After the Update to 2.3.0 the nemo integration stopped working, even though it was also updated:
sudo dpkg -l | grep next
ii libnextcloudsync0 2.3.0-1.0~xenial1 amd64 Nextcloud sync library
ii nextcloud-client 2.3.0-1.0~xenial1 amd64 Nextcloud desktop sync client
ii nextcloud-client-l10n 2.3.0-1.0~xenial1 all Nextcloud client internatialization files
ii nextcloud-client-nemo 2.3.0-1.0~xenial1 all Nemo plugin for Nextcloud
Is this just a minor problem like last time? if so, could you update the package?
greetings and thanks for you effort, i really like the client!
