Updated Collabora, container starts but later stops
I’ve had Collabora running fine for a little over a week. It’s running as a separate container alongside Nextcloud on an unRAID server.
Today there was an update to the docker (I’m assuming to 24.04.7.1.1), but now the container will start and the logs will fill with this sort of reporting over and over:
wsd-00001-00001 2024-08-30 14:15:59.800151 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00001 2024-08-30 14:16:19.800317 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00001 2024-08-30 14:16:39.800451 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00001 2024-08-30 14:16:59.800536 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00025 2024-08-30 14:16:04.101080 -0400 [ prisoner_poll ] TRC #15: Handling poll events of prisoner_poll at index 0 (of 1): 0x0| net/Socket.cpp:558
wsd-00001-00025 2024-08-30 14:16:04.101084 -0400 [ prisoner_poll ] TRC #15: setupPollFds getPollEvents: 0x1| net/Socket.hpp:880
wsd-00001-00025 2024-08-30 14:16:04.101086 -0400 [ prisoner_poll ] TRC ppoll start, timeoutMicroS: 64000000 size 1| net/Socket.cpp:430
wsd-00001-00025 2024-08-30 14:17:08.164843 -0400 [ prisoner_poll ] TRC Poll completed with 0 live polls max (64000000us)(timedout)| net/Socket.cpp:448
wsd-00001-00001 2024-08-30 14:17:19.800717 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00001 2024-08-30 14:17:39.800905 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00025 2024-08-30 14:17:08.164912 -0400 [ prisoner_poll ] TRC #15: Handling poll events of prisoner_poll at index 0 (of 1): 0x0| net/Socket.cpp:558
wsd-00001-00025 2024-08-30 14:17:08.164929 -0400 [ prisoner_poll ] TRC #15: setupPollFds getPollEvents: 0x1| net/Socket.hpp:880
wsd-00001-00025 2024-08-30 14:17:08.164940 -0400 [ prisoner_poll ] TRC ppoll start, timeoutMicroS: 64000000 size 1| net/Socket.cpp:430
wsd-00001-00025 2024-08-30 14:18:12.229093 -0400 [ prisoner_poll ] TRC Poll completed with 0 live polls max (64000000us)(timedout)| net/Socket.cpp:448
wsd-00001-00001 2024-08-30 14:17:59.801029 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
wsd-00001-00001 2024-08-30 14:18:19.801206 -0400 [ coolwsd ] INF Waiting for a new child for a max of 20000ms| wsd/COOLWSD.cpp:4421
And finally exits with these lines:
  • wsd-00001-00001 2024-08-30 13:53:54.590839 -0400 [ coolwsd ] TRC Have 0 new children.| wsd/COOLWSD.cpp:4430
  • 08/30/202401:53:54 PM
No child process could be created. Exiting.
wsd-00001-00001 2024-08-30 13:53:54.590883 -0400 [ coolwsd ] FTL No child process could be created. Exiting.| wsd/COOLWSD.cpp:4436
Forced Exit with code: 70
wsd-00001-00001 2024-08-30 13:53:54.590889 -0400 [ coolwsd ] FTL Forced Exit with code: 70| common/Util.cpp:817
I also see these errors in the logs:
  • frk-00026-00026 2024-08-30 14:09:39.799065 -0400 [ coolforkit-caps ] ERR Capability cap_sys_chroot is not set for the coolforkit program.| kit/ForKit.cpp:230
  • 08/30/202402:09:39 PM
frk-00026-00026 2024-08-30 14:09:39.799067 -0400 [ coolforkit-caps ] ERR Capability cap_fowner is not set for the coolforkit program.| kit/ForKit.cpp:230
frk-00026-00026 2024-08-30 14:09:39.799068 -0400 [ coolforkit-caps ] ERR Capability cap_chown is not set for the coolforkit program.| kit/ForKit.cpp:230
Capabilities are not set for the coolforkit program.
frk-00026-00026 2024-08-30 14:09:39.799070 -0400 [ coolforkit-caps ] FTL Capabilities are not set for the coolforkit program.| kit/ForKit.cpp:780
Please make sure that the current partition was not mounted with the ā€˜nosuid’ option.
frk-00026-00026 2024-08-30 14:09:39.799072 -0400 [ coolforkit-caps ] FTL Please make sure that the current partition was not mounted with the ā€˜nosuid’ option.| kit/ForKit.cpp:781
If you are on SLES11, please set ā€˜file_caps=1’ as kernel boot option.
coolforkit version details: 24.04.7.1 - 61cf2b4
frk-00026-00026 2024-08-30 14:09:39.799075 -0400 [ coolforkit-caps ] FTL If you are on SLES11, please set ā€˜file_caps=1’ as kernel boot option.| kit/ForKit.cpp:782
Any idea what I need to do?
Plus one here
I updated today to the latest version and Collab Office isn’t working anymore. Something broken in the last release?
ConnectException
cURL error 28: Operation timed out after 5000 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://<myhosturl>/hosting/discovery
Failed to fetch discovery: cURL error 28: Operation timed out after 5000 milliseconds with 0 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://<myhosturl>/hosting/discovery
Is there anything I need to adjust in my config now (again)?
I rolled back to 24.04.6.2.1 for now which works as intended.
Same issue for me :
wsd-00001-00001 2024-08-31 14:11:09.475670 +0200 [ coolwsd ] ERR  enterMountingNS, unshare failed: Operation not permitted| common/JailUtil.cpp:69
wsd-00001-00001 2024-08-31 14:11:09.475703 +0200 [ coolwsd ] ERR  creating usernamespace for mount user failed.| wsd/COOLWSD.cpp:1971
wsd-00001-00001 2024-08-31 14:11:09.478246 +0200 [ coolwsd ] ERR  Failed to bind-mount [/opt/cool/systemplate] -> [/opt/cool/child-roots/1-2e33d82b/cool_test_mount]| common/JailUtil.cpp:154
wsd-00001-00001 2024-08-31 14:11:09.478264 +0200 [ coolwsd ] ERR  Bind-Mounting fails and will be disabled for this run. To disable permanently set mount_jail_tree config entry in coolwsd.xml to false.| common/JailUtil.cpp:423
wsd-00001-00001 2024-08-31 14:11:09.478505 +0200 [ coolwsd ] DBG  FileServerRoot before config: | wsd/COOLWSD.cpp:2650
wsd-00001-00001 2024-08-31 14:11:09.478524 +0200 [ coolwsd ] DBG  FileServerRoot after config: /usr/share/coolwsd| wsd/COOLWSD.cpp:2652
wsd-00001-00001 2024-08-31 14:11:09.482149 +0200 [ coolwsd ] TRC  Initialize FileServerRequestHandler| wsd/COOLWSD.cpp:2946
wsd-00001-00001 2024-08-31 14:11:09.581792 +0200 [ coolwsd ] TRC  Pre-read 793 file(s) from directory: /usr/share/coolwsd/browser/dist/images/dark: lc_transformdialog.svg lc_scalignmentpropertypanel.svg lc_setoptimalcolumnwidth.svg lc_setminimalrowheight.svg lc_searchnext.svg lc_symbolshapes.puzzle.svg lc_selectheight.svg lc_numberformatstandard.svg lc_collapsenotebookbar.svg lc_downloadas-rtf.svg lc_setobjecttoforeground.svg lc_spacing.svg lc_fontworkshapetype.svg lc_connectorarrows.svg lc_fold.svg lc_symbolshapes.right-bracket.svg lc_acceptchanges.svg lc_functiondialog.svg lc_swresnc20000.svg lc_formproperties.svg lc_linetransparency.svg lc_symbolshapes.diamond-bevel.svg lc_starshapes.star8.svg lc_downloadas-docx.svg lc_square.svg lc_linepropertypanel.svg lc_arrowshapes.left-arrow.svg lc_insertaxistitle.svg lc_updatecurindex.svg lc_arrowshapes.notched-right-arrow.svg lc_starshapes.star5.svg lc_tabledesign.svg lc_updateall.svg lc_fontworkshapetype.fontwork-curve-up.svg lc_insertdropdowncontentcontrol.svg lc_deleterows.svg lc_downloadas-odg.svg lc_hidedetail.svg lc_setred.svg lc_flowchartshapes.flowchart-delay.svg user.svg lc_connectorarrowend.svg lc_editdoc.svg lc_saveas.svg lc_runmacro.svg lc_fullscreen-presentation-toolbar-mobile.svg lc_repair.svg lc_editannotation.svg lc_selectall.svg lc_fromrow.svg lc_chapternumberingdialog.svg lc_symbolshapes.right-brace.svg lc_deletecolumns.svg lc_styleapply3fstyle3astring3dheading20126familyname3astring3dcellstyles.svg lc_distributecolumns.svg lc_backward.svg lc_forward.svg lc_orientation.svg lc_arrowshapes.left-right-arrow-callout.svg lc_undo.svg lc_outlineup.svg