I just finished installing Nextcloud and had to disable the Cloudflare proxy for Talk to work properly, but now I don’t know how to force the application to always load with https.
Hello @microvax,
welcome to the Nextcloud community! ![]()
please review 101: Self-hosting information for beginners you will understand if you are ready to go the self-hosting rabbit hole. If you want add informations requested in the support template
