Warning: "Used memory grew by more than 10 MB when executing job ... UpdateAvailableNotifications"
Version info
Nextcloud version (eg, 20.0.5): 29.0.0
Operating system and version (eg, Ubuntu 20.04): Debian 12
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.59
PHP version (eg, 7.4): 8.2.18
Warning:
Used memory grew by more than 10 MB when executing job OCA\UpdateNotification\BackgroundJob\UpdateAvailableNotifications
It’s a bit of nitpicking for sure but… I don’t like having even a warning for me there is a problem somewhere and it should be fixed.
Yes
I would assume:
  1. Configure maintenance hours
  2. Let run the maintenance cronjob
{"reqId":"U6b2Q9bDGWzSS0dsf7Q6","level":2,"time":"2024-05-01T04:20:52+02:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Used memory grew by more than 10 MB when executing job OCA\\UpdateNotification\\BackgroundJob\\UpdateAvailableNotifications (id: 13740, arguments: null): 41.4 MB (before: 30.5 MB)","userAgent":"--","version":"29.0.0.19","data":{"app":"cron"}}
{"reqId":"Wxf4y3OcWsfw3jBOTk8A","level":2,"time":"2024-05-02T04:25:59+02:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Used memory grew by more than 10 MB when executing job OCA\\UpdateNotification\\BackgroundJob\\UpdateAvailableNotifications (id: 13740, arguments: null): 40.3 MB (before: 30.6 MB)","userAgent":"--","version":"29.0.0.19","data":{"app":"cron"}}
Actual config
  'instanceid' => '(╯°□°)╯︵ ┻━┻',
  'passwordsalt' => '(╯°□°)╯︵ ┻━┻',
  'secret' => '(╯°□°)╯︵ ┻━┻',
    0 => '(╯°□°)╯︵ ┻━┻',
  'version' => '29.0.0.19',
  'maintenance_window_start' => 6,
  'upgrade.disable-web' => false,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'redis' =>
    'host' => '(╯°□°)╯︵ ┻━┻',
    'port' => (╯°□°)╯︵ ┻━┻,
  'dbhost' => 'MariaDB',
  'dbname' => '(╯°□°)╯︵ ┻━┻',
  'dbuser' => '(╯°□°)╯︵ ┻━┻',
  'dbpassword' => '(╯°□°)╯︵ ┻━┻',
  'dbtableprefix' => '(╯°□°)╯︵ ┻━┻',
  'default_language' => '(╯°□°)╯︵ ┻━┻',
  'default_locale' => '(╯°□°)╯︵ ┻━┻',
  'default_phone_region' => '(╯°□°)╯︵ ┻━┻',
  'default_timezone' => '(╯°□°)╯︵ ┻━┻',
  'loglevel' => 2,
  'logtimezone' => '(╯°□°)╯︵ ┻━┻',
  'log_rotate_size' => 524288000,
  'log_query' => false,
  'profiler' => false,
  'mail_domain' => '(╯°□°)╯︵ ┻━┻',
  'mail_from_address' => '(╯°□°)╯︵ ┻━┻',
  'mail_smtpmode' => 'smtp',
  'mail_smtphost' => '(╯°□°)╯︵ ┻━┻',
  'mail_smtpport' => '465',
  'mail_smtpsecure' => 'ssl',
  'mail_smtpauth' => 1,
  'mail_smtpname' => '(╯°□°)╯︵ ┻━┻',
  'mail_smtppassword' => '(╯°□°)╯︵ ┻━┻',
  'overwritehost' => '(╯°□°)╯︵ ┻━┻',
  'overwrite.cli.url' => '(╯°□°)╯︵ ┻━┻',
  'trusted_proxies' =>
  'theme' => '',
  'app_install_overwrite' =>
    0 => 'tasks',
    1 => 'money',
Privated config
The (╯°□°)╯︵ ┻━┻ config is fun, but hard to read so I’m posting it here replace with private :wink:
  'instanceid' => 'private',
  'passwordsalt' => 'private',
  'secret' => 'private',
    0 => 'private',
  'apps_paths' =>
    0 =>
      'url' => '/apps',
    1 =>
      'writable' => true,
  'redis' =>
    'host' => 'private',
    'port' => private,
  'dbname' => 'private',
  'dbuser' => 'private',
  'dbpassword' => 'private',
  'dbtableprefix' => 'private',
  'default_language' => 'private',
  'default_locale' => 'private',
  'default_phone_region' => 'private',
  'default_timezone' => 'private',
  'loglevel' => 2,
  'logtimezone' => 'private',
  'mail_domain' => 'private',
  'mail_from_address' => 'private',
  'mail_smtphost' => 'private',
  'mail_smtpname' => 'private',
  'mail_smtppassword' => 'private',
  'overwritehost' => 'private',
  'overwrite.cli.url' => 'private',
    0 => 'private',
  'theme' => '',
    0 => 'tasks',
    1 => 'money',
I had the same problem and I solved it in the following way, at least the warning didn’t appear again.
If you want you can try and if that not work for you is easy to revert.
sudo nano /var/www/nextcloud/cron.php
(or the path where your nextcloud instalation is)
Search in the file (crt+w) “memoryafter” and find this string:
if ($memoryAfter - $memoryBefore > 10_000_000)
Replace the 1 to 3 (30mb), like this:
if ($memoryAfter - $memoryBefore > 30_000_000)
Save and exit (crt+x - > Y - > Enter)
And just like that error is solved (at least for me).
Good Luck
I think this worked for me, didn’t have this issue again after I edit the parameters.
Update on this: it didn’t work, unfortunately. Cron jobs is acting like crazy, my disk space usage increased about 20GB too. I made a fresh install and didn’t set up cron jobs for now. I’ll wait for it to be fixed to try again.
Please try this one
Output Buffering must be turned off in .htaccess or .user.ini or php.ini, or PHP will return memory-related errors:
  • output_buffering = 0
Reference: Uploading big files > 512MB — Nextcloud latest Administration Manual latest documentation
I have self-maintained instance of Nexctloud install via snap. It has been running exceptionally well for years now but recently it updated itself to Hub8. Since then I have noticed the following in the logs:
Used memory grew by more than 10 MB when executing job OCA\Passwords\Cron\CheckPasswordsJob (id: 15404, arguments: null): 46.6 MB (before: 25.9 MB)
I am not sure if the issue coincides with this event but seems it may have something to do with it . I was unable to locate the cron.php file to try and increase the memory threshold. Any help or suggestions would be greatly appreciated!
Please never edit the source code manually.
This warning can be safely ignored by most admins, but for some admins it is relevant when they run very large instances. This is not a random debug and needs to stay. One might argue about the threshold size, but you will always find people complaining about it regardless of the chosen threshold due to the widely different sizes of Nextcloud instances.
Thank you for the reply. I will go ahead and ignore. It has not caused any other noticeable issues.
The thresholds have been slightly tweaked in the latest code base. You won’t see the log @ 10 MB any longer in 29.0.4. It has been adjusted to 50 MB.
