Forum still in english
    • 33.0.4
    • Debian
    • Yes
    • At the forum installation
    • Using Yunohost
  1. Install the forum
  2. View all actions in english, but the menu bar is in French
No error, nothing to log.
PASTE
PASTE HERE
PASTE HERE
Hi @MaximeV
and welcome to the forum! :waving_hand:
I understand that the support template isn’t necessary for every question or that not every section applies to every issue, but two things:
  1. It would be nice if you could delete the sections you don’t fill out. That way people don’t have to search through a wall of text to find the actual question. :wink:
  2. It would also help if you could describe the problem a bit more precisely.
I assume you’re referring to this app: https://apps.nextcloud.com/apps/forum
If so, is the entire menu still in French even after switching your Nextcloud interface to English? Or is it only the category and forum section titles, like in the screenshot below (in my case they are in German)?
If it’s like on the screenshot above, then I think that’s expected. Those default categories are created in whatever language is selected when you first install or initialize the app. You can rename them manually (for example, to English), but they won’t automatically change when a user switches the interface language.
In my opinion, that wouldn’t make much sense anyway. In a forum where people can post in multiple languages, you would typically create separate categories or subforums for each language, just like in this forum. Those subforums are usually named in the language people are expected to post in and remain that way regardless of each user’s interface language.
Also, since you can use arbitrary names for subforums, it would be technically difficult to translate them automatically. Unlike the rest of the interface, the app can’t simply ship predefined strings in different languages, it would somehow have to translate whatever names you choose.
Or, more simply, think of those menu entries as part of the forum’s content rather than part of the user interface. :wink:
The French translation of the Forum app is still far from complete.
2026-07-02_10h10_06
