Upgrade problem with Nextcloud docker compose setup with Caddy (2024)
Great tutorial!
However, changing NEXTCLOUD_VERSION=29.0.8-fpm to 30.0.05-fpm gives me a Error code: 502 Bad Gateway
Reverting to 29.0.16 restores my nextcloud
Things go south once yone start using a Nextcloud version above 29.
(so 30.0-fpm does not work, neither 31.0.5-fpm but 29.0.16 does) (https://hub.docker.com/_/nextcloud)
What is the proper way to upgrade to Nextcloud Hub 10 ?
Thnx!
please use search it has been discussed often!
Docker upgrade procedure
Hi Willie.
I have read this but somehow this fails.
Changing the .env from this tutorial leads to another docker image being downloaded and subsequently the error if the NEXTCLOUD_VERSION exceeds 29.
I split you topic to a separate issue and kindly ask to provide all details as required per support template especially logs
this is how it works.
This topic was automatically closed after 89 days. New replies are no longer allowed.
