Workarounds for Same-Site-Cookie bug with Thunderbird
Related to https://github.com/nextcloud/server/issues/10134
Workaround known to work:
(as described in Thunderbird’s release notes):
  • go to the config editor (Settings -> Advanced -> General -> Config Editor)
  • search for network.cookie.same-site.enabled
  • set it to false
For your own security you should set it back to true once this issue is resolved.\
Unconfirmed workaround by other users:
I have found a safer workaround: If you have changed it already set network.cookie.same-site.enabled to true again. Then set all third party cookies to be denied and add an exception for the domain your Nextcloud installation is running on.
Settings > Privacy > Web content > Exceptions > Enter https://your.domain.org [ /nextcloud ]
I have tried both of the workarounds listed above. I am not sure this this is related (beginner/sorry) but while my calendar is showing in Thunderbird (60.2.1), it will not allow me to choose or turn it on. Please see attached.
I had the same issue testing all workarounds to finally discover that is was the TOTP security setting in my nexcloud account that was the problem. removing it was the solution.
