Sure, you can download the AppImage once https://github.com/nextcloud/client_theming/issues/61 has happened.
It is strange, since, AFAIK, the actual code should be the same for both versions, only the icons and some names have changed. Maybe the developers working on the code can look into it.
Are there any plans to do a rebuild for zesty? It just hit Beta 1. Likely it would just be a rebuild. I could potentially help with packaging.
I have uploaded the Zesty packages into the PPA and had them built. The building was OK, so it probably even works. Please, give them a try and let me know the results.
yes, more infos here
https://launchpad.net/~nextcloud-devs/+archive/ubuntu/client
Seems to work great! Thanks!
A post was split to a new topic: Debian-repo not working with Debian 9
2 posts were split to a new topic: No Nextcloud icon in panel on Mint
2 posts were split to a new topic: Problem updating client with repo
For some distributions, there are already sources to install the Nextcloud sync client via packet manager. @jospoortvliet posted a summary of all available distros:
People start to post their individual problems on this topic. If you need help building packages for your distribution or already existing packages have bugs, please open a new thread.
