Hey, I have nextcloud version 28 installed on a vm with Ubuntu
when I am trying to use Collabora it sometimes works and sometimes I get this error
“Failed to establish socket connection or socket connection closed unexpectedly. The reverse proxy might be misconfigured, please contact the administrator. For more info on proxy configuration please checkout https://sdk.collaboraonline.com/docs/installation/Proxy_settings.html”
and on the logs I get
Server error: GET https://url/apps/richdocumentscode/proxy.php?req=/hosting/capabilities resulted in a 530 response: error code: 1033
Failed to fetch the Collabora capabilities endpoint: Server error: GET https://url/apps/richdocumentscode/proxy.php?req=/hosting/capabilities resulted in a 530 response: error code: 1033
i think its because it cant reach to
on the settings everything looking ok its even saying
Collabora Online server is reachable.
Collabora Online Development Edition 23.05.6.4 aff0ccf
and nextcloud talk is not working aswell
I can join to a call but they can’t connect
so I am not sure what wrong or what he needs
what should I do ?
until you edited the URLs anually it looks your system is not aware of it’s domain name. Please ensure your reverseproxy forwards the required reverse proxy headers like X-Forwarded*
please don’t mix different topics, create another thread and this time fill required support template
I’m not sure what is the real issue - but I don’t see any problems with NC 28.0.1 running as Apache Docker container and separate CODE server - according to this comment this might be a reason.
