Collabora / Unautorisierter WOPI-Host
I’m having trouble setting up a Collabora Docker container in Nextcloud. I’m running Nextcloud, NGINXProxyManager, and Collabora on Proxmox (9.0.11)/Docker LXC Containers (Debian 12.12). All three applications are running as individual containers. The NGINXProxyManager is the reverse proxy for the applications’ external access. I believe I’ve configured Collabora correctly because when I access it through the reverse proxy, I get an “OK” message in the browser. However, when I try to open a Word document via Nextcloud, I get the following error message: “Failed to load document. Unauthorized WOPI host. Please try again later and contact your administrator if the problem persists.” I’ve read quite a bit but haven’t quite grasped what a WOPI host is. Does anyone have any idea what I need to configure and where?
BR Jan
    • 32.0.1
    • Debain 12.12, Docker version 28.5.1
    • replace me
    • replace me
    • replace me
    • no
    • a long time before
    • Docker via Portainer
    • yes
{"reqId":"3h0JB1zvpbQamhkiJokH","level":3,"time":"2025-11-07T12:46:52+00:00","remoteAddr":"192.168.2.190","user":"jan","app":"PHP","method":"PROPFIND","url":"/remote.php/dav/files/jan/","message":"Icewind\\SMB\\Native\\NativeState::lseek(): Implicitly marking parameter $path as nullable is deprecated, the explicit nullable type must be used instead at /app/www/public/3rdparty/icewind/smb/src/Native/NativeState.php#346","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.1 (build 20251027) (Nextcloud, windows-10.0.26200 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"8a6ac51a-7ee0-46f5-99da-e0a3b8758020","data":{"app":"PHP"},"id":"690dea4dac916"}
PASTE
PASTE HERE
root@nextcloud:/#occ config:list system
            "nextcloud.niederdraeing.uk",
            "docker-proxmox",
            "docker-proxmox.fritz.box",
            "192.168.2.204"
        "dbtype": "mysql",
        "version": "32.0.1.2",
        "overwrite.cli.url": "https:\/\/nextcloud.niederdraeing.uk",
        "dbport": "",
        "mysql.utf8mb4": true,
        "default_phone_region": "DE",
        "default_language": "de",
        "defaultapp": "dashboard,files",
        "enable_previews": true,
        "preview_max_x": 4096,
        "preview_max_y": 4096,
        "preview_max_filesize_image": 50,
        "preview_max_memory": 256,
        "enabledPreviewProviders": [
            "OC\\Preview\\PNG",
            "OC\\Preview\\JPEG",
            "OC\\Preview\\jpg",
            "OC\\Preview\\JPG",
            "OC\\Preview\\GIF",
            "OC\\Preview\\HEIC",
            "OC\\Preview\\BMP",
            "OC\\Preview\\XBitmap",
            "OC\\Preview\\MP3",
            "OC\\Preview\\TXT",
            "OC\\Preview\\MarkDown",
            "OC\\Preview\\OpenDocument",
            "OC\\Preview\\Krita",
            "OC\\Preview\\Movie",
            "OC\\Preview\\MKV",
            "OC\\Preview\\MP4",
            "OC\\Preview\\AVI",
            "OC\\Preview\\PDF",
            "OC\\Preview\\Imaginary",
            "OC\\Preview\\Image"
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "maintenance_window_start": 0,
        "app_install_overwrite": [
            "news",
            "maps",
            "bookmarks_fulltextsearch",
            "wopi",
            "backup",
            "keeweb",
            "memories",
            "bookmarks",
            "deck",
            "fulltextsearch",
            "fulltextsearch_elasticsearch",
            "libresign",
            "twofactor_admin"
        "filelocking.enabled": true,
        "memcache.locking": "\\OC\\Memcache\\APCu",
        "upgrade.disable-web": true,
        "loglevel": 3,
        "memories.exiftool": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-musl",
        "memories.vod.path": "\/config\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
        "memories.index.path.blacklist": "\\\/@(Recently-Snapshot|Recycle)\\\/",
        "memories.gis_type": 1
occ app:list
  - activity: 5.0.0-dev.0
  - admin_audit: 1.22.0
  - app_api: 32.0.0
  - bookmarks: 16.0.0
  - calendar: 6.0.3
  - circles: 32.0.0
  - comments: 1.22.0
  - contacts: 8.0.6
  - contactsinteraction: 1.13.1
  - cookbook: 0.11.5
  - dashboard: 7.12.0
  - dav: 1.34.2
  - deck: 1.16.0
  - external: 7.0.0
  - federation: 1.22.0
  - files: 2.4.0
  - files_external: 1.24.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.0
  - files_trashbin: 1.22.0
  - fulltextsearch: 32.0.0
  - fulltextsearch_elasticsearch: 32.0.0
