Unsymetric WebDav problem with files >1GB
example
longer
example
here
Some useful links to gather information about your Nextcloud Talk installation:
Information about Signaling server: /index.php/index.php/settings/admin/talk#signaling_server
Information about TURN server: /index.php/settings/admin/talk#turn_server
Information about STUN server: /index.php/settings/admin/talk#stun_server
Nextcloud version 32.0.0
Custom Signaling server configured: no
Custom TURN server configured: no
Custom STUN server configured: no
Operating system (eg, Windows/Ubuntu/…): WSL (Debian 13.1) on Windows Server 2022
Browser name and version (eg, Chrome v101): Edge on Windows 11
I want to transfer Date from Sharepoint server to Nextcloud server using WebDav.
This ist the summary of trys:
files >1G from Filesystem to Nextcloud via browser – ok.
files > 1G from Filesystem to Nextcloud via WebDav – fails.
files > 1G from Filesystem to Sharepoint via Webdav – ok.
files > 1G from Nextcloud to Sharepoint via WebDav – ok.
files > 1G from Sharepoint to Nextcloud via WebDav – fails.
It seems, there ist a problem with nextcloud receiving large files vi WebDav.
The registry entry
HKLM\SYSTEM\CurrentControlSet\Services\WebClient\Parameter\FileSizeLimitInBytes
has the value „4294967295“.
The file
/var/www/Nexctloud/.user.ini
contains the values
php_value upload_max_filesize 16G
php_value post_max_size 16G
php_value max_input_time 3600
php_value max_execution_time 3600
The files
/etc/php/8.4/apache2/php.ini
/etc/php/8.4/cli/php.ini
/etc/php/8.4/fpm/php.ini
all contains the same values:
post_max_size = 16G
upload_max_filesize = 16G
max_execution_time = 3600
max_input_time = 3600
Has any one an idea to fix the problem?
sharepoint is a windows server? how do you use webdav, other webdav clients work?
Anything in the logs (Nextcloud/webserver)
Sharepoint 2016 runs on Wndows Server 2016.
As is said,
Files > 1GB can be copied from Filesystem to Sharepoint via Webdav.
Files > 1GB can be copied from Nextcloud to Sharepoint via WebDav.
Files > 1GB can not be copied from Filesystem to Nextcloud via WebDav.
Files > 1GB can not be copied from Sharepoint to Nextcloud via WebDav.
Files > 1GB can be uploaded to Nextcloud from Filesystem.
net use https://nextcloud_url
net use https://sharepoint_url
Kopieren mit robocopy.
The Web UI (and all official Nextcloud clients) use chunking. Your other scenarios are likely not using chunking. And, given the 1GiB ceiling my wild guess is Apache’s (default but adjustable) request body limit. See the Admin Manual section covering big file uploads.
Beyond that… well, we need the details from the standard support template to help you out. I’m not sure why you filled out the Talk template.
And if you use a different webdav software, e.g. winscp, this would work?
if it is not via webdav, do you mean it is the web-interface, the NC client?
If you write it like this with files smaller than 1 GB it works?
And have you any server logs? In case of a timeout, it would be important to know what times out (php, webserver, proxy, database, …) or runs into a limit.
Hallo tflidd,
“Files > 1GB can not be copied from Filesystem to Nextcloud via WebDav.”
In Detail:
lsb is a non real user to hold and share all Sharepoint-Data.
C:\Temp\BigFile has File_1-0.GB, File_1-2.GB, File_1-4.GB
net use n: https://sbn-03026-01/remote.php/dav/files/lsb
robocopy /s /e /r:1 /w:1 /tee /np /log:rc-bigfile-n.log c:\temp\Bigfile n:BigFile
this did not work.
Logfile:
Fehler
no app in context
BadRequest
Expected filesize of 1459375159 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 0 bytes.
Could either be a network problem on the sending side or a problem writing to the storage on the server side.
18.11.2025, 11:29:53
Fehler
no app in context
BadRequest
Expected filesize of 1292938359 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 0 bytes.
18.11.2025, 11:29:29
But
net use s: https:///websites/Test
robocopy /s /e /r:1 /w:1 /tee /np /log:rc-bigfile-s.log c:\temp\Bigfile s:BigFile
works fine.
“Files > 1GB can be uploaded to Nextcloud from Filesystem.”
->Dateien->Neu->Dateien hochladen
Works fine.
For the expected size, did you check all the settings in the documentation for large file uploads?
https://docs.nextcloud.com/server/stable/admin_manual/configuration_files/big_file_upload_configuration.html
Some of these parameters can lead to similar errors:
