Call for testing: Nextcloud 13.0.0 RC4
Hi @guddl,
could you report this in the calendar repo: https://github.com/nextcloud/calendar/issues and mention me as well as @skjnldsv there? Thanks
Done. Issue #700 :wink: https://github.com/nextcloud/calendar/issues/700
When I try to upgrade from Nextcloud 13 Beta 3 to Beta 4 or RC1 I’m getting the following error:
Doctrine\DBAL\Schema\SchemaException: An index with name 'idx_4c258fd8b269' was already defined on table 'cards'.
Update failed
any ideas?
Could you report this in the bug tracker please: https://github.com/nextcloud/server/issues
Thanks
There is now an RC2 - find the changelog in https://github.com/nextcloud/server/pull/7940
Find it here:
https://download.nextcloud.com/server/prereleases/nextcloud-13.0.0RC2.zip
https://download.nextcloud.com/server/prereleases/nextcloud-13.0.0RC2.tar.bz2
Changelog:
Updated to RC2 and the E2E module, after upload other files in a folder seem to disappear, in web and app but activities says it was successful and folder access is mentioned and size increased but files invisible and no longer downloadable, “file no longer exists on the server”…
Switched off E2E problem solved.
@Fred_Dresken_Maveric Could I ask you to report this in https://github.com/nextcloud/end_to_end_encryption/issues? Thanks
Is there any way to go to NC 13 RC with the web updater without a manual update? The Beta channel does not have the NC 13 anymore.
I could provide you tomorrow with an updater server url that does this. This then only needs to be set in the config.php and will work for you. Is this okay?
Perfect, thank you…
Hi, sorry that it took a bit longer - the 13.0.0 RC3 should be available on the beta channel for 12 and 13 versions. Have fun :slight_smile:
Diff from RC2 to RC3 is:
I am not sure if this is the right place. Just a maybe silly question.
But after upgrade from the latest 12 version to 13.0.0 RC3 I cannot share directories and files any more. The “shares” already configured from the old/stable version still work, but I cannot configure them in an way in the web interface. The icon is gone.
Can someone direct me in the right direction?
That sounds weird. Have you tried to clear the browser cache? Maybe it’s only a caching issue :confused:
Yes, it happens with every clean browser.
This problem appears every time a share is involved.
For example when viewing a picture full screen I can see a “share-Button”, but when pressing this one nothing happens and when I delete the file I get “Error while retrieving shares”.
Deletion works by the way.
I disabled and enable all nextcloud apps. There is nothing in the error.log
(And during upgrade I didn’t notice any warnings/failures)
Update:
Personal settings “nextcloud/index.php/settings/user/sharing” don’t show anything.
No entry in the logfiles, just an emtpy page.
The upgrade from 13RC2 to 13RC3 went smooth here so far. Yet in one instance I opened general settings and saw “You are on 13RC3” AND “There is a new (beta) version: 13RC3”. After a Shift-Reload, it showed “You run the latest version”. But it should not be possible to have the state I had.
General question (nor 13 or RC3 specific): Why are all non-default apps deactivated every time I upgrade. It’s so tiring and seems perfectly scriptable to re-enable all compatible apps after an update.
That didn’t sound very well.
We have had those errors with one of the 12.x.x Version and LDAP Accounts too - not long ago.
After a fix errors had gone …
Does the Share-Error occur with local accounts too - Diff to LDAP Accounts?
Yes, it is only a server in the local network without ldap.
I just tried downloading the recent tarball/zip and tried (saving my config or course) but the problem persists.
As I want to be on the save side, I reinstalled the V12 again.
RC4 (and hopefully the last RC) is out as of now. Changelog is in https://github.com/nextcloud/server/pull/8127 and the updater server already serves it. :slight_smile:
