Where are the language settings for Collabora?
I’m sorry I have to post to a topic that was started in 2016 (!)
I realize that for a lot of people these ā€œdefaultā€ settings are just fine:
  • currency: $ (dollar)
  • decimal separator: . (dot)
  • thousands separator: , (comma)
But I’m Dutch… so I’dd like to be able to alter them (per document…) to:
  • currency: € (euro)
  • decimal separator: , (comma)
  • thousands separator: . (dot)
This varies per country… It can’t be thĆ t hard to set this up?
I’dd love to be able to do this not only in settings (where I now can only set up a template directory) but also alter this via a setting somewhere after opening the document itself.
Hi, I have the same problem. Do you found a solution?
it can be setted by (Settings > Personal info > Language). After setting to ā€˜Nederlands’, it will as your expectation.
Similar to How to set the default length unit used in Collabora Online
This issue has crept back up. I tried changing public_html/data/appdata_<unique value>/richdocuments/empty_templates and the document.ott file there to no avail. Blank documents do not represent the default language.