lc_line.svg lc_resharddisk_16.svg lc_editregion.svg lc_fontworkcharacterspacingfloater.svg lc_chart2restypexy_16.svg lc_arrowshapes.up-down-arrow-callout.svg lc_hamburger.svg lc_arrowshapes.svg lc_connectorlinesarrowend.svg lc_dia.svg lc_paralefttoright.svg lc_symbolshapes.lightning.svg lc_fontheight.svg lc_shadowed.svg lc_recalcpivottable.svg lc_prevrecord.svg lc_aligndown.svg lc_flowchartshapes.flowchart-document.svg lc_insertsection.svg lc_aftertextindent.svg lc_view.svg lc_numberformatpercent.svg lc_cellvertcenter.svg lc_fontworkshapetype.fontwork-circle-curve.svg lc_hangingindent.svg lc_remove.svg lc_hyphenation.svg lc_basicshapes.hexagon.svg lc_fontworkshapetype.fontwork-arch-left-pour.svg plus.svg lc_arrangeframemenu.svg lc_downloadas.svg lc_editheaderandfooter.svg lc_paraspacedecrease.svg lc_formularesfapopen.svg lc_formatcolumns.svg lc_symbolshapes.left-bracket.svg lc_scresnc02.svg lc_basicshapes.round-rectangle.svg lc_calloutshapes.line-callout-2.svg lc_numberformatdate.svg lc_sidebartextpanel.svg lc_hidecolumn.svg lc_cancel.svg lc_insertzwsp.svg lc_scresnc08.svg lc_hide.svg lc_arrowshapes.left-arrow-callout.svg lc_flowchartshapes.flowchart-direct-access-storage.svg lc_freezepanes.svg lc_inserttable.svg lc_belowparaspacing.svg lc_onlinehelp.svg lc_formatmenu.svg lc_hidenote.svg sc_calloutshapes.line-callout-2.svg lc_fontworksameletterheights.svg lc_sdresgraphic.svg lc_centerpara.svg lc_formatgroup.svg lc_spacepara15.svg lc_flowchartshapes.flowchart-off-page-connector.svg lc_insertcolumnsbefore.svg lc_spacepara1.svg lc_unlinkcitation.svg lc_insertsparkline.svg lc_insertpage.svg lc_fontworkshapetype.fontwork-arch-up-curve.svg lc_arrowshapes.up-right-down-arrow.svg lc_insertqrcode.svg lc_calloutshapes.svg lc_backcolor.svg lc_definedbname.svg lc_closedocmobile.svg lc_inserttimefield.svg lc_swresnc20008.svg lc_symbolshapes.flower.svg lc_save.svg lc_upsearch.svg lc_sendtoback.svg lc_hiderow.svg fr01.svg lc_pagesetup.svg lc_togglemergecells.svg lc_fontworkshapetype.fontwork-arch-up-pour.svg lc_wrapcontour.svg lc_arrowshapes.pentagon-right.svg lc_distributerows.svg lc_setoutline.svg lc_basicshapes.cube.svg lc_scresnc01.svg lc_decrementlevel.svg sc_calloutshapes.line-callout-3.svg lc_styleapply3fstyle3astring3dbad26familyname3astring3dcellstyles.svg lc_presentation.svg lc_wordcountdialog.svg lc_setgraphtransparency.svg lc_fillstyle.svg lc_arrowshapes.up-right-arrow.svg lc_slidemenu.svg lc_insertpagetitlefield.svg lc_file.svg lc_addname.svg lc_insertreferencefield.svg lc_masterslide.svg lc_lock.svg sc_alignbottom.svg lc_invertbackground.svg lc_setparagraphlanguagemenu.svg lc_contourdialog.svg fr05.svg lc_insertfilefield.svg lc_numberformatscientific.svg lc_starshapes.signet.svg lc_wraptext.svg lc_fontworkshapetype.fontwork-plain-text.svg minus.svg lc_aboveparaspacing.svg lc_square_unfilled.svg sc_wrapon.svg font.svg lc_insertpagebreak.svg lc_setanchortocell.svg lc_changesmenu.svg lc_chartelementspanel.svg lc_sdrespageobjs.svg lc_titlepagedialog.svg lc_swresnc20003.svg lc_removehyperlink.svg lc_styleapply.svg lc_formatdatalabel.svg lc_down.svg lc_chart2restypebar_16.svg lc_sortascending.svg lc_fontworkshapetype.fontwork-arch-right-curve.svg lc_pie.svg lc_scresnc07.svg lc_rightpara.svg lc_starshapes.vertical-scroll.svg lc_downloadas-pptx.svg lc_swresnc20004.svg lc_accepttrackedchangetonext.svg lc_selecttable.svg lc_connector.svg lc_downloadas-doc.svg lc_serveraudit.svg lc_calloutshapes.round-callout.svg lc_cmdsc_cut.svg lc_styleapply3fstyle3astring3ddefault26familyname3astring3dcellstyles.svg lc_wrapleft.svg lc_basicshapes.svg lc_arrowshapes.down-arrow-callout.svg lc_spellingandgrammardialog.svg sc_calloutshapes.rectangular-callout.svg symbol_SPIN_DOWN.svg lc_possizepropertypanel.svg lc_renametable.svg lc_customanimation.svg lc_outlinebullet.svg lc_behindobject.svg lc_insertsheet.svg sc_wrapoff.svg lc_insertrlm.svg lc_headerandfooter.svg lc_flowchartshapes.flowchart-data.svg lc_showcolumn.svg lc_optimizetable.svg lc_fontworkshapetype.fontwork-wave.svg lc_deletecell.svg lc_objectbackone.svg lc_styleapply3fstyle3astring3dneutral26familyname3astring3dcellstyles.svg lc_arrowshapes.up-arrow-callout.svg lc_menubar.svg lc_intersect.svg lc_rowheight.svg lc_wrapthrough.svg lc_checkbox.svg lc_symbolshapes.moon.svg lc_fontworkshapetype.fontwork-curve-down.svg lc_swresredline_tablechg.svg lc_beforeobject.svg lc_cube.svg lc_flowchartshapes.flowchart-manual-input.svg lc_connectorline.svg lc_slidechangewindow.svg lc_extrusiontoggle.svg lc_starshapes.star24.svg lc_basicshapes.ring.svg lc_datasort.svg lc_latestupdates.svg lc_flowchartshapes.flowchart-card.svg lc_fontworkshapetype.fontwork-fade-up-and-right.svg lc_spelling.svg lc_fontworkshapetype.fontwork-fade-right.svg lc_entirecell.svg lc_basicshapes.trapezoid.svg lc_deleteannotation.svg lc_goalseekdialog.svg lc_insertauthorfield.svg lc_insertdatalabel.svg lc_zoteroThesis.svg lc_zoomin.svg lc_justifypara.svg lc_pagemenu.svg lc_fullscreen-presentation.svg lc_numberformatthousands.svg lc_protect.svg lc_toggleuimode.svg lc_formataxis.svg lc_morebutton.svg lc_exportepub.svg lc_showannotations.svg lc_setanchortocellresize.svg lc_splitcell.svg lc_insertsymbol.svg lc_inserthyperlink.svg lc_reportissue.svg lc_defaultbullet.svg lc_swresnc20007.svg lc_framelinecolor.svg lc_leftpara.svg lc_menuprintranges.svg lc_arrowshapes.up-arrow.svg lc_tableinsertmenu.svg lc_movedown.svg lc_starshapes.bang.svg sc_aligntop.svg lc_sidebar.svg lc_listitem-selected.svg lc_zoomreset.svg lc_mergecells.svg lc_sidebardeck.a11ycheckdeck.svg lc_shareas.svg lc_delete.svg sc_calloutshapes.line-callout-1.svg lc_toggledarktheme.svg lc_listspropertypanel.svg lc_datafilterstandardfilter.svg lc_deletetable.svg lc_scrollbar_mobile.svg lc_chart2restypecolumn_16.svg lc_insertsheetbefore.svg lc_swresredline_inserted.svg lc_incrementindent.svg lc_symbolshapes.bracket-pair.svg lc_acceptalltrackedchanges.svg lc_wrapright.svg lc_savemodified.svg lc_verticaltext.svg lc_downloadas-ppt.svg lc_selectionlanugagedefault.svg lc_decrementindent.svg lc_wrapideal.svg lc_fontworkshapetype.fontwork-stop.svg symbol_SPIN_UP.svg lc_insertindexesentry.svg lc_fontworkshapetype.fontwork-inflate.svg lc_defaultnumbering.svg lc_insertpagefield.svg lc_substract.svg lc_calloutshapes.line-callout-3.svg lc_rejecttrackedchangetonext.svg lc_basicshapes.paper.svg lc_setgreen.svg lc_arrangemenu.svg lc_arrowshapes.quad-arrow.svg lc_flowchartshapes.flowchart-sequential-access.svg lc_feedback.svg lc_charspacing.svg lc_inserthardhyphen.svg lc_hyphenate.svg lc_swresnc20010.svg lc_bringtofront.svg lc_diagramtype.svg lc_sidebardeck.elementsdeck.svg lc_setanchortopage.svg lc_starshapes.horizontal-scroll.svg lc_deletelegend.svg lc_inserttopicfield.svg lc_connectorlinearrows.svg lc_all.svg lc_connectorlines.svg lc_insertpageheader.svg lc_insertnonbreakingspace.svg lc_view100.svg lc_insertsofthyphen.svg lc_forumhelp.svg lc_datamenu.svg lc_definename.svg lc_shadowpropertypanel.svg lc_basicshapes.cross.svg lc_addcitationnote.svg lc_fontworkshapetype.fontwork-triangle-up.svg lc_duplicatepage.svg lc_deleteaxis.svg lc_masterslidespanel.svg lc_downloadas-ods.svg lc_deleteallannotation.svg lc_setdocumentproperties.svg lc_cmdsc_deleteannotation.svg lc_renamemasterpage.svg lc_symbolshapes.left-brace.svg lc_basicshapes.circle-pie.svg lc_symbolshapes.cloud.svg lc_flowchartshapes.flowchart-stored-data.svg lc_insertgraphicremote.svg lc_insertcheckboxcontentcontrol.svg lc_deleteallnotes.svg lc_borderdialog.svg lc_objectalignright.svg lc_paperformat.svg sc_alignverticalcenter.svg lc_symbolshapes.heart.svg lc_ungroup.svg lc_insertrowsafter.svg lc_basicshapes.pentagon.svg lc_formatformmenu.svg lc_spellonline.svg lc_insertpicturecontentcontrol.svg lc_insertpagenumberfield.svg lc_insertframe.svg lc_insertcolumnbreak.svg lc_fliphorizontal.svg lc_configuredialog.svg lc_dismantle.svg lc_fontworkshapetype.fontwork-fade-up.svg lc_gallery.svg lc_square_rounded_unfilled.svg lc_starshapes.concave-star6.svg lc_arrowshapes.corner-right-arrow.svg lc_decimalplaces.svg lc_formattingmark.svg lc_flowchartshapes.flowchart-summing-junction.svg lc_redo.svg sc_wrapleft.svg lc_fontworkshapetype.fontwork-chevron-down.svg lc_alignmiddle.svg sc_calloutshapes.svg lc_setanchortochar.svg lc_backgroundcolor.svg lc_distributeselection.svg lc_arrowshapes.down-arrow.svg lc_connectorcurvearrows.svg lc_datafilterremovefilter.svg lc_graphicpropertypanel.svg lc_circle.svg lc_arrowshapes.right-arrow.svg lc_basicshapes.isosceles-triangle.svg lc_edithyperlink.svg lc_insertsheetafter.svg lc_flowchartshapes.flowchart-display.svg lc_chartareapanel.svg lc_basicshapes.round-quadrat.svg sc_calloutshapes.cloud-callout.svg lc_fontworkshapetype.fontwork-arch-down-pour.svg lc_verticalpos.svg lc_numberformatpropertypanel.svg lc_addeditbibliography.svg lc_alignbottom.svg fr07.svg lc_movesheetleft.svg lc_insertendnote.svg lc_cmdsc_deleterows.svg lc_wrapmenu.svg lc_freezepanescolumn.svg lc_ellipse.svg lc_insertmajorgrid.svg lc_presentinwindow.svg lc_basicshapes.circle.svg lc_denominatorplaces.svg lc_alignverticalcenter.svg lc_formatchartarea.svg unfold.svg lc_outlinedown.svg lc_fontworkshapetype.fontwork-circle-pour.svg sc_wrapideal.svg lc_insertpagesfield.svg lc_helpindex.svg lc_setobjecttobackground.svg lc_formatcelldialog.svg lc_basicshapes.diamond.svg sc_calloutshapes.round-callout.svg lc_datadatapilotrun.svg lc_fontworkshapetype.fontwork-triangle-down.svg lc_chart2restypearea_16.svg lc_previoustrackedchange.svg lc_arrowshapes.s-sharped-arrow.svg lc_aligntop.svg lc_symbolshapes.sun.svg lc_setbrightness.svg lc_flowchartshapes.flowchart-internal-storage.svg lc_rotation.svg lc_setblue.svg lc_deletecolumnbreak.svg lc_superscript.svg lc_showtrackedchanges.svg lc_insertrowbreak.svg lc_chart2restypecolumnline_16.svg lc_splittable.svg lc_downsearch.svg lc_setgamma.svg zoomreset.svg lc_basicshapes.can.svg lc_setanchoratchar.svg lc_insertfield.svg lc_numberformatcurrency.svg lc_shownote.svg lc_arrowshapes.circular-arrow.svg lc_wrappropertypanel.svg lc_wrapoff.svg lc_thesaurusdialog.svg lc_symbolshapes.forbidden.svg lc_aligncenter.svg lc_numberformatincdecimals.svg lc_xlinestyle.svg lc_mobile_comment_wizard.svg lc_basicshapes.block-arc.svg lc_replycomment.svg lc_fontworkshapetype.fontwork-fade-left.svg lc_chart2restypestock_16.svg lc_watermark.svg lc_subscript.svg lc_spellcheckignore.svg lc_navigator.svg lc_flowchartshapes.flowchart-predefined-process.svg lc_changebezier.svg lc_swresnc20002.svg lc_slidemasterpage.svg lc_fontworkshapetype.fontwork-arch-down-curve.svg sc_wrapcontour.svg lc_calculate.svg lc_mobile_wizard.svg lc_fontworkshapetype.fontwork-fade-up-and-left.svg lc_signature.svg lc_pageheight.svg lc_rejecttrackedchange.svg lc_footnotedialog.svg lc_alignup.svg lc_startformula.svg lc_tablenumberformatdialog.svg lc_arrowshapes.up-down-arrow.svg lc_insertfootnote.svg lc_insertfieldctrl.svg lc_basicshapes.parallelogram.svg lc_linestyle.svg lc_accepttrackedchanges.svg lc_alignvcenter.svg lc_typenet.svg lc_delbreakmenu.svg lc_connectortoolbox.svg lc_compressgraphic.svg lc_swresredline_formatted.svg lc_searchprev.svg lc_formatmajorgrid.svg lc_formatmeanvalue.svg lc_shrink.svg lc_lineendstyle.svg lc_resetdatapoint.svg lc_symbolshapes.svg lc_scresnc05.svg lc_columnwidth.svg lc_flowchartshapes.flowchart-sort.svg lc_setminimalcolumnwidth.svg lc_calloutshapes.rectangular-callout.svg lc_gradangle.svg lc_flowchartshapes.flowchart-multidocument.svg lc_contentcontrolproperties.svg lc_lastrecord.svg lc_setoptimalrowheight.svg lc_translate.svg lc_prev.svg lc_calloutshapes.line-callout-1.svg lc_showslide.svg lc_sortdescending.svg lc_basicshapes.ellipse.svg lc_datafilterhideautofilter.svg lc_deletenote.svg lc_outlineright.svg lc_rect_rounded.svg lc_leftindent.svg lc_deletemajorgrid.svg lc_objectalignleft.svg lc_insertmeanvalue.svg lc_print.svg lc_show.svg lc_insertbreak.svg lc_objectforwardone.svg lc_radiobutton.svg lc_rect_unfilled.svg lc_showresolvedannotations.svg lc_swresnc20005.svg lc_showrow.svg lc_insertlrm.svg lc_chart2restypebubble_16.svg lc_starshapes.star6.svg lc_formatbulletsmenu.svg lc_insertshape.svg lc_bold.svg lc_cancelformula.svg lc_chart2restypepie_16.svg lc_grow.svg lc_entirerow.svg lc_setcontrast.svg lc_stylenewbyexample.svg lc_underlinedouble.svg lc_renamedocument.svg lc_formattingmarkmenu.svg lc_autosummenu.svg lc_connectorcurve.svg sc_wraptext.svg lc_arrowshapes.split-arrow.svg lc_editstyle.svg lc_downloadas-odt.svg lc_linespacing.svg lc_charmapcontrol.svg lc_wrapon.svg lc_next.svg lc_spacepara2.svg lc_graphicdialog.svg lc_searchdialog.svg fr09.svg lc_charfontname.svg lc_paragraphdialog.svg lc_starshapes.doorplate.svg lc_swresnc20009.svg lc_insertbreakmenu.svg lc_insertcolumnsafter.svg lc_datefield.svg lc_insertcaptiondialog.svg lc_swresnc20001.svg lc_insertzwnbsp.svg lc_lb_distance.svg lc_flowchartshapes.svg lc_scresnc03.svg lc_copy.svg lc_userslistmenu.svg lc_resetattributes.svg lc_selectbackground.svg lc_italic.svg lc_styleapply3fstyle3astring3dheading20226familyname3astring3dcellstyles.svg lc_fontworkshapetype.fontwork-chevron-up.svg lc_autoformat.svg lc_swresnc20011.svg lc_fontworkpropertypanel.svg lc_basicshapes.quadrat.svg lc_arrowshapes.chevron.svg lc_spelldialog.svg lc_arrowshapes.right-arrow-callout.svg lc_charttypepanel.svg lc_symbolshapes.brace-pair.svg lc_showstatusbar.svg lc_xlinecolor.svg lc_rect.svg lc_flowchartshapes.flowchart-preparation.svg lc_formatpaintbrush.svg lc_insertcontentcontrol.svg lc_pageformatdialog.svg lc_closemasterview.svg lc_insertcolumnsmenu.svg lc_calloutshapes.cloud-callout.svg lc_sdresobjects.svg lc_flipvertical.svg lc_inserttitlefield.svg lc_swresredline_deleted.svg lc_zoomout.svg lc_connectorcurvearrowend.svg lc_cellverttop.svg lc_fontworkshapetype.fontwork-slant-down.svg lc_controlcodes.svg lc_hideslide.svg lc_insertminorgrid.svg lc_selectwidth.svg lc_insertauthoritiesentry.svg lc_group.svg lc_validation.svg lc_swwrappropertypanel.svg lc_leadingzeroes.svg lc_spellcheckignoreall.svg lc_sdresole.svg lc_scresnc06.svg lc_keyboardshortcuts.svg lc_flowchartshapes.flowchart-terminator.svg lc_pagewidth.svg lc_linewidth.svg lc_downloadas-odp.svg lc_paste.svg lc_movesheetright.svg lc_moveup.svg lc_warn-copy-paste.svg lc_leavegroup.svg fr06.svg lc_insertbookmark.svg lc_basicshapes.rectangle.svg lc_cmdsc_paste.svg lc_fontworkshapetype.fontwork-open-circle-curve.svg lc_swresredline_fmtcollset.svg lc_zoteroBook.svg lc_wrapanchoronly.svg lc_insertion_mobile_wizard.svg lc_combine.svg lc_zoteroJournalArticle.svg lc_flowchartshapes.flowchart-or.svg lc_viewcomment.svg lc_fillcolor.svg lc_arrowshapes.quad-arrow-callout.svg lc_insertrowsbefore.svg lc_swresnc20006.svg lc_symbolshapes.octagon-bevel.svg lc_accepttrackedchange.svg