 2.14.0Disabled:
activity: 5.0.0-dev.0 (installed 2.21.1)
admin_audit: 1.22.0 (installed 1.19.0)
app_api: 32.0.0 (installed 4.0.0)
bruteforcesettings: 5.0.0-dev.0 (installed 2.9.0)
circles: 32.0.0 (installed 29.0.0-dev)
comments: 1.22.0 (installed 1.19.0)
contactsinteraction: 1.13.1 (installed 1.10.0)
dashboard: 7.12.0 (installed 7.12.0)
encryption: 2.20.0
federation: 1.22.0 (installed 1.19.0)
files_downloadlimit: 5.0.0-dev.0 (installed 2.0.0)
files_external: 1.24.0 (installed 1.22.0)
files_reminders: 1.5.0 (installed 1.2.0)
firstrunwizard: 5.0.0-dev.0 (installed 2.18.0)
logreader: 5.0.0-dev.0 (installed 2.14.0)
nextcloud_announcements: 4.0.0-dev.0 (installed 1.18.0)
password_policy: 4.0.0-dev.0 (installed 1.19.0)
photos: 5.0.0-dev.1 (installed 5.0.0-dev.1)
privacy: 4.0.0-dev.0 (installed 1.13.0)
recommendations: 5.0.0-dev.0 (installed 2.1.0)
related_resources: 3.0.0-dev.0 (installed 1.4.0)
survey_client: 4.0.0-dev.0 (installed 1.17.0)
suspicious_login: 10.0.0-dev.0
systemtags: 1.22.0 (installed 1.19.0)
twofactor_nextcloud_notification: 6.0.0-dev.0
user_ldap: 1.23.0
weather_status: 1.12.0 (installed 1.12.0)
webhook_listeners: 1.3.0 (installed 1.1.0-dev)
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
