Using ownyourbits / nextcloudpi-arm64: latest running nextcloudpi docker speed is very slow, how to optimize
According to the document installation, all with the default configuration
Hi @blxw987_bao,
You are missing the required support template. Please fill this form out and edit into your post.
Please also confirm your hardware setup.
This will give us technical info and logs needed to help you! Thanks.
pi4,arm64,RAM 8M ,EMMC 32M
network speed 5.27MB/s
SATA USB3.0
user less than 10
not use office suite
‣ You should run Lets Encrypt for trusted encrypted access
‣ You should open your ports for Lets Encrypt and external access
NextcloudPi version | v1.51.0 |
NextcloudPi image | NextcloudPi_docker_01-22-23 |
OS | Debian GNU/Linux 11. 5.10.92-v8 (aarch64) |
automount | no |
USB devices | none |
datadir | /data/ncdata/data |
data in SD | yes |
data filesystem | ext2/ext3 |
data disk usage | 18G/27G |
rootfs usage | 18G/27G |
swapfile | none |
dbdir | /data/database |
Nextcloud check | ok |
Nextcloud version | 25.0.3.2 |
HTTPD service | up |
PHP service | up |
MariaDB service | up |
Redis service | up |
HPB service | up |
Postfix service | up |
Internet check | ok |
Public IPv4 | 123.126.82.8 |
Public IPv6 | not found |
Port 80 | closed |
Port 443 | closed |
IP | 172.17.0.7 |
Gateway | 172.17.0.1 |
Interface | eth0 |
Certificates | none |
NAT loopback | no |
Uptime | 2days |