lc_deletepivottable.svg lc_tablemenu.svg lc_dbquerypropertiesdialog.svg lc_formatline.svg lc_insertmultiindex.svg lc_fontworkshapetype.fontwork-open-circle-pour.svg lc_conditionalformatmenu.svg fr03.svg lc_rev-history.svg lc_setdefault.svg lc_setanchortopara.svg lc_downloadas-csv.svg lc_setselectionlanguagemenu.svg lc_incrementlevel.svg lc_cellvertbottom.svg sc_recsearch.svg sc_wrapright.svg lc_arrowshapes.up-right-arrow-callout.svg lc_fontdialog.svg lc_flowchartshapes.flowchart-punched-tape.svg lc_starshapes.star12.svg fr011.svg lc_swresnc20013.svg lc_merge.svg lc_rotateleft.svg lc_fontworkshapetype.fontwork-arch-left-curve.svg lc_checkboxoff.svg lc_tabledialog.svg lc_strikeout.svg lc_formatlegend.svg lc_connectorlinearrowend.svg lc_pararighttoleft.svg lc_fontworkshapetype.fontwork-fade-down.svg lc_anchormenu.svg fr02.svg lc_nexttrackedchange.svg lc_beforetextindent.svg lc_about.svg fr010.svg lc_menu20statistic.svg lc_basicshapes.frame.svg lc_showruler.svg lc_firstlineindent.svg lc_styleapply3fstyle3astring3dgood26familyname3astring3dcellstyles.svg lc_ok.svg lc_parapropertypanel.svg lc_downloadas-xlsx.svg lc_linenumberingdialog.svg lc_autosum.svg lc_unsetcellsreadonly.svg lc_recsearch.svg lc_deletedatalabel.svg lc_copyhyperlinklocation.svg lc_togglea11ystate.svg lc_insertobjectstarmath.svg lc_setborderstyle.svg sc_wrapthrough.svg lc_fontcolor.svg lc_animationobjects.svg lc_arrowshapes.split-round-arrow.svg lc_insertrowsmenu.svg lc_nextrecord.svg lc_wrapthroughtransparencytoggle.svg lc_horizontalpos.svg lc_symbolshapes.quad-bevel.svg lc_fontworkalignmentfloater.svg lc_flowchartshapes.flowchart-collate.svg lc_insertgraphic.svg lc_chart2restypenet_16.svg lc_text.svg lc_overline.svg lc_cut.svg lc_entirecolumn.svg lc_languagemenu.svg fr08.svg lc_underline.svg lc_chart2restypepointline_16.svg lc_freezepanesrow.svg lc_datafilterspecialfilter.svg lc_basicshapes.octagon.svg lc_sb_softedge_radius.svg lc_color.svg lc_numberformattime.svg lc_paraspaceincrease.svg lc_datafilterautofilter.svg lc_flowchartshapes.flowchart-decision.svg lc_pagedialog.svg lc_arrowshapes.striped-right-arrow.svg lc_themedialog.svg lc_downloadas-xls.svg lc_scnumberformatpropertypanel.svg lc_drawchart.svg lc_styleupdatebyexample.svg lc_insertpagecountfield.svg lc_rotateright.svg lc_swresnc20012.svg lc_trackchanges.svg lc_outlineleft.svg lc_numberformatdecdecimals.svg lc_deletepage.svg lc_numberformatdecimal.svg lc_insertcell.svg lc_fontworkshapetype.fontwork-slant-up.svg lc_starshapes.star4.svg lc_starshapes.svg lc_rejectalltrackedchanges.svg lc_sheetmenu.svg lc_firstrecord.svg lc_showdetail.svg lc_basicshapes.right-triangle.svg fr012.svg lc_alignmentpropertypanel.svg lc_removebullets.svg lc_fontworkshapetype.fontwork-arch-right-pour.svg lc_exportpdf.svg lc_entergroup.svg fr04.svg lc_toolprotectiondocument.svg lc_fullscreen.svg lc_up.svg lc_insertpagefooter.svg lc_scresnc04.svg lc_currencyfield.svg | wsd/FileServer.cpp:928
wsd-00001-00001 2024-08-31 14:11:09.754195 +0200 [ coolwsd ] TRC  Pre-read 1132 file(s) from directory: /usr/share/coolwsd/browser/dist/images: lc_transformdialog.svg icon-set-colorarrows-same.svg lc_setoptimalcolumnwidth.svg lc_setminimalrowheight.svg icon-set-symbols1-cross.svg lc_searchnext.svg lc_ressx03250.svg stacksteppedlines_52x60.svg lc_symbolshapes.puzzle.svg columnpercent_52x60.svg barstack3d_52x60.svg lc_selectheight.svg closedoc.svg lc_numberformatstandard.svg icon-set-bars-one-quarter.svg conestack_52x60.svg icon-set-shapes-diamond.svg lc_collapsenotebookbar.svg lc_downloadas-rtf.svg lc_setobjecttoforeground.svg lc_spacing.svg lc_fontworkshapetype.svg lc_connectorarrows.svg lc_formularesfaperror.svg lc_fold.svg lc_symbolshapes.right-bracket.svg lc_acceptchanges.svg lc_functiondialog.svg lc_swresnc20000.svg lc_formproperties.svg lc_linetransparency.svg lc_symbolshapes.diamond-bevel.svg lc_conditionalformatdialog_branding.svg databar-set-03.png lc_starshapes.star8.svg lc_downloadas-docx.svg typecolumn_16.svg lc_square.svg lc_arrowshapes.left-arrow.svg valueaxisdirectboth_52x60.svg lc_insertaxistitle.svg nostacksmooth3d_52x60.svg lc_updatecurindex.svg ui-bg_gloss-wave_35_f6a828_500x100.png lc_arrowshapes.notched-right-arrow.svg lc_starshapes.star5.svg netfill_52x60.svg lc_tabledesign.svg lc_updateall.svg lc_fontworkshapetype.fontwork-curve-up.svg stacksteppedpoints_52x60.svg lc_insertdropdowncontentcontrol.svg lc_deleterows.svg areaspiled_52x60.svg lc_downloadas-odg.svg lc_lb_glow_radius.svg lc_hidedetail.svg lc_setred.svg icon-set-circles1-yellow.svg columnstack3d_52x60.svg layout_head03a.svg lc_flowchartshapes.flowchart-delay.svg scale-set-02.png user.svg lc_connectorarrowend.svg errorright_30.svg lc_editdoc.svg lc_saveas.svg lc_runmacro.svg lc_fullscreen-presentation-toolbar-mobile.svg lc_repair.svg lc_drawchart_branding.svg lc_editannotation.svg lc_selectall.svg lc_svxressh03.svg lc_fromrow.svg netpoint_52x60.svg pyraminddeep_52x60.svg lc_chapternumberingdialog.svg lc_symbolshapes.right-brace.svg lc_deletecolumns.svg lc_styleapply3fstyle3astring3dheading20126familyname3astring3dcellstyles.svg lc_distributecolumns.svg lc_inserttable_row_mono.svg lc_backward.svg lc_forward.svg lc_orientation.svg bar_52x60.svg lc_arrowshapes.left-right-arrow-callout.svg lc_undo.svg barpercent3d_52x60.svg lc_line.svg lc_resharddisk_16.svg lc_editregion.svg stackdirectboth_52x60.svg lc_chart2restypexy_16.svg lc_arrowshapes.up-down-arrow-callout.svg lc_hamburger.svg lc_arrowshapes.svg lc_connectorlinesarrowend.svg ui-icons_222222_256x240.png layout_textonly.svg conepercent_52x60.svg lc_dia.svg lc_paralefttoright.svg lc_symbolshapes.lightning.svg lc_fontheight.svg lc_shadowed.svg lc_recalcpivottable.svg netlinepointstack_52x60.svg icon-set-colorarrows-slightly-down.svg marker-shadow.png lc_prevrecord.svg lc_aligndown.svg ui-bg_diagonals-thick_20_666666_40x40.png lc_flowchartshapes.flowchart-document.svg lc_insertsection.svg lc_aftertextindent.svg lc_view.svg stackstepped3d_52x60.svg lc_numberformatpercent.svg columns_52x60.svg sc_beforetextindent.svg lc_fontworkshapetype.fontwork-circle-curve.svg lc_hangingindent.svg lc_remove.svg stacksteppedboth_52x60.svg barstack_52x60.svg lc_basicshapes.hexagon.svg lc_fontworkshapetype.fontwork-arch-left-pour.svg plus.svg stackdirectpoints_52x60.svg cylinderhoriprocent_52x60.svg ui-icons_ffd27a_256x240.png errorleft_30.svg lc_downloadas.svg stackdirect3d_52x60.svg pie3d_52x60.svg lc_paraspacedecrease.svg lc_formularesfapopen.svg valueaxissteppedlines_52x60.svg lc_formatcolumns.svg lc_symbolshapes.left-bracket.svg lc_scresnc02.svg lc_basicshapes.round-rectangle.svg lc_calloutshapes.line-callout-2.svg lc_numberformatdate.svg lc_sidebartextpanel.svg lc_normalmultipanegui.svg lc_ok_white.svg tabstop-left.svg checkbox-off-disabled.svg lc_hidecolumn.svg indentation_marker_down_branding.svg lc_cancel.svg lc_insertzwsp.svg lc_scresnc08.svg lc_hide.svg lc_arrowshapes.left-arrow-callout.svg lc_flowchartshapes.flowchart-direct-access-storage.svg nostacksteppedlines_52x60.svg conehori_52x60.svg lc_freezepanes.svg lc_inserttable.svg lc_belowparaspacing.svg cylinderpercent_52x60.svg icon-set-pies-three-quarters.svg lc_onlinehelp.svg lc_formatmenu.svg lc_hidenote.svg sc_calloutshapes.line-callout-2.svg lc_fontworksameletterheights.svg lc_sdresgraphic.svg lc_centerpara.svg netpointstack_52x60.svg lc_formatgroup.svg