How to manage Lets Encrypt for Nextcloud snap
Managing Lets Encrypt for Nextcloud snap
Nextcloud snap includes a service for automated HTTPS encryption using Lets Encrypt, self-signed certificates, or custom certificates. Lets Encrypt requires port 80 and port 443.
Enable HTTPS via Lets Encrypt. HTTP will redirect to HTTPS. Non-custom certificates will automatically be kept up-to-date. See nextcloud.enable-https -h for more information. Note that this requires sudo or root privileges.
Run nextcloud.enable-https -h for more information:
  • issue command in host shell
sudo nextcloud.enable-https -h
grafik
Enable Lets Encrypt in Nextcloud snap:
sudo nextcloud.enable-https lets-encrypt
TIP
Read the resulting response carefully and ensure the requirements are met.
grafik
Enter valid email address and domain/subdomain.
If you need to setup multiple domains then separate the domains/subdomains with a space.
IMPORTANT
Let’s Encrypt will expect that Nextcloud is exposed on ports 80 and 443. If you change ports and don’t put Nextcloud behind a reverse proxy such that ports 80 and 443 are sent to Nextcloud for that domain name, Let’s Encrypt will be unable to verify ownership of your domain and will not grant certificates.
Self-signed certificate is easier to setup than Let’s Encrypt certificates, but will cause warnings in browsers and due to being very basic won’t work with some applications.
Lets Encrypt failed after entering incorrect data.
If you’ve tried to encrypt your Nextcloud snap with Lets Encrypt and something went wrong after entering incorrect data, you’ll need to correct that data.
You may run into a ... permission error because only root may overwrite the data.
Simply switch user to root sudo -i and try entering the correct data as root # nextcloud.enable-https lets-encrypt.
If that doesn’t work, you’ll need to start from scratch.
Disable Lets Encrypt in Nextcloud snap
sudo nextcloud.disable-https lets-encrypt
Disable renew service in Nextcloud snap
Due to a snapd issue it may be necessary to disable the renewal-service manually.
sudo snap stop --disable nextcloud.renew-certs
Check renew service in Nextcloud snap
Renew service renew-certs.service is automated in Nextcloud-snap.
Check renewal by issuing:
sudo journalctl -u snap.nextcloud.renew-certs.service
Self signed certificate in Nextcloud snap
IMPORTANT
Generate and use a limited self-signed certificate. This is easier to setup than Let’s Encrypt certificates, but will cause warnings in browsers and due to being very basic won’t work with some applications.
Enable self signed certificate:
sudo nextcloud.enable-https self-signed
Change Lets Encrypt domain – Lets Encrypt from scratch
  1. Disable Lets Encrypt
  2. Remove all current Certificates
  3. Get new Certificates
  • disable HTTPS (this just removes a symlink, it doesn’t remove any certificates):
  • remove all/any certificates that are there (this includes self-signed certs, Let’s Encrypt certificates, everything). Make sure you get this command right, you don’t want to delete anything else in the current/ directory:
sudo rm -rf /var/snap/nextcloud/current/certs
  • add required empty directories:
sudo mkdir -p /var/snap/nextcloud/current/certs/certbot
  • pretend you’re enabling HTTPS for the first time, using only the domains you need to encrypt (If you need to setup multiple domains then separate the domains/subdomains with a space):
NOTE
Switch to root by issuing; sudo -i and try entering the correct data as root # nextcloud.enable-https lets-encrypt.
Lets Encrypt Log
View Lets Encrypt log in Netxtcloud snap:
sudo cat /var/snap/nextcloud/current/certs/certbot/logs/letsencrypt.log
Resources:
