I cant figure out why nextcloud office stopped working and how to fix it
Hi guys im running nextcloud from some time. But from some time after some update nextcloud office just stopped working. I tried reinstalling nextcloud office and collabra integrated server. Without any luck. Im getting error 60 and (sometimes) 28 When using “use own server” with disabled ssl veryfication im getting “Failed to connect to the remote server: Could not find urlsrc for application/vnd.openxmlformats-officedocument.wordprocessingml.document in WOPI discovery response”
Server info: ubuntu + nextcloud installed on apache2 (and if it metter i use cloud flare but it worked with it previously)
Hi @VoidDave, welcome to Nextcloud community :handshake:
Unfortunately a lot of information to help you is missing as you ignored the required support template. Please edit into your post and add as many information as possible. This will give us the technical info and logs needed to help you!
please use search and review the Collabora integration guide.
Hello VoidDave,
For me it looks like your server Version is newer, than the supported Version for Collaboration Online. Have you considert installing a dedicated Collabora Online Developer (CODE) Server?
Hi thanks for reply. I couldn’t figure it out with collabra server. But you pointed me in right direction. I just had to use onlyoffice. Thanks man