errorup_30.svg step_center_x_30.svg lc_flowchartshapes.flowchart-off-page-connector.svg lc_insertcolumnsbefore.svg donut_52x60.svg lc_spacepara1.svg tabstop-center.svg symbol_ARROW_RIGHT.svg lc_unlinkcitation.svg ui-bg_highlight-soft_75_ffe45c_1x100.png databar-set-07.png lc_insertsparkline.svg errorbothhori_30.svg lc_insertpage.svg lc_fontworkshapetype.fontwork-arch-up-curve.svg step_start_30.svg lc_arrowshapes.up-right-down-arrow.svg lc_insertqrcode.svg reglin.svg lc_calloutshapes.svg user.png valueaxissmoothlines_52x60.svg ui-icons_777620_256x240.png lc_backcolor.svg lc_definedbname.svg lc_closedocmobile.svg radio-on-disabled.svg lc_inserttimefield.svg lc_swresnc20008.svg radio-off.svg lc_inserttable_col_mono.svg lc_symbolshapes.flower.svg lc_save.svg lc_upsearch.svg lc_sendtoback.svg lc_hiderow.svg fr01.svg lc_pagesetup.svg lc_togglemergecells.svg lc_fontworkshapetype.fontwork-arch-up-pour.svg conehoripercent_52x60.svg lc_wrapcontour.svg lc_arrowshapes.pentagon-right.svg lc_distributerows.svg lc_setoutline.svg lc_basicshapes.cube.svg lc_scresnc01.svg lc_insertpage_branding.svg nostacksteppedboth_52x60.svg typepie_16.svg sc_calloutshapes.line-callout-3.svg lc_resim30820.svg scroll-double-dark.svg lc_styleapply3fstyle3astring3dbad26familyname3astring3dcellstyles.svg lc_presentation.svg lc_wordcountdialog.svg lc_setgraphtransparency.svg lc_fillstyle.svg lc_arrowshapes.up-right-arrow.svg ui-icons_777777_256x240.png layout_head03b.svg ui-icons_cc0000_256x240.png lc_inserttable_branding.svg databar-set-01.png lc_slidemenu.svg lc_insertpagetitlefield.svg lc_diagup.svg lc_file.svg regpoly.svg lc_addname.svg pie3dexploded_52x60.svg lc_bottom.svg lc_insertreferencefield.svg icon-set-pies-full.svg lc_masterslide.svg lc_menu_downloadas_pdf_branding.svg lc_lock.svg sc_alignbottom.svg donut3dexploded_52x60.svg ui-bg_glass_65_ffffff_1x400.png edit_branding.svg stockcolumnsattach_52x60.svg lc_contourdialog.svg fr05.svg lc_insertfilefield.svg lc_numberformatscientific.svg lc_starshapes.signet.svg lc_wraptext.svg lc_fontworkshapetype.fontwork-plain-text.svg icon-set-circles2-dark-red.svg minus.svg lc_aboveparaspacing.svg lc_square_unfilled.svg icon-set-circles2-dark-gray.svg sc_wrapon.svg lc_insertpagebreak.svg lc_setanchortocell.svg lc_changesmenu.svg scale-set-03.png lc_chartelementspanel.svg lc_sdrespageobjs.svg lc_togglewasm.svg lc_titlepagedialog.svg lc_nextrecord_branding.svg lc_swresnc20003.svg layout_vertical02.svg lc_removehyperlink.svg lc_styleapply.svg baseline-edit-24px.svg regexp.svg valueaxisdirectlines_52x60.svg valueaxisstepped3d_52x60.svg lc_formatdatalabel.svg lc_down.svg lc_chart2restypebar_16.svg lc_sortascending.svg lc_fontworkshapetype.fontwork-arch-right-curve.svg lc_pie.svg lc_scresnc07.svg lc_rightpara.svg lc_starshapes.vertical-scroll.svg cell-resize-marker.svg stockblock_52x60.svg lc_downloadas-html.svg lc_downloadas-pptx.svg lc_swresnc20004.svg lc_accepttrackedchangetonext.svg lc_selecttable.svg lc_connector.svg icon-set-triangles-up.svg spritesheet.png lc_downpage_branding.svg lc_downloadas-doc.svg lc_serveraudit.svg lc_formularesfx.svg icon-set-pies-half.svg lc_svxrespr03.svg lc_calloutshapes.round-callout.svg stacksmooth3d_52x60.svg lc_cmdsc_cut.svg lc_wrapleft.svg cylinder_52x60.svg lc_basicshapes.svg lc_arrowshapes.down-arrow-callout.svg radio-off-disabled.svg sc_calloutshapes.rectangular-callout.svg symbol_SPIN_DOWN.svg lc_left.svg lc_possizepropertypanel.svg lc_renametable.svg lc_customanimation.svg lc_outlinebullet.svg lc_behindobject.svg lc_insertsheet.svg pyramindhori_52x60.svg sc_wrapoff.svg lc_insertrlm.svg lc_headerandfooter.svg lc_flowchartshapes.flowchart-data.svg lc_showcolumn.svg icon-set-symbols1-check.svg lc_selectionlanugagenone.svg lc_optimizetable.svg lc_fontworkshapetype.fontwork-wave.svg lc_deletecell.svg sidebar-template-large.svg lc_styleapply3fstyle3astring3dneutral26familyname3astring3dcellstyles.svg lc_arrowshapes.up-arrow-callout.svg table-column-resize-marker.svg lc_menubar.svg lc_intersect.svg layout_head03.svg lc_rowheight.svg close-widget.svg lc_wrapthrough.svg lc_checkbox.svg layout_head02a.svg lc_symbolshapes.moon.svg lc_fontworkshapetype.fontwork-curve-down.svg lc_swresredline_tablechg.svg lc_beforeobject.svg conehorideep_52x60.svg pie_52x60.svg lc_cube.svg lc_flowchartshapes.flowchart-manual-input.svg sign_ok.svg lc_connectorline.svg x-office-drawing.svg lc_slidechangewindow.svg icon-set-stars-half.svg lc_extrusiontoggle.svg layout_head02b.svg icon-set-flags-green.svg lc_starshapes.star24.svg x-office-document.svg lc_basicshapes.ring.svg lc_datasort.svg lc_latestupdates.svg lc_flowchartshapes.flowchart-card.svg icon-set-pies-empty.svg lc_fontworkshapetype.fontwork-fade-up-and-right.svg lc_spelling.svg lc_fontworkshapetype.fontwork-fade-right.svg nostackdirect3d_52x60.svg valueaxisdirect3d_52x60.svg lc_entirecell.svg table-row-resize-marker.svg lc_basicshapes.trapezoid.svg lc_showannotations_branding.svg lc_inserthyperlink_branding.svg valueaxisdirectpoints_52x60.svg lc_firstrecord_branding.svg lc_goalseekdialog.svg lc_insertauthorfield.svg lc_insertdatalabel.svg lc_zoteroThesis.svg icon-set-symbols1-exclamation-mark.svg pyramindstack_52x60.svg lc_zoomin.svg lc_justifypara.svg lc_pagemenu.svg lc_fullscreen-presentation.svg ui-bg_glass_100_f6f6f6_1x400.png lc_numberformatthousands.svg lc_protect.svg typearea_16.svg lc_toggleuimode.svg icon-set-bars-full.svg lc_formataxis.svg lc_morebutton.svg sc_firstlineindent.svg typexy_16.svg lc_exportepub.svg lc_showannotations.svg icon-set-trafficlights-red.svg lc_setanchortocellresize.svg lc_splitcell.svg lc_helpindex_secondary.svg lc_numberformatpercent_branding.svg lc_insertsymbol.svg lc_topbottom.svg lc_inserthyperlink.svg lc_reportissue.svg lc_defaultbullet.svg lc_swresnc20007.svg lc_framelinecolor.svg lc_leftpara.svg lc_menuprintranges.svg lc_arrowshapes.up-arrow.svg lc_tableinsertmenu.svg lc_movedown.svg lc_starshapes.bang.svg lock-illustration.svg table-column-resize-marker-hover_branding.svg sc_aligntop.svg netstack_52x60.svg lc_sidebar.svg lc_listitem-selected.svg lc_zoomreset.svg lc_mergecells.svg lc_sidebardeck.a11ycheckdeck.svg lc_shareas.svg plus_branding.svg lc_delete.svg sc_calloutshapes.line-callout-1.svg lc_toggledarktheme.svg lc_top.svg icon-set-colorarrows-up.svg sc26049.png lc_datafilterstandardfilter.svg lc_deletetable.svg netstackfill_52x60.svg lc_scrollbar_mobile.svg lc_chart2restypecolumn_16.svg lc_insertsheetbefore.svg donut3d_52x60.svg lc_swresredline_inserted.svg icon-set-trafficlights-green.svg symbol_ARROW_UP.svg handle_start.svg fit-cell_branding.svg indentation_marker_up.svg lc_symbolshapes.bracket-pair.svg lc_acceptalltrackedchanges.svg lc_wrapright.svg lc_serverauditerror.svg lc_savemodified.svg layout_empty.svg lc_verticaltext.svg lc_downloadas-ppt.svg lc_decrementindent.svg lc_formularesfapok.svg lc_wrapideal.svg lc_fontworkshapetype.fontwork-stop.svg symbol_SPIN_UP.svg ios_handle_end.svg lc_fontworkshapetype.fontwork-inflate.svg layers.png lc_defaultnumbering.svg lc_insertpagefield.svg lc_substract.svg icon-set-grayarrows-slightly-down.svg lc_menu_chevron.svg layout_head06.svg lc_calloutshapes.line-callout-3.svg lc_rejecttrackedchangetonext.svg lc_basicshapes.paper.svg icon-set-bars-empty.svg lc_setgreen.svg lc_arrangemenu.svg lc_arrowshapes.quad-arrow.svg lc_flowchartshapes.flowchart-sequential-access.svg