  - keeweb: 0.6.22
  - libresign: 12.1.0
  - logreader: 5.0.0-dev.0
  - mail: 5.5.12
  - maps: 1.6.0
  - memories: 7.7.0
  - news: 27.1.0
  - notes: 4.12.3
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - photos: 5.0.0-dev.1
  - previewgenerator: 5.10.0
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - recognize: 10.0.5
  - richdocuments: 9.0.1
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - spreed: 22.0.2
  - support: 4.0.0-dev.0
  - survey_client: 4.0.0-dev.0
  - systemtags: 1.22.0
  - text: 6.0.1
  - theming: 2.7.0
  - twofactor_admin: 4.8.0
  - twofactor_totp: 14.0.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - weather_status: 1.12.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - backup: 1.4.0 (installed 1.4.0)
  - calendar_news: 1.1.16 (installed 1.1.16)
  - encryption: 2.20.0 (installed 2.17.0)
  - files_downloadlimit: 5.0.0-dev.0 (installed 2.0.0)
  - files_versions: 1.25.0 (installed 1.24.0)
  - firstrunwizard: 5.0.0-dev.0 (installed 2.18.0)
  - nextcloud_announcements: 4.0.0-dev.0 (installed 1.18.0)
  - user_ldap: 1.23.0 (installed 1.20.0)
  - wopi: 3.5.11 (installed 3.5.11)
The topic post up frequently please use search and review Collabora integration guide for details. There are also references to related posts
Thanks for youre answer. I read this documentation. And check my configuration.
In the Docker-container Nextcloud:
curl https://collabora.mysite.de/hosting/discovery
Answer was OK: Right Site for collabora was configured.
In the Docker-container collabora
curl https://nextcloud.mysite.de/hosting/discovery
OK. Get some answers. Right Site for Nextcloud was configured.
In the Docker-container collabora:
curl https://nextcloud.mysite.de/status.php
{"installed":true,"maintenance":false,"needsDbUpgrade":false,"version":"32.0.1.2","versionstring":"32.0.1","edition":"","productname":"Nextcloud","extendedSupport":false}
In the Nextcloud Container ist the richdocuments enabled
occ config:app:set richdocuments wopi_url --value https://collabora.mysite.de
Answer: Config value were not updated
occ richdocuments:activate-config
✓ Reset callback url autodetect
Checking configuration
🛈 Configured WOPI URL: https://collabora.mysite.de
🛈 Configured public WOPI URL: https://collabora.mysite.de
🛈 Configured callback URL:
✓ Fetched /hosting/discovery endpoint
✓ Valid mimetype response
✓ Valid capabilities entry
✓ Fetched /hosting/capabilities endpoint
✓ Detected WOPI server: Collabora Online Development Edition 25.04.7.1
Collabora URL (used for Nextcloud to contact the Collabora server):
Collabora public URL (used in the browser to open Collabora):
Callback URL (used by Collabora to connect back to Nextcloud):
autodetected (will use the same URL as your user for browsing Nextcloud)
I check the Adminsettings / Office
and test to open an docx file:
I don’t now what ist wrong or what can i check at next. Do you have any ideas?
BR
Jan
But not completely. - Scroll down in this window and check the authorized WOPI-URL.
If there is/are local IP-addresse(s) inserted, they may be wrong.
In normal case you access to Nextcloud over your public IP-address. So the authorized WOPI address may be set to 0.0.0.0 or the public IP. But the public IP changes frequentliy on dial-in router connections.
Edit: the correct IP-address is 0.0.0.0/0 (see below)
thanks for you’re help.
I change the WOPI address to 0.0.0.0. bit it dosn’z work. The same error.
Do you see my mistakes?
BR
Jan
That looks good. But I found out, that after the URI of your Collabora Online Server the port number seems to be missing (1st screenshot).
What about the certificate-validation? Do you get an error, if you remove the mark?
@JanNi do you want to try this: Collabora CODE for Nextcloud with Docker
later Office versions (8.x.x) require a / slash at the end of your URL to connect successfully!
if you want to allow all IPv4 addresses use 0.0.0.0/0 otherwise you only allow the single IPv4 address 0.0.0.0 which doesn’t exist :wink: I would recommend you look at the logs (“docker logs $collabora_container_name” and “docker logs $nextcloud_container_name” for docker setup) to see which address is used.. often it is your public IP but could be local lan as well depending on setup.. look at wopi_allowlist for more discussions
Hi everyone,
I adjusted the wopi-allowlist to the setting 0.0.0.0/0. After that, I was able to open Office documents in Netcloud. Thank you so much for your help. You put me on the right track, and I learned something new.
BR Jan
