Dear all,
I want to use the fritzbox NAS as a external storage with ftps in my nc. I can access the fritzbox NAS over a normal ftp application, but when it’s coming to the nc, the nc always fails. Using not secure ftp is going very well. I think it is a problem with the self-signed certificate from the fritz box. Is there a way to import the self-signed certificate into the nc. In the docu there is only a link to an article from 2014.
Not directly related with Nextcloud. Check how to import ssl certs on an linux host to establish trusted connections. The web is full of content about this.
Sorry for not mentioning the version. I use nc 14.04 on apache2 with mariadb on a raspberrypi with raspian.
I see you choose sftp. Is it not a complete different protocol to ftps?
For those who have still the same problem: I finally find a solution:
Just import the certificate from the fritzbox into linux (If you installed Nextcloud e.g. on a vServer like i did)
Copy your CA to “dir /usr/local/share/ca-certificates/”
1.1 Use command: “sudo cp foo.crt /usr/local/share/ca-certificates/foo.crt”
Update the CA store: “sudo update-ca-certificates”
EDIT:
Yeah so you can add the external storage now, but as soon as I want to connect to it, it seems that the FTP-Server of the fritzbox is crashing, because I cant connect for a few seconds from whatever device i try