marker-icon-2x.png lc_leftright.svg lc_feedback.svg lc_inserthardhyphen.svg scale-set-09.png lc_hyphenate.svg lc_swresnc20010.svg lc_diagramtype.svg lc_sidebardeck.elementsdeck.svg lc_setanchortopage.svg indentation_marker_down.svg lc_starshapes.horizontal-scroll.svg lc_deletelegend.svg lc_inserttopicfield.svg lc_connectorlinearrows.svg lc_all.svg lc_connectorlines.svg drop-down-button.svg ui-bg_diagonals-thick_18_b81900_40x40.png lc_insertpageheader.svg toolbar-bg-logo.svg sidebar-animation-large.svg hamburger.svg lc_view100.svg lc_insertsofthyphen.svg lc_forumhelp.svg lc_datamenu.svg lc_numberformatincdecimals_branding.svg lc_definename.svg cylinderdeep_52x60.svg icon-set-squares-half.svg lc_basicshapes.cross.svg lc_addcitationnote.svg pyramindhorideep_52x60.svg x-office-spreadsheet.svg lc_fontworkshapetype.fontwork-triangle-up.svg ui-icons_ef8c08_256x240.png lc_duplicatepage.svg lc_deleteaxis.svg lc_downloadas-ods.svg baseline-edit.svg lc_setdocumentproperties.svg lc_cmdsc_deleteannotation.svg cell-autofill-marker.svg lc_renamemasterpage.svg lc_symbolshapes.left-brace.svg lc_basicshapes.circle-pie.svg scale-set-05.png ui-icons_555555_256x240.png lc_symbolshapes.cloud.svg step_end_30.svg scale-set-11.png nostacksteppedpoints_52x60.svg conehoristack_52x60.svg table-column-resize-marker-hover.svg lc_flowchartshapes.flowchart-stored-data.svg lc_insertgraphicremote.svg scale-set-10.png lc_deleteallnotes.svg lc_effectpropertypanel.svg lc_uppage_branding.svg lc_borderdialog.svg ui-bg_glass_100_fdf5ce_1x400.png step_center_y_30.svg valueaxissmooth3d_52x60.svg lc_objectalignright.svg lc_paperformat.svg sc_alignverticalcenter.svg lc_symbolshapes.heart.svg lc_ungroup.svg lc_basicshapes.pentagon.svg nostackdirectboth_52x60.svg lc_formatformmenu.svg lc_menu_zoomreset_branding.svg lc_insertpicturecontentcontrol.svg lc_insertpagenumberfield.svg lc_insertframe.svg layout_vertical01.svg icon-set-positive-green-smilie.svg lc_insertcolumnbreak.svg lc_fliphorizontal.svg stackdirectlines_52x60.svg table-row-resize-marker-hover.svg databar-set-00.png lc_dismantle.svg lc_fontworkshapetype.fontwork-fade-up.svg lc_gallery.svg lc_square_rounded_unfilled.svg reglog.svg nostacksmoothboth_52x60.svg lc_starshapes.concave-star6.svg lc_outside.svg lc_arrowshapes.corner-right-arrow.svg pieexploded_52x60.svg lc_decimalplaces.svg lc_formattingmark.svg lc_flowchartshapes.flowchart-summing-junction.svg lc_redo.svg sc_wrapleft.svg lc_fontworkshapetype.fontwork-chevron-down.svg lc_alignmiddle.svg sc_calloutshapes.svg lc_setanchortochar.svg lc_distributeselection.svg lc_arrowshapes.down-arrow.svg lc_connectorcurvearrows.svg lc_datafilterremovefilter.svg icon-set-trafficlights-yellow.svg lc_circle.svg lc_arrowshapes.right-arrow.svg icon-set-positive-yellow-smilie.svg lc_basicshapes.isosceles-triangle.svg radio-on.svg menu-share.svg lc_edithyperlink.svg lc_insertsheetafter.svg lc_flowchartshapes.flowchart-display.svg bar3ddeep_52x60.svg sc_wrapmenu.svg lc_chartareapanel.svg lc_basicshapes.round-quadrat.svg sc_calloutshapes.cloud-callout.svg icon-set-flags-yellow.svg lc_fontworkshapetype.fontwork-arch-down-pour.svg lc_verticalpos.svg lc_numberformatpropertypanel.svg lc_addeditbibliography.svg lc_alignbottom.svg fr07.svg icon-set-pies-one-quarter.svg lc_movesheetleft.svg lc_insertendnote.svg lc_cmdsc_deleterows.svg lc_wrapmenu.svg lc_freezepanescolumn.svg lc_ellipse.svg ui-bg_flat_0_aaaaaa_40x100.png icon-set-triangles-same.svg lc_insertmajorgrid.svg lc_presentinwindow.svg lc_basicshapes.circle.svg lc_denominatorplaces.svg checkbox-on-disabled.svg lc_formatchartarea.svg lc_scrolltoprevious.svg unfold.svg icon-set-circles2-light-red.svg lc_fontworkshapetype.fontwork-circle-pour.svg sc_aftertextindent.svg sc_wrapideal.svg lc_insertpagesfield.svg lc_helpindex.svg lc_setobjecttobackground.svg icon-set-negative-yellow-smilie.svg lc_formatcelldialog.svg lc_basicshapes.diamond.svg sc_calloutshapes.round-callout.svg lc_datadatapilotrun.svg lc_fontworkshapetype.fontwork-triangle-down.svg lc_chart2restypearea_16.svg refinp2.svg lc_arrowshapes.s-sharped-arrow.svg lc_aligntop.svg lc_symbolshapes.sun.svg icon-set-squares-three-quarters.svg lc_setbrightness.svg lc_flowchartshapes.flowchart-internal-storage.svg lc_rotation.svg lc_setblue.svg lc_deletecolumnbreak.svg lc_superscript.svg lc_showtrackedchanges.svg lc_setborderstyle_branding.svg lc_insertrowbreak.svg note.svg lc_chart2restypecolumnline_16.svg lc_splittable.svg lc_downsearch.svg lc_setgamma.svg zoomreset.svg lc_basicshapes.can.svg columnstackline_52x60.svg x-office-presentation.svg lc_setanchoratchar.svg icon-set-bars-half.svg areas_52x60.svg lc_insertfield.svg pyramindhoripercent_52x60.svg lc_numberformatcurrency.svg lc_shownote.svg lc_autosum_branding.svg lc_arrowshapes.circular-arrow.svg lc_topdoublebottom.svg table-row-or-column-select-marker-selected.svg icon-set-shapes-triangle.svg lc_wrappropertypanel.svg tabstop-right.svg lc_wrapoff.svg lc_thesaurusdialog.svg lc_symbolshapes.forbidden.svg lc_aligncenter.svg lc_prevrecord_branding.svg loading.gif lc_numberformatincdecimals.svg cylinderhorideep_52x60.svg nostackstepped3d_52x60.svg lc_notesmode.svg lc_mobile_comment_wizard.svg lc_basicshapes.block-arc.svg lc_replycomment.svg lc_fontworkshapetype.fontwork-fade-left.svg lc_chart2restypestock_16.svg icon-set-grayarrows-up.svg lc_watermark.svg lc_subscript.svg lc_spellcheckignore.svg lc_navigator.svg lc_flowchartshapes.flowchart-predefined-process.svg lc_changebezier.svg lc_swresnc20002.svg icon-set-neutral-yellow-smilie.svg lc_fontworkshapetype.fontwork-arch-down-curve.svg sc_wrapcontour.svg lc_calculate.svg databar-set-09.png lc_mobile_wizard.svg lc_fontworkshapetype.fontwork-fade-up-and-left.svg lc_signature.svg lc_pageheight.svg lc_rejecttrackedchange.svg lc_footnotedialog.svg lc_alignup.svg stock_52x60.svg lc_startformula.svg lc_tablenumberformatdialog.svg lc_arrowshapes.up-down-arrow.svg icon-set-shapes-circle.svg valueaxissmoothboth_52x60.svg lc_insertfootnote.svg columnstack_52x60.svg lc_basicshapes.parallelogram.svg lc_convertformulatovalue.svg refinp1.svg lc_linestyle.svg databar-set-02.png lc_alignvcenter.svg lc_right.svg lc_typenet.svg checkbox-on.svg ui-icons_ffffff_256x240.png lc_delbreakmenu.svg lc_compressgraphic.svg table-row-resize-marker_branding.svg lc_swresredline_formatted.svg areaspiled3d_52x60.svg lc_searchprev.svg lc_formatmajorgrid.svg lc_formatmeanvalue.svg lc_serverauditheader.svg lc_shrink.svg lc_lineendstyle.svg lc_resetdatapoint.svg typebubble_16.svg lc_symbolshapes.svg lc_scresnc05.svg lc_columnwidth.svg lc_flowchartshapes.flowchart-sort.svg lc_setminimalcolumnwidth.svg lc_calloutshapes.rectangular-callout.svg lc_gradangle.svg lc_ressx03249.svg lc_flowchartshapes.flowchart-multidocument.svg lc_contentcontrolproperties.svg lc_lastrecord.svg valueaxissteppedboth_52x60.svg icon-set-circles1-green.svg lc_translate.svg lc_prev.svg lc_calloutshapes.line-callout-1.svg layout_head03c.svg lc_showslide.svg lc_sortdescending.svg lc_deletepage_branding.svg cylinderhoristack_52x60.svg lc_basicshapes.ellipse.svg lc_datafilterhideautofilter.svg lc_deletenote.svg lc_outlineright.svg lc_rect_rounded.svg lc_spreadsheet_protected.svg lc_leftindent.svg lc_deletemajorgrid.svg ui-icons_228ef1_256x240.png lc_objectalignleft.svg lc_insertmeanvalue.svg icon-set-bars-three-quarters.svg lc_print.svg icon-set-circles1-red.svg lc_show.svg cylinderhori_52x60.svg lc_insertbreak.svg lc_objectforwardone.svg icon-set-squares-one-quarter.svg handle_end.svg tabstop-decimal.svg lc_radiobutton.svg layout_head02.svg errordown_30.svg lc_rect_unfilled.svg lc_showresolvedannotations.svg donutexploded_52x60.svg regpow.svg regno.svg columnpercent3d_52x60.svg lc_swresnc20005.svg lc_showrow.svg lc_insertlrm.svg scale-set-00.png lc_chart2restypebubble_16.svg lc_starshapes.star6.svg stockcolumns_52x60.svg lc_formatbulletsmenu.svg lc_insertshape.svg lc_inserttable_mono.svg sign_not_ok.svg lc_bold.svg lc_chart2restypepie_16.svg lc_grow.svg lc_setcontrast.svg lc_stylenewbyexample.svg lc_numberformatdecdecimals_branding.svg lc_underlinedouble.svg lc_renamedocument.svg lc_formattingmarkmenu.svg lc_autosummenu.svg lc_connectorcurve.svg sc_wraptext.svg lc_arrowshapes.split-arrow.svg lc_editstyle.svg lc_downloadas-odt.svg lc_linespacing.svg lc_wrapon.svg typenet_16.svg lc_next.svg lc_spacepara2.svg lc_graphicdialog.svg net_52x60.svg lc_searchdialog.svg nostackdirectlines_52x60.svg sidebar-property-large.svg fr09.svg bubble_52x60.svg lc_charfontname.svg lc_paragraphdialog.svg lc_starshapes.doorplate.svg lc_swresnc20009.svg lc_insertbreakmenu.svg pyramindhoristack_52x60.svg databar-set-06.png lc_datefield.svg lc_insertcaptiondialog.svg marker-icon.png columns3d_52x60.svg lc_swresnc20001.svg pyramindpercent_52x60.svg lc_insertzwnbsp.svg lc_lb_distance.svg lc_flowchartshapes.svg lc_scresnc03.svg lc_copy.svg icon-set-stars-full.svg lc_userslistmenu.svg lc_selectbackground.svg lc_italic.svg nostacksmoothlines_52x60.svg lc_styleapply3fstyle3astring3dheading20226familyname3astring3dcellstyles.svg lc_fontworkshapetype.fontwork-chevron-up.svg lc_ressx03255.svg lc_lb_shadow_blur.svg lc_autoformat.svg lc_swresnc20011.svg lc_fontworkpropertypanel.svg lc_basicshapes.quadrat.svg lc_arrowshapes.chevron.svg lc_spelldialog.svg icon-set-circles2-light-gray.svg lc_arrowshapes.right-arrow-callout.svg lc_scrolltonext.svg lc_symbolshapes.brace-pair.svg lc_showstatusbar.svg lc_xlinecolor.svg lc_rect.svg lc_flowchartshapes.flowchart-preparation.svg lc_formatpaintbrush.svg lc_insertcontentcontrol.svg lc_closemasterview.svg lc_insertcolumnsmenu.svg lc_calloutshapes.cloud-callout.svg lc_sdresobjects.svg lc_flipvertical.svg lc_inserttitlefield.svg lc_swresredline_deleted.svg lc_none.svg lc_zoomout.svg lc_connectorcurvearrowend.svg lc_fontworkshapetype.fontwork-slant-down.svg databar-set-05.png lc_controlcodes.svg icon-set-colorarrows-down.svg lc_hideslide.svg lc_ellipse_branding.svg lc_insertminorgrid.svg nostackdirectpoints_52x60.svg lc_selectwidth.svg lc_insertauthoritiesentry.svg lc_group.svg lc_validation.svg lc_swwrappropertypanel.svg lc_leadingzeroes.svg lc_sdresole.svg lc_scresnc06.svg lc_keyboardshortcuts.svg lc_flowchartshapes.flowchart-terminator.svg lc_diagdown.svg lc_pagewidth.svg lc_linewidth.svg scale-set-06.png lc_serverauditok.svg pyramind_52x60.svg lc_downloadas-odp.svg lc_paste.svg lc_movesheetright.svg layout_head04.svg lc_moveup.svg symbol_ARROW_LEFT.svg bar3d_52x60.svg lc_topthickbottom.svg lc_closedocmobile_branding.svg lc_warn-copy-paste.svg lc_leavegroup.svg fr06.svg areasfull_52x60.svg stacksmoothlines_52x60.svg toolbar-bg-logo-dark.svg icon-set-grayarrows-slightly-up.svg icon-set-triangles-down.svg lc_insertbookmark.svg lc_basicshapes.rectangle.svg lc_cmdsc_paste.svg typebar_16.svg icon-set-squares-full.svg lc_fontworkshapetype.fontwork-open-circle-curve.svg lc_swresredline_fmtcollset.svg lc_zoteroBook.svg lc_wrapanchoronly.svg lc_insertion_mobile_wizard.svg regavg.svg lc_combine.svg lc_zoteroJournalArticle.svg lc_flowchartshapes.flowchart-or.svg lc_viewcomment.svg lc_fillcolor.svg lc_arrowshapes.quad-arrow-callout.svg lc_insertrowsbefore.svg scale-set-01.png lc_swresnc20006.svg lc_symbolshapes.octagon-bevel.svg icon-set-grayarrows-same.svg barpercent_52x60.svg lc_deletepivottable.svg lc_tablemenu.svg lc_dbquerypropertiesdialog.svg lc_formatline.svg lc_insertmultiindex.svg sidebar-transition-large.svg lc_fontworkshapetype.fontwork-open-circle-pour.svg text-path_branding.svg lc_conditionalformatmenu.svg fr03.svg conedeep_52x60.svg lc_resim30821.svg lc_rev-history.svg lc_setdefault.svg lc_setanchortopara.svg icon-set-flags-red.svg lc_downloadas-csv.svg lc_setselectionlanguagemenu.svg lc26049.svg typestock_16.svg icon-set-negative-red-smilie.svg sc_recsearch.svg icon-set-squares-empty.svg scale-set-07.png lc_color-picker-selected.svg sc_wrapright.svg lc_arrowshapes.up-right-arrow-callout.svg lc_fontdialog.svg lc_flowchartshapes.flowchart-punched-tape.svg lc_starshapes.star12.svg fr011.svg lc_swresnc20013.svg table-move-marker.svg databar-set-11.png lc_merge.svg icon-set-stars-empty.svg lc_rotateleft.svg lc_fontworkshapetype.fontwork-arch-left-curve.svg lc_checkboxoff.svg ui-bg_highlight-soft_100_eeeeee_1x100.png lc_strikeout.svg lc_formatlegend.svg lc_connectorlinearrowend.svg lc_pararighttoleft.svg lc_fontworkshapetype.fontwork-fade-down.svg lc_anchormenu.svg icon-set-grayarrows-down.svg netlinepoint_52x60.svg checkbox-off.svg fr02.svg lc_beforetextindent.svg lc_about.svg fr010.svg lc_menu20statistic.svg lc_thickbottom.svg indentation_marker_up_branding.svg typecolumnline_16.svg lc_basicshapes.frame.svg close-widget-hover.svg lc_showruler.svg lc_firstlineindent.svg lc_styleapply3fstyle3astring3dgood26familyname3astring3dcellstyles.svg wrapoff.svg table-row-resize-marker-hover_branding.svg lc_ok.svg scale-set-04.png lc_doublebottom.svg lc_downloadas-xlsx.svg scroll-double-white.svg lc_menu_fullscreen_branding.svg cone_52x60.svg columnline_52x60.svg cursor-handler.svg ios_handle_start.svg lc_linenumberingdialog.svg lc_autosum.svg contacts-dark.svg ui-icons_444444_256x240.png spritesheet-2x.png lc_unsetcellsreadonly.svg lc_recsearch.svg lc_deletedatalabel.svg lc_copyhyperlinklocation.svg lc_togglea11ystate.svg lc_insertobjectstarmath.svg lc_setborderstyle.svg layout_head01.svg sc_wrapthrough.svg lc_fontcolor.svg lc_animationobjects.svg lc_arrowshapes.split-round-arrow.svg lc_insertrowsmenu.svg lc_nextrecord.svg lc_wrapthroughtransparencytoggle.svg lc_horizontalpos.svg lc_symbolshapes.quad-bevel.svg lc_fontworkalignmentfloater.svg lc_flowchartshapes.flowchart-collate.svg lc_insertgraphic.svg lc_chart2restypenet_16.svg lc_text.svg lc_text_branding.svg lc_overline.svg lc_cut.svg databar-set-08.png table-row-or-column-select-marker.svg lc_ressx03251.svg lc_entirecolumn.svg lc_languagemenu.svg areasfull3d_52x60.svg fr08.svg lc_underline.svg lc_chart2restypepointline_16.svg lc_freezepanesrow.svg lc_datafilterspecialfilter.svg lc_basicshapes.octagon.svg lc_sb_softedge_radius.svg symbol_ARROW_DOWN.svg lc_color.svg columns3ddeep_52x60.svg lc_numberformattime.svg lc_paraspaceincrease.svg lc_thickbox.svg lc_duplicatepage_branding.svg stacksmoothboth_52x60.svg lc_datafilterautofilter.svg submenu.svg lc_flowchartshapes.flowchart-decision.svg lc_pagedialog.svg lc_arrowshapes.striped-right-arrow.svg lc_themedialog.svg cylinderstack_52x60.svg lc_downloadas-xls.svg lc_drawchart.svg lc_styleupdatebyexample.svg lc_insertpagecountfield.svg lc_clipboard-check.svg lc_rotateright.svg areas3d_52x60.svg lc_swresnc20012.svg lc_trackchanges.svg lc_outlineleft.svg lc_numberformatdecdecimals.svg databar-set-10.png lc_deletepage.svg errorbothverti_30.svg lc_numberformatdecimal.svg lc_insertcell.svg lc_fontworkshapetype.fontwork-slant-up.svg layers-2x.png lc_starshapes.star4.svg lc_starshapes.svg lc_rejectalltrackedchanges.svg lc_sheetmenu.svg lc_firstrecord.svg scale-set-08.png lc_showdetail.svg lc_basicshapes.right-triangle.svg icon-set-circles1-gray.svg fr012.svg lc_removebullets.svg lc_fontworkshapetype.fontwork-arch-right-pour.svg lc_exportpdf.svg typepointline_16.svg lc_entergroup.svg fr04.svg lc_toolprotectiondocument.svg table-column-resize-marker_branding.svg lc_fullscreen.svg lc_up.svg lc_insertpagefooter.svg lc_scresnc04.svg lc_currencyfield.svg icon-set-colorarrows-slightly-up.svg databar-set-04.png | wsd/FileServer.cpp:928
wsd-00001-00001 2024-08-31 14:11:09.904155 +0200 [ coolwsd ] TRC  Pre-read 2 file(s) from directory: /usr/share/coolwsd/browser/dist/admin/font: Montserrat-Regular.ttf OFL.txt | wsd/FileServer.cpp:928
wsd-00001-00001 2024-08-31 14:11:10.057601 +0200 [ coolwsd ] TRC  Pre-read 129 file(s) from directory: /usr/share/coolwsd/browser/dist/l10n/uno: km.json ml.json as.json dsb.json sr-Latn.json lt.json ug.json mai.json pt.json am.json bg.json tg.json ast.json ky.json sv.json sk.json cs.json cy.json hu.json pa-IN.json xh.json en-ZA.json ru.json eo.json es-override.json mni.json ko.json si.json or.json uk.json da.json ro.json ckb.json te.json sq.json sl.json ga.json ca-valencia.json vi.json hi.json oc.json ne.json ve.json dgo.json is.json az.json eu.json es.json de-override.json hr.json kok.json gug.json el.json gu.json kk.json mr.json ss.json an.json sd.json lb.json sr.json rw.json ab.json fa.json br.json sat.json id.json nl.json fr.json bn.json ts.json dz.json th.json nso.json sa-IN.json hsb.json en-GB.json tt.json it.json kab.json om.json nb.json tn.json bn-IN.json tr.json jv.json kl.json pt-BR.json gd.json fur.json pl.json fy.json lv.json nr.json et.json sah.json zh-CN.json ka.json lo.json my.json kmr-Latn.json he.json ar.json af.json uz.json vec.json ur.json brx.json de.json ta.json st.json mk.json fi.json sw-TZ.json kn.json nn.json ca.json gl.json sid.json bs.json bo.json szl.json mn.json zh-TW.json be.json ja.json ks.json zu.json ti.json | wsd/FileServer.cpp:928
wsd-00001-00001 2024-08-31 14:11:10.341621 +0200 [ coolwsd ] TRC  Pre-read 258 file(s) from directory: /usr/share/coolwsd/browser/dist/l10n: descriptions-fy.json ui-vi.json ui-pl.json descriptions-pt.json help-ru.json descriptions-uk.json help-sq.json help-fi.json help-nn.json help-es.json descriptions-ko.json descriptions-en_ZA.json descriptions-an.json help-et.json ui-af.json help-ca.json help-sv.json help-pa_IN.json descriptions-ca@valencia.json descriptions-be.json ui-pt_BR.json ui-en_NZ.json ui-hsb.json help-is.json ui-it.json ui-si.json ui-bn.json descriptions-pt_BR.json help-gug.json ui-ar.json descriptions-hr.json help-ady.json help-ga.json ui-et.json ui-tr.json descriptions-br.json help-ab.json help-bs.json ui-sq.json descriptions-am.json uno-localizations-override.json localizations.json ui-ta.json ui-hr.json help-dsb.json help-si.json ui-uz.json descriptions-hi.json ui-en_ZA.json descriptions-af.json help-ia.json descriptions-en_NZ.json ui-dsb.json ui-ast.json ui-gl.json help-sk.json ui-en_AU.json help-zh_CN.json descriptions-tr.json ui-pt.json descriptions-nl.json help-zh_TW.json help-oc.json ui-sk.json descriptions-kn.json descriptions-kk.json descriptions-en_AU.json ui-ne.json help-or.json help-ne.json descriptions-th.json help-ar.json help-ast.json ui-be.json ui-zh_TW.json help-eo.json ui-nn.json descriptions-gd.json help-da.json help-en_NZ.json help-ja.json ui-kab.json ui-cs.json help-cy.json help-ko.json descriptions-bn.json descriptions-uz.json ui-eu.json descriptions-sl.json ui-el.json descriptions-lo.json descriptions-ne.json descriptions-el.json descriptions-hsb.json descriptions-hu.json help-mn.json descriptions-jv.json descriptions-tg.json help-pt.json ui-zh_CN.json help-uk.json ui-fr.json descriptions-ro.json help-lt.json help-nl.json help-ta.json descriptions-is.json help-he.json ui-fy.json ui-fi.json help-en_AU.json help-hi.json help-lv.json help-tr.json Makefile.am descriptions-zh_Hans.json descriptions-ru.json help-bg.json descriptions-fi.json descriptions-ug.json ui-da.json ui-is.json help-en_ZA.json ui-oc.json descriptions-nn.json descriptions-pa.json ui-de.json descriptions-zh_Hant.json ui-ca-valencia.json ui-ga.json ui-eo.json descriptions-mn.json descriptions-brx.json descriptions-cs.json help-af.json help-am.json help-fy.json help-pt_BR.json descriptions-cy.json descriptions-sq.json ui-or.json descriptions-eu.json descriptions-be_Latn.json ui-hi.json ui-ca.json descriptions-nb_NO.json ui-he.json ui-ja.json help-hu.json ui-jv.json descriptions-he.json help-de.json ui-am.json descriptions-en_GB.json descriptions-ml.json help-id.json ui-lv.json ui-ug.json descriptions-bg.json ui-cy.json help-brx.json ui-vec.json help-br.json descriptions-eo.json descriptions-bs.json help-ml.json descriptions-sk.json descriptions-fa.json ui-bs.json descriptions-dsb.json help-ro.json ui-an.json help-kk.json uno-localizations.json help-gl.json ui-ko.json help-vec.json ui-en_GB.json descriptions-sv.json help-bn.json descriptions-lt.json help-en_GB.json descriptions-bar.json ui-uk.json ui-id.json help-jv.json ui-pa_IN.json help-kab.json help-sl.json ui-ab.json help-tg.json descriptions-kab.json ui-fa.json ui-hu.json descriptions-fr.json descriptions-oc.json help-be.json descriptions-gl.json help-pl.json descriptions-ja.json ui-ro.json descriptions-ar.json descriptions-et.json descriptions-gug.json help-uz.json ui-lo.json ui-th.json ui-bg.json ui-ml.json ui-nl.json help-ug.json descriptions-ab.json admin-localizations.json help-el.json ui-bar.json ui-be_Latn.json ui-gug.json help-vi.json help-hr.json help-localizations.json descriptions-lv.json descriptions-id.json help-kn.json descriptions-vec.json ui-gd.json ui-sl.json ui-kk.json ui-nb.json descriptions-de.json help-gd.json descriptions-si.json ui-lt.json ui-br.json help-ca-valencia.json descriptions-pl.json help-eu.json help-cs.json help-fr.json descriptions-ta.json help-it.json descriptions-or.json descriptions-es.json help-be_Latn.json help-hsb.json help-fa.json Makefile.in descriptions-da.json ui-es.json descriptions-ast.json ui-ru.json descriptions-ga.json descriptions-ca.json ui-ia.json descriptions-it.json help-nb.json ui-sv.json descriptions-vi.json locore-localizations.json | wsd/FileServer.cpp:928
wsd-00001-00001 2024-08-31 14:11:10.374565 +0200 [ coolwsd ] DBG  FileServerRoot: /usr/share/coolwsd| wsd/COOLWSD.cpp:4379
frk-00026-00026 2024-08-31 14:11:10.384303 +0200 [ coolforkit-caps ] ERR  Capability cap_sys_chroot is not set for the coolforkit program.| kit/ForKit.cpp:230
frk-00026-00026 2024-08-31 14:11:10.384316 +0200 [ coolforkit-caps ] ERR  Capability cap_fowner is not set for the coolforkit program.| kit/ForKit.cpp:230
frk-00026-00026 2024-08-31 14:11:10.384327 +0200 [ coolforkit-caps ] ERR  Capability cap_chown is not set for the coolforkit program.| kit/ForKit.cpp:230
Same Problem here,
rolled back my docker image to 24.04.6.2.1 and now it’s working again.
As @MarslMarcello and @foer said, rolling back to 24.04.6.2.1 brings it back online.
Either a bug or some hoop we need to jump through to get the latest version working.
It is most likely a bug…see:
https://github.com/CollaboraOnline/online/issues/9948
