I have installed the virtual drive and set it up to sync. However I have randomly getting error "
Hi @neometals,
You are missing the required support template. Please fill this form out and edit into your post.
This will give us the technical info and logs needed to help you! Thanks.
system information
- if you have systeminfo app installed you will find the required data on
https://{your nextcloud}/settings/admin/serverinfo - collect anonymized system report using
https://{your nextcloud}/settings/admin/support
| Nextcloud version (eg, 26.0.1): | 2.5.0.5040 |
| Operating system and version (eg, Ubuntu 22.04): | Windows 11 |
| Apache or nginx version (eg, Apache 2.4.25): | replace me |
| PHP version (eg, 8.1): | replace me |
| Database (sqlite or MariaDB or Postgres) | replace me |
| Docker (compose) | |
| Snap | |
| Is this the first time you’ve seen this error? | yes |
- Steps to replicate it:
- Launch Virtual Drive
- Virtual Drive will map the drive as X: Drive and can navigate
- After few navigation error came up "X:(Folder Name) is unavailable …
- The output of your Nextcloud log in Admin > Logging:
PASTE HERE
- The output of your config.php file in
/path/to/nextcloud**
(usehttps://.../settings/admin/supportwhich auto-removes identifying information!):
PASTE HERE
- for Docker/Podman list environment variables ( run “
docker inspect {container name}”)**
PASTE HERE
- The output of your Apache/nginx/system log in
/var/log/____: - For Docker/Podman post STDOUT of the container (run
docker logs {container name})
PASTE HERE
- errors in nextcloud.log in /var/www/ or as admin user in top right menu, filtering for errors.
PASTE HERE
We still neither know the version of the client nor the server.
Docker/NCP whatever version?
Logs still would be helpful as well.
