After upgrading to 18 earlier this afternoon I am having problem with the Community Document Server and OnlyOffice and am unable to open or edit any documents.
When I try to open a document I get this message: Community document server is not supported for this instance, please setup and configure an external document server.
I’ve tried the solution posted here, but it didn’t make any difference.
I also have these seemingly related errors in my logs, but don’t get a specific error when I try to open a document, even with debug logging turned on.
[no app in context] Error: OCP\AutoloadNotAllowedException: Autoload path not allowed: /config/www/nextcloud/apps/onlyoffice/lib/appconfig.php at <<closure>>
0. /config/www/nextcloud/lib/autoloader.php line 164
OC\Autoloader->isValidPath("/config/www/nex ... p")
1. <<closure>>
OC\Autoloader->load("OCA\\Onlyoffice\\AppConfig")
2. /config/www/nextcloud/apps/documentserver_community/lib/AppInfo/Application.php line 70
spl_autoload_call("OCA\\Onlyoffice\\AppConfig")
3. /config/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php line 118
OCA\DocumentServer\AppInfo\Application->OCA\DocumentServer\AppInfo\{closure}("*** sensitive parameters replaced ***")
4. /config/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 113
Pimple\Container->offsetGet("OCA\\DocumentSe ... g")
5. /config/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 408
OC\AppFramework\Utility\SimpleContainer->query("OCA\\DocumentSe ... g")
6. /config/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 386
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback("OCA\\DocumentSe ... g")
7. /config/www/nextcloud/apps/documentserver_community/lib/AppInfo/Application.php line 84
OC\AppFramework\DependencyInjection\DIContainer->query("OCA\\DocumentSe ... g")
8. /config/www/nextcloud/apps/documentserver_community/lib/AppInfo/Application.php line 88
OCA\DocumentServer\AppInfo\Application->getAutoConfig()
9. /config/www/nextcloud/apps/documentserver_community/appinfo/app.php line 4
OCA\DocumentServer\AppInfo\Application->register()
10. /config/www/nextcloud/lib/private/legacy/app.php line 265
require_once("/config/www/nex ... p")
11. /config/www/nextcloud/lib/private/legacy/app.php line 155
OC_App::requireAppFile("documentserver_community")
12. /config/www/nextcloud/lib/private/legacy/app.php line 128
OC_App::loadApp("documentserver_community")
13. /config/www/nextcloud/lib/base.php line 993
OC_App::loadApps()
14. /config/www/nextcloud/index.php line 38
OC::handleRequest()
GET /apps/files
from 172.19.0.1 by xthursdayx at 2020-01-19T00:38:35+00:00
and
[no app in context] Error: Error: Class 'OCA\Onlyoffice\AppConfig' not found at <<closure>>
0. /config/www/nextcloud/lib/private/ServerContainer.php line 107
OCA\Onlyoffice\AppInfo\Application->__construct()
1. /config/www/nextcloud/lib/private/ServerContainer.php line 133
OC\ServerContainer->getAppContainer("onlyoffice", "Onlyoffice")
2. /config/www/nextcloud/apps/onlyoffice/appinfo/app.php line 32
OC\ServerContainer->query("OCA\\Onlyoffice\\AppInfo\\Application")
3. /config/www/nextcloud/lib/private/legacy/app.php line 265
4. /config/www/nextcloud/lib/private/legacy/app.php line 155
OC_App::requireAppFile("onlyoffice")
5. /config/www/nextcloud/lib/private/legacy/app.php line 128
OC_App::loadApp("onlyoffice")
6. /config/www/nextcloud/lib/private/legacy/util.php line 197
OC_App::loadApps(["filesystem"])
7. /config/www/nextcloud/lib/private/Files/Filesystem.php line 267
OC_Util::setupFS("")
8. /config/www/nextcloud/lib/private/Server.php line 319
OC\Files\Filesystem::getMountManager(null)
9. /config/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php line 118
OC\Server->OC\{closure}("*** sensitive parameters replaced ***")
10. /config/www/nextcloud/lib/private/ServerContainer.php line 125
Pimple\Container->offsetGet("RootFolder")
11. /config/www/nextcloud/lib/private/Server.php line 341
OC\ServerContainer->query("RootFolder")
12. <<closure>>
13. /config/www/nextcloud/lib/private/Files/Node/LazyRoot.php line 62
call_user_func(Closure {})
14. /config/www/nextcloud/lib/private/Files/Node/LazyRoot.php line 142
OC\Files\Node\LazyRoot->__call("get", ["__groupfolders"])
15. /config/www/nextcloud/apps/groupfolders/lib/AppInfo/Application.php line 55
OC\Files\Node\LazyRoot->get("__groupfolders")
16. /config/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php line 118
OCA\GroupFolders\AppInfo\Application->OCA\GroupFolders\AppInfo\{closure}("*** sensitive parameters replaced ***")
17. /config/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 113
Pimple\Container->offsetGet("GroupAppFolder")
18. /config/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 408
OC\AppFramework\Utility\SimpleContainer->query("GroupAppFolder")
19. /config/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 386
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback("GroupAppFolder")
20. /config/www/nextcloud/apps/groupfolders/lib/AppInfo/Application.php line 89
OC\AppFramework\DependencyInjection\DIContainer->query("GroupAppFolder")
21. /config/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php line 118
22. /config/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php line 113
Pimple\Container->offsetGet("OCA\\GroupFolde ... d")
23. /config/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php line 408
OC\AppFramework\Utility\SimpleContainer->query("OCA\\GroupFolde ... d")
24. /config/www/nextcloud/lib/private/ServerContainer.php line 134
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback("OCA\\GroupFolde ... d")
25. /config/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php line 123
OC\ServerContainer->query("OCA\\GroupFolde ... d")
26. /config/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php line 104
OCA\Files_Versions\AppInfo\Application->loadBackend({@attributes: {f ... "})
27. /config/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php line 82
OCA\Files_Versions\AppInfo\Application->registerVersionBackends()
28. /config/www/nextcloud/lib/private/ServerContainer.php line 107
OCA\Files_Versions\AppInfo\Application->__construct()
29. /config/www/nextcloud/lib/private/ServerContainer.php line 133
OC\ServerContainer->getAppContainer("files_versions", "Files_Versions")
30. /config/www/nextcloud/apps/files_versions/appinfo/app.php line 24
OC\ServerContainer->query("OCA\\Files_Vers ... n")
31. /config/www/nextcloud/lib/private/legacy/app.php line 265
32. /config/www/nextcloud/lib/private/legacy/app.php line 155
OC_App::requireAppFile("files_versions")
33. /config/www/nextcloud/lib/private/legacy/app.php line 128
OC_App::loadApp("files_versions")
34. /config/www/nextcloud/apps/dav/appinfo/app.php line 35
OC_App::loadApps(["dav"])
35. /config/www/nextcloud/lib/private/legacy/app.php line 265
36. /config/www/nextcloud/lib/private/legacy/app.php line 155
OC_App::requireAppFile("dav")
37. /config/www/nextcloud/lib/private/legacy/app.php line 128
OC_App::loadApp("dav")
38. /config/www/nextcloud/lib/base.php line 993
OC_App::loadApps()
39. /config/www/nextcloud/index.php line 38
OC::handleRequest()
GET /apps/files
from 172.19.0.1 by xthursdayx at 2020-01-19T00:11:36+00:100:
and
12. <<closure>>
OC_App::loadApps()
OC::handleRequest()
GET /apps/files
Any ideas what I can try to fix this?
