NC23: How to enable Nextcloud Office
Works on an upgraded NC too.
Follow the steps in the post from @Paradox551 - after a reboot of my server everything is fine …
Thanks
To be honest - after the performance issues with 22.2.1 and now this not working upgrade - maybe its better to reduce the interval of new releases and better spend more time to test it.
For everyone that doesn’t want to bother with “broken” updates anymore: you should give GitHub - nextcloud/all-in-one: Nextcloud AIO stands for Nextcloud All In One and provides easy deployment and maintenance with most features included in this one Nextcloud instance. a try :wink:
Unfortunately it was only advertising. Office for the Nextcloud works the same as before. Either with the Collabora Docker. Or with the Collabora Online - Built-in CODE Server. This app for the Collabora built in code server is probably not working at the moment. So many are probably disappointed. Just like me.
Are you sure? It is beta and it says
This is beta software and not production ready. But feel free to use it at your own risk!
Seems you are right.
In fact, it is interesting to note that I havce been using external Collabora (CODE) (builtin not installed). After upgrade to NC 23, it works as before but as abvertised, the visuals are better and the external Collabora surprisedly declares itself as “NextCloud Office” when click about.
Upgraded to the newly dropped version of CODE 21.11.4 and Nextcloud Office still doesn’t work. Still having the issue where Office documents download instead of opening.
Here’s a guide to get it working - PSA: How to get collabora working on nextcloud 23!
Thanks for this, but my Nextcloud has several hundred GB of data spread across multiple accounts. I’m definitely not in a position to do a clean install on a whim.
You should test new releases then on a seperate test instance before you upgrade your production instance. I only have a small instance for me and my girlfriend, but I always test new releases in a seperate VM with a seperate Nextcloud Installation.
In general, my experience with Nextcloud over the last years has shown, that it is not a good idea to upgrade on day 1 to a new Nextcloud release, especially if you use a lot of apps. There are always a few apps not ready on release day. So either set up a test instance or wait until at least the first point release if you want to be sure that everything is working after a major upgrade. And yes I agree that Nextcloud should only release new versions when at least all core apps are working, but unfortunately my experience has shown that this is almost never the case…
Now, If you already updated your production instance to Nextcloud 23, you have imho two options: Wait for an update of the Built-In Collabora Server or use the official Collabora Docker image instead. With the Docker image everything is working as advertised, including the new Nextcloud Office interface.
It would be very nice if they would tell us if the build in code server will work again in the future. Or that you have to switch to the Docker Code
I think it was never intended not to work. :wink:
Screenshot_20211204-185115
Here it is, using external collabora instance in kubernetes. I am so suprised that it advertised itself as nextcloud office. It seems that the visual effects enhancements are due to NC codes, not collabora.
Be frank, I never had good experience using built-in onlyoffice or collabora: can’t install, or too slow. External services are always better, even u have only one bare metal server. According to my experience, the office function never malfunction after NC upgrade, if hosting it externally.
Thanks for this, this worked for me as well. My Collabora intsance is within my cloud server so I just took the internal code block and inserted it into my Nextcloud.conf
Worked a treat
Unfortunately not viable for me because it cant be used behind a reverse proxy.
That’s fair enough! I’m still pretty new to Nextcloud so I’ve been trying to keep my instance up to date but I should’ve probably waited a bit longer.
Having Collabora working isn’t super critical so I guess I’ll just wait it out.
Yes, that’s right but you might investigate yourself how it could made work behind reverse proxies. If you open a PR with that we might consider it then :slight_smile:
The problem with “waiting it out” is that it can take months to be fixed if not years.
The developers haven’t even addressed the issue yet. Not a peep from them. :slight_smile:
Once I install the Collabora Online App, it completely bricks my Nextcloud instance.
When trying to access my Nextcloud it loads forever until eventually a 504 error shows up, rendering the Nextcloud completely unusable.
I have to manually delete the richdocuments folder from the app directory to resolve the problem.
Used Versions:
Nextcloud 23.0.0.10
Ubuntu 18.04.5
PHP 8.0.13
Collabora Online 5.0.0
I think the problem might be infinite redirects, this is what I could find in the servers apache logs. It goes on like this for a while.
Imgur
Until eventually this comes
Imgur
Yeah, the built-in CODE server totally bricked my NC and half of the other things running on my server. Had to disable it from the command line, then remove it.
Here is what I did to get Nextcloud Office working:
1. Install CODE from Package
cd /usr/share/keyrings
sudo wget https://collaboraoffice.com/downloads/gpg/collaboraonline-release-keyring.gpg
Create this file:
sudo nano /etc/apt/sources.list.d/collaboraonline.sources
Paste this into the file for Ubuntu 18+ and save the file:
Types: deb
URIs: https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu1804
Suites: ./
Signed-By: /usr/share/keyrings/collaboraonline-release-keyring.gpg
Update and install:
sudo apt update && sudo apt install coolwsd code-brand
Update Collabora Configuration
sudo coolconfig set ssl.enable false
sudo coolconfig set ssl.termination true
sudo coolconfig set storage.wopi.host nextcloud.example.com
sudo coolconfig set-admin-password
sudo systemctl restart coolwsd
2. Create an NGINX Reverse Proxy Virtual Host
Notice, I removed the “https” and replaced it with “http” in all of the proxy_pass lines. This part is what left me scratching my head for a while. I’m not sure why the Collabora site lists those lines with https. We are doing https at the webserver level.
server {
 listen       443 ssl;
 server_name  collaboraonline.example.com;
 ssl_certificate /path/to/certificate;
 ssl_certificate_key /path/to/key;
 # static files
 location ^~ /browser {
   proxy_pass http://127.0.0.1:9980;
   proxy_set_header Host $http_host;
 # WOPI discovery URL
 location ^~ /hosting/discovery {
 # Capabilities
 location ^~ /hosting/capabilities {
 # main websocket
 location ~ ^/cool/(.*)/ws$ {
   proxy_set_header Connection "Upgrade";
   proxy_read_timeout 36000s;
 # download, presentation and image upload
 location ~ ^/(c|l)ool {
 # Admin Console websocket
 location ^~ /cool/adminws {
Restart NGINX.
3. Update Nextcloud Settings
Go to the Office section of Nextcloud settings and put your https://collaboraonline.example.com site into “Use your own server” and save.
I had also the problem after the upgrade to NC 23.
I followed the instructions from @nickt, made little changes to the nginx configuration (my nginx is separate server) and put the adress of this proxy into the office section from nextcloud.
Now all works fine.
thanks nickt
I’m not sure it’s worth all of the trouble to install. After getting it installed and tested, I’m going to pass for now and stick with OnlyOffice for production stuff. I’m seeing general slowness and some wonky things happening with rendering documents. Plus, mobile is a less than ideal UX. Hopefully NC Office can get closer to OnlyOffice one day. OnlyOffice just feels so much more native and fast.
