Managing external media and storage
Snap confinement is a security feature and determines the amount of access an application has to system resources, such as files, the network, peripherals and services. Thus your Nextcloud snap is securely confined from the host system. Unless you specifically allow the Nextcloud snap to access the /media
or /mnt
directories on the host system, you will not be able to access any other directory outside of the confinement.
What permissions should external media have?
See FAQ’s and Snap confinement
Removable media or external storage must be mounted to either /media
or /mnt
as root with root permissions and connected to Snap!
The interface providing the ability to access removable media is not automatically connected upon install, so if you’d like to use external storage (or otherwise use a device in /media
or /mnt
for data), you need to give the snap permission to access removable media by connecting that interface:
sudo snap connect nextcloud:removable-media
How can I connect local or external media?
How can I connect a USB media device?
Mount directory
Tip: Ensure USB-boot is disabled in BIOS or use the
--nofail
option in/etc/fstab
for headless boot, especially when connecting an external USB-device.Tip: Its not recommended to use the “automount” directory
/media/$USER/
. Prefer creating a dedicated directory/media/nextcloud/
or/mnt/nextcloud/
and mounting the dedicated directory in/etc/fstab
Data directory
- Change data directory
- Change data directory, procedure to move or define data directory
- Default path
