Display issues after upgrade to NC 13.0.0
Issue in NC 13.0.0 (it will be fixed in 13.0.1), related github-issue → [13.0.0RC2] Login buttion is off · Issue #8043 · nextcloud/server · GitHub
Symptoms: White screen on web-interface (except for the navigation elements), other display issues with web-interface (also when individual themings are used).
Workaround: Delete the CSS and js cache on your server, run these commands in your nextcloud folder via terminal:
rm -r data/appdata_*/css/* data/appdata_*/js/*
occ files:scan-app-data
reload the page
Remark: If the whole screen is white, there can be as well other server issues, for more information you have to check your logfiles (webserver, nextcloud).
