Hello Dear,
You can not upgrade directly from 10 to 13. First, you have to upgrade it 11 then 12ā¦13.
Hello Dear,
you might have missed that Iām talking about an owncloud installation.
Migration from OC 10.0.4 to nextcloud 12.0.4 is supposed to work - though it fails for me with a bug that is supposed to be fixed in NC 13. (#7432)
Upgrade from 10 to 13 is not possible. If you start with ownCloud 10 then you need to upgrade to Nextcloud 12 first. Just use the migrator script which guides you through the correct versions automatically: https://nextcloud.com/migration/
we just published the RC1 of 13.0.0 in the prereleases folder on the download server. It will also be available soon on our updater server for the beta channel of 12 and 13 instances.
How is the state from the linux desktop client, is there e2e encryption support?
Did update via web-updater. 1st ok, but than white page! App files_accesscontrol was responsible for that. i moved the dir out the apps-directory. then 2nd step (database-upgrade) got working and did fine. The app files_accesscontrol came back by itself?? now i have a bunch of apps to update
Did work fine ā¦
Talk-app works out of the box. gorgous!!! Congrats
Yes - the files_accesscontrol app needs to be upgraded before the update: https://github.com/nextcloud/server/issues/7532
Update on 2 machines (x86_64, armv7), works very well.
Thanks for the work !
[quote=āMorrisJobke, post:29, topic:25435, full:trueā]
[/quote]
until then, I canāt update my spin, isnāt it?
The updater server is serving the new version already
Updated on our server. Works fine. Thanks.
works fine here, only the news app had some problems. scroll and read did not work.
Just a note for those using gdrive or dropbox as external storage:
Related topic on github:
Helo Morris, very sorry for lame question, but I am very new to snap.
How should I get 13.0.0 RC1?
snap refresh nextcloud --channel=13/RC1
is not ok
Many thnx in advance for patience
Hi the snap is maintained by @kyrofa and I donāt know if this is already updated.
@maurizio not yet. Weāve requested a track for v13 and are waiting for it to be fulfilled. Once that happens, youāll be able to get this in 13/candidate.
Until then, you can always try edge which is actually daily master. I suspect itāll give you a taste of v13 anyway, but it can be unstable FYI. Note also that downgrades are unsupported-- if you switch your production snap to v13, you canāt later to back to v12 unless you revert. I only recommend doing this on a test setup.
Used a modified version of Nachoās nc-nextcloud in nextcloudpi-config to install 13RC1.
Seems to be running fine, nicely responsive.
Getting errors from Zend OPcache although they donāt seem serious.
pi@nextcloudpi:~ $ php -v
Cannot load Zend OPcache - it was already loaded
PHP 7.0.27-0+deb9u1 (cli) (built: Jan 5 2018 13:51:52) ( NTS )
Copyright (c) 1997-2017 The PHP Group
Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
with Zend OPcache v7.0.27-0+deb9u1, Copyright (c) 1999-2017, by Zend Technologies
Alright, the RC is up for the snap, at least for amd64 and i386 (the other architectures are still waiting on the build farm to get meltdown/spectre mitigations). You can check it out from the 13/candidate channel:
$ sudo snap install nextcloud --channel=13/candidate
Or if you already have it installed:
$ sudo refresh nextcloud --channel=13/candidate
Note that downgrades are not supported without a revert, so use your own best judgment.
