I got the same error as dom134 about /assets. That folder was created a while ago when I enabled the assets pipeline, so should be handled by the updater I think?
After deleting /assets the updater worked fine, reloading Nextcloud and starting the update through the webinterface still disabled 3rd party apps though, was that supposed to happen?
It seems like I need to do this again for .52 ? As Iām getting the same message again
Now Iām getting the following:
Fatal error: Uncaught Symfony\Component\Process\Exception\RuntimeException: The Process class relies on proc_open, which is not available on your PHP installation. in /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/vendor/symfony/process/Process.php:144 Stack trace: #0 /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/src/Utils/OccRunner.php(45): Symfony\Component\Process\Process->__construct(āphp /www/htdocsā¦ā) #1 /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/src/Utils/OccRunner.php(56): Owncloud\Updater\Utils\OccRunner->run(āconfig:list --pā¦ā) #2 /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/src/Utils/ConfigReader.php(106): Owncloud\Updater\Utils\OccRunner->runJson(āconfig:list --pā¦ā) #3 /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/src/Utils/ConfigReader.php(50): Owncloud\Updater\Utils\ConfigReader->load() #4 /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/src/Control in /www/htdocs/xxxxxxx/domain/next.domain.net/cloud/updater/vendor/symfony/process/Process.php on line 144
On the roadmap.
Anything in your browser console?
Good catch. I filed a bug at Ignore asset folder Ā· Issue #23 Ā· nextcloud/updater Ā· GitHub and we will fix this
Unfortunately, at the moment this is still the case. But a newer version will do that.
Unfortunately yes, the 9.x releases still ship the old ownCloud updater. And as you can see that one is super prone to break randomly. In your case some required PHP extensions are not installed.
At the moment one has to manually upload the new updater every time. Iāll look with @MorrisJobke for when we will ship the new updater. Hopefully soon. Sorry for the hassles! ā We just wanted to really make sure to not ship something that does more harm than good.
@LukasReschke yet again nothing just as before. The only difference I notice is that the permissions are still in place (with the first update these got screwed up as you may remember)
Shall I create an account for you so you can check yourself? (it is a test installation anyway)
John
No worries, just let me know when I should run an update
That would be awesome
Could you please also check the .step file in data/updater-INSTANCEID/ ? There should be a number. This is the number at which the updater continues And that is why there is a continue button skips the already executed steps.
Thanks for your help.
the content of the file reads:
(āstateā:āendā,āstepā:11)
I know this doesnāt add anything much, but this worked a dream for me. I had a permissions problem because I had made a backup to updater/index.php.bak and this wasnāt owned by www-data, but otherwise it was all fine. It did disable 4 of my plugins, but I simply re-enabled them after the upgrade.
I guess the updater wonāt work if my nextcloud instance is not located in the nextcloud folder (I renamed the folder)?
Is it enough to rename the folder back to Nextcloud and after the update rename it agian?
Iām already on .52 so i canāt test it.
It should work no matter how the parent folder is named.
This is most likely why the updater would not show up
Oh great, Iāll try it as soon as there is a new version to test.
Yeah, I know. I just wait till the next version gets released.
I am on owncloud 9.0.2 and want to test the new script. but sadly it does nothing.
I have yesterday uploaded the index to the updater folder and add the line in the config.
change the update channel and nothing happends. can i check somewhere why nothing happends?
Starting from NextCloud 9.051 it worked flawless and as expected!
regards, hitam4450
Just upgraded from owncloud to 9.50 manually an then used the updater to go to 9.51. Worked very well, just - naturally! - doesnāt work with Strong Permissions
I got stuck on this error message:
Check for write permissions
The following places can not be written to:/var/www/html/nextcloud/updater/ā¦/apps/notes/.git/objects/pack/pack-17eddcbf421e526c08aa2359c72d3cf848f58435.pack/var/www/html/nextcloud/updater/ā¦/apps/notes/.git/objects/pack/pack-17eddcbf421e526c08aa2359c72d3cf848f58435.idxThe following places can not be written to:/var/www/html/nextcloud/updater/ā¦/apps/notes/.git/objects/pack/pack-17eddcbf421e526c08aa2359c72d3cf848f58435.pack/var/www/html/nextcloud/updater/ā¦/apps/notes/.git/objects/pack/pack-17eddcbf421e526c08aa2359c72d3cf848f58435.idx
Itās strange because everything in /nextcloud should have apache:apache owner.
No, but if someone has run the strong permissions script, then hopefully they read the part that warns that theyāll need to temporarily change the permissions back before upgradingā¦
I did run the script that changes owner of all files in /var/www/html/nextcloud to apache:apache. And all files there seem to have apache:apache as their owner. Yet Iām told during the upgrade that some files canāt be written to.
Like me? Yeah, missed that.
