File transfert and loopback problems
hello,
i’ve solve installing AIO on my Pi3b+, and end configure wan access
but i have somes news problems :
  • i try to sent just a picture from my phone (connect by data to internet) to my nextcloudpi and the tranfert don’t realy start
  • on the computer, i have drop a file in the folder and the transfert are ok
  • when i connect my phone to my lan by wifi, i can’t connect to my cloud
  • i have folow my internet provider to active the loopback but that stil don’t work
  • i don’t have find how to set in the app how to make a switching méthode for lan/wan
i have make somes research on the forum but i don’t find the answer i need
could you help me
ps i’m french so as possible use the more simple words you can
Nice reading:
https://help.nextcloud.com/t/101-split-brain-dns-split-horizon/202579
https://help.nextcloud.com/t/101-network-domain-and-dns/201882
https://help.nextcloud.com/t/101-self-hosting-information-for-beginners/187015
Other topic is even well known issue. Do some reading on github issue discussions desktop clients android or ios.
Being french is no excuse anymore :wink:.
linux base systems are not easy for me i don’t undertand all, in your links i dont see information who help me,
exept potentaly the Pi hole but dit it need an other Pi ?
hello all,
when i’m connected with my phone to the same rooter than my pi, i cant access to my nextcloud, so i must turn off my wifi on my phone to be connected to the data to access to it,
somes times he don’t want to receve files
i don’t find goods answer about the loopback with my internet provider
could you help me ?
