Trusted proxy setting not seeming to apply in docker
On my administration overview page it says “You are accessing your instance over a secure connection, however your instance is generating insecure URLs. This most likely means that you are behind a reverse proxy and the overwrite config variables are not set correctly. Please read the documentation page about this”
That is correct. I am using a docker nextcloud container and a nginx container as a proxy. If I go to the page it links to it basically says to set up a trusted_proxies. I have done that all ready. If I check trusted proxies I see it listed.
$ docker exec --user www-data nextcloud-app-1 php occ config:system:get trusted_proxies
nextcloud-proxy-1
I double checked and that the name of my proxy container.
Thank you.
config.php encase that is helpful.
 'apps_paths' =>
   0 =>
     'url' => '/apps',
     'writable' => false,
   1 =>
     'url' => '/custom_apps',
     'writable' => true,
 'redis' =>
   'host' => 'redis',
   'password' => '',
   'port' => 6379,
 'trusted_proxies' =>
   0 => 'nextcloud-proxy-1',
 'instanceid' => '[some random letters]',
 'passwordsalt' => '[some more random letters]',
 'secret' => '[lots of random letters]',
   0 => '[my domain name in the format aaaa.bbbbbb.com]',
 'datadirectory' => '/srv/nextcloud/data',
 'version' => '26.0.0.11',
 'overwrite.cli.url' => 'http://[my domain name in the format aaaa.bbbbbb.com]',
 'dbname' => 'nextcloud',
 'dbhost' => 'db',
 'dbuser' => 'nextcloud',
 'dbpassword' => '[some random letters]',
 'loglevel' => 2,
 'mail_smtpmode' => 'smtp',
 'mail_smtpauth' => 1,
 'mail_from_address' => '[some not so random letters]',
 'mail_domain' => '[some popular mail domain].com',
 'mail_smtphost' => 'smtp.[some popular mail domain].com',
 'mail_smtpport' => '587',
 'mail_smtpname' => '[my email]',
 'mail_smtppassword' => '[some random letters]',
Hrm… That seems like it should work. I don’t have a good reference because I don’t run a dockerized proxy.
Could you get the docker network IP of the proxy container and add it as a trusted proxy just to see if that does it?
Actually I just checked the docs and it says this is supposed to be IPs. It may not work with hostnames.
I think you can set a static docker network address for the reverse proxy so it won’t move on you.
I used occ to add the ip address as a proxy and it shows up in the config file but not when I use “occ config:system:get trusted_proxies”. Is there something I need to do to apply changes?
Config now has:
    1 => '172.28.0.4',
This does not seem to have helped.
I would recommend you you to add overwriteprotocoland overwritehost parameters as well - only overwrite.cli.url is not sufficient…
You might find this guide useful: Apache Docker behind reverse proxy
Thanks @wwe, I used occ to add overwriteprotocol, overwritehost, and overwritecondaddr. Like so:
  'overwritehost' => 'my.domain.com',
  'overwritecondaddr' => '^172\.28\.0\.4$',
That fixed the error on the administration overview page. I was also looking at anther issue where the NextCloud log is showing the proxy address. It did not fix that. I then went and changed overwritecondaddr to my host name ( nextcloud-proxy-1). Still worked. I deleted it and it still worked. overwritecondaddr was not needed for my set up! So now my config looks something like this:
I also updated my docker-compose.yml with:
      - OVERWRITEPROTOCOL=https
      - OVERWRITEHOST=my.domain.com
Hopefully that will make it work next time I have to restart it.
Thanks for your help.
P.S. I am also looking for ideas on how to fix the ip address in the log file.
