Uable to connect suite crm 7 in nextcloud 25
uable to connect suite crm 7 in nextcloud 25: getting error invalid username/password.
In logs: UnexpectedValueException: The Nextcloud configuration (config/config.php) does not contain the key user_backend_sql_raw which should contain the configuration for the app user_backend_sql_raw.
<<closure>>
OCA\UserBackendSqlRaw\Config->__construct()
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 108:
ReflectionClass->newInstanceArgs()
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 116:
OC\AppFramework\Utility\SimpleContainer->buildClass()
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 134:
OC\AppFramework\Utility\SimpleContainer->resolve()
/var/www/html/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 466:
OC\AppFramework\Utility\SimpleContainer->query()
/var/www/html/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php - line 438:
OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback()
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 89:
OC\AppFramework\DependencyInjection\DIContainer->query()
<<closure>>
OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}("*** sensiti ... *")
array_map()
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 57:
/var/www/html/nextcloud/apps/user_backend_sql_raw/lib/AppInfo/Application.php - line 61:
OC\AppFramework\Utility\SimpleContainer->get()
/var/www/html/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php - line 190:
OCA\UserBackendSqlRaw\AppInfo\Application->boot()
/var/www/html/nextcloud/lib/private/legacy/OC_App.php - line 208:
OC\AppFramework\Bootstrap\Coordinator->bootApp()
/var/www/html/nextcloud/lib/private/legacy/OC_App.php - line 141:
OC_App::loadApp()
/var/www/html/nextcloud/lib/private/legacy/OC_User.php - line 128:
OC_App::loadApps()
/var/www/html/nextcloud/lib/base.php - line 746:
OC_User::setupBackends()
/var/www/html/nextcloud/lib/base.php - line 1150:
OC::init()
/var/www/html/nextcloud/index.php - line 34:
require_once("/var/www/ht ... p")
I’m afraid we would need ways more informations about your server.
take this template as an orientation Support template. Please use this when you request support
plus: NC25 is EOL since 1 year now. pls update to a supported version, first
You appear to be trying to use an app called user_backend_sql_raw, but don’t have it configured:
I hve istalled raw sql from nextcloud store but issue still persists.
Yes, because as the error states… You need to configure it:
Could you guide me with any source link or by what to write in config file. Appreciate your help.
The second link above is the documentation.
