The third beta of Nextcloud 30 is now available on our download server! ![]()
If you notice anything out of order, please report back on the appropriate github repository! ![]()
We will follow up with frequent betas over the next weeks.
Downloads
Previous announcements
Changelog
- Audit the tag creator (server#40163)
- Update IRC URL (server#42746)
- Perf(systemtags): Add index for systemtags_object_mappings.objectid (server#45306)
- Chore: Remove deprecated legacy search backend (server#45950)
- Refactor(files): Migrate logger to Typescript (server#46083)
- Fix: Add
acceptShareas an interface (server#46099) - Fix(userstatus): add missing parenthesis (server#46287)
- Fix(setupchecks): Skip checking for OPcache settings if running checks from CLI (server#46353)
- Feat(editLocallyAction): Handle possible no local client scenario (server#46452)
- Fix(dav): drop unwanted RemoteException class (server#46550)
- Feat: Navigate via folder tree (server#46596)
- Refactor(cloud_federation_api): Replace security annotations with respective attributes (server#46744)
- Refactor(dav): Replace security annotations with respective attributes (server#46747)
- Fix(files): Provide default file action for file entry name (on click action) (server#46768)
- Refactor(encryption): Replace security annotations with respective attributes (server#46804)
- Refactor(files): Replace security annotations with respective attributes (server#46807)
- Refactor(files_sharing): Replace security annotations with respective attributes (server#46810)
- Refactor(user_ldap): Replace security annotations with respective attributes (server#46822)
- Refactor(weather_status): Replace security annotations with respective attributes (server#46824)
- Chore(ShareSettings): Proper wording for share autocompletion settings (server#46830)
- Fix: don’t persist previews used during blurhash generation - take 2 (server#46864)
- Fix(TaskProcessing): Don’t break if provider methods throw (server#46872)
- Chore(core): wrap initial state into hidden container (server#46873)
- Update line height (server#46876)
- Fix: try to find non-recursive share source (server#46881)
- Fix(files_sharing): Add missing “note to recipient” (server#46892)
- Chore: Fix cypress docker integration when testing locally (server#46893)
- Fix(trashbin): Improve documentation of since/until timestamps of res… (server#46894)
- Resolve template filler bugs (server#46895)
- Fix(files): Set container for file list actions (server#46896)
- Revert: chore(files): cleanup old templates (server#46897)
- [master] Update psalm-baseline.xml (server#46901)
- Fix(build): do not run SPDX Plugin in dev mode (server#46903)
- More fixes for task processing (server#46912)
- Fix: template folder and file request menu order (server#46913)
- Fix: don’t break doc builds / fix imaginary config sample formatting (server#46915)
- Fix(core): app menu label position and animation (server#46916)
- Fix(files): Add missing
emptyViewhandling (server#46917) - Fix(files): Correctly create Nodes from WebDAV result in “recent”-view (server#46918)
- Fix(systemtags): Correctly set the display name for the Nextcloud node (server#46921)
- Add small font size variable (server#46925)
- Fix(files): do not show legacy
edit locallyaction on public pages (server#46927) - Fix(files): empty folder pending size (server#46928)
- Fix(core): app menu notification should be in the top right (server#46930)
- Build(deps): bump the github-actions group with 6 updates (server#46936)
- Fix(activity): regroup Files and split sharing activity (server#46942)
- Fix(AdminSettings/AI): show pref list of only the enabled translation providers (server#46943)
- [master] Fix npm audit (activity#1709)
- Fix(stream): Don’t render avatar for federated users (activity#1744)
- Add npm audit action (bruteforcesettings#624)
- Chore(deps): Bump @nextcloud/vue from 8.14.0 to 8.15.1 (bruteforcesettings#628)
- Chore: update workflows from templates (circles#1469)
- Chore(deps-dev): Bump phpunit/phpunit from 10.5.24 to 10.5.25 (circles#1626)
- Fix(notifications): Don’t trigger invite notifications for system groups (circles#1650)
- Migrate reuse to toml format (circles#1657)
- Chore(deps): bump @nextcloud/logger from 2.7.0 to 3.0.2 (logreader#1255)
- [master] Update nextcloud/ocp dependency (logreader#1320)
- Migrate REUSE to TOML format (recommendations#769)
- Add SPDX header (related_resources#448)
- Chore: update workflows from templates (related_resources#452)
- Fix(css): spacing issue in table (text#6150)
- Chore(deps): bump fast-xml-parser from 4.3.6 to 4.4.1 (text#6151)
