Talk HPB error: Error: Websocket connection failed on Nextcloud AIO
    • 32.0.1
    • Debian 12
    • Apache 2.4.65
    • NGINX Proxy Manager
    • PHP 8.4.13
    • Yes
    • When I wanted to start a Talk meeting, it told me it couldnt reach the HPB.
    • AIO
I want to turn on HPB for Talk but i get the following error:
The wierd thing is that i have turned on Websocket support in NGINX Proxy Manager:
I use Selfsigned SSL certs and my nextcloud-aio-nextcloud container has the root cert installed and trusted so this isnt a problem.
  1. Use Nginx Proxy Manager with self signed certs
  2. Install Nextcloud AIO with Talk
  3. Try to connect with the HPB
https://pastebin.com/5AGt6kAY
  'one-click-instance' => true,
  'one-click-instance.user-limit' => 100,
  'apps_paths' =>
    0 =>
      'url' => '/apps',
      'writable' => false,
    1 =>
      'url' => '/custom_apps',
      'writable' => true,
  'check_data_directory_permissions' => false,
  'redis' =>
    'host' => 'nextcloud-aio-redis',
    'password' => 'passwd',
    'port' => 6379,
  'overwritehost' => 'next.mydomain.com',
  'passwordsalt' => 'passwdsalt',
  'secret' => 'secret',
    0 => 'localhost',
    1 => 'next.mydomain.com',
  'datadirectory' => '/mnt/ncdata',
  'dbtype' => 'pgsql',
  'version' => '32.0.1.2',
  'overwrite.cli.url' => 'https://next.mydomain.com/',
  'dbname' => 'nextcloud_database',
  'dbhost' => 'nextcloud-aio-database:5432',
  'dbuser' => 'oc_nextcloud',
  'dbpassword' => 'dbpasswd',
  'instanceid' => 'instance',
  'updatechecker' => true,
  'updatedirectory' => '/nc-updater',
  'loglevel' => 2,
  'app_install_overwrite' =>
    0 => 'nextcloud-aio',
    1 => 'externalportal',
  'log_type' => 'file',
  'logfile' => '/var/www/html/data/nextcloud.log',
  'log_rotate_size' => 10485760,
  'log.condition' =>
    'apps' =>
      0 => 'admin_audit',
  'preview_max_x' => 2048,
  'preview_max_y' => 2048,
  'jpeg_quality' => 60,
  'enabledPreviewProviders' =>
    1 => 'OC\\Preview\\Image',
    2 => 'OC\\Preview\\MarkDown',
    3 => 'OC\\Preview\\MP3',
    4 => 'OC\\Preview\\TXT',
    5 => 'OC\\Preview\\OpenDocument',
    6 => 'OC\\Preview\\Movie',
    7 => 'OC\\Preview\\Krita',
    0 => 'OC\\Preview\\Imaginary',
    23 => 'OC\\Preview\\ImaginaryPDF',
  'enable_previews' => true,
  'mail_smtpmode' => 'smtp',
  'versions_retention_obligation' => 'auto, 30',
  'activity_expire_days' => 30,
  'share_folder' => '/Shared',
  'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
  'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
  'maintenance_window_start' => 100,
  'allow_local_remote_servers' => true,
  'davstorage.request_timeout' => 3600,
  'documentation_url.server_logs' => 'https://github.com/nextcloud/all-in-one/discussions/5425',
  'dbpersistent' => false,
  'auth.bruteforce.protection.enabled' => true,
  'ratelimit.protection.enabled' => true,
  'files_external_allow_create_new_local' => false,
  'trusted_proxies' =>
    0 => '127.0.0.1',
    1 => '::1',
    10 => '172.18.0.0/16',
  'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
  'preview_imaginary_key' => 'key',
I’ve reviewed your issue with the WebSocket and SSL certificate while using Nextcloud AIO and Nextcloud Talk. Based on your logs, it seems like the main issue is related to the SSL certificate. The log indicates a failure due to a self-signed certificate in the certificate chain, which causes the connection to the signaling server to fail. This is likely affecting the WebSocket connection as well.
I think the problem might be related to various settings, such as certificates and reverse proxy.
I’d suggest comparing your installation process with my guide for Proxmox + NGINX + Nextcloud AIO + Watchtower. This guide covers all the steps for installation, including the proper port settings, reverse proxy, and WebSocket support.
Here’s the link to my guide and URL for video (processing): Proxmox + NGINX + Nextcloud AIO + Watchtower Deployment Guide
In particular, you might want to focus on ensuring that Let’s Encrypt certificates are correctly issued (rather than using self-signed certificates), and that the reverse proxy is properly handling WebSocket connections.
I believe this could help resolve your issue, and I’m looking forward to hearing your thoughts on it.
Hey, Thanks for your reply.
I have followed your guide but I cannot use a lets encrypt certificate as I need to set up Nextcloud totally internal for a school project. I need to set it up so that you can only access it using a vpn. meaning i can only use self signed certs, i have trusted the certificate in nextcloud-aio-apache, nextcloud-aio-nextcloud and in the VM itself. so this shouldnt be an Issue. Is it possible to enable the HPB using only self signed SSL certs without any open ports to the outside (except one for the vpn).
Thanks!
I don’t really have experience running HPB fully internal with self-signed certificates, but based on what your logs show, the issue is that the certificate must be trusted inside each AIO container, not just on the VM.
If I understand it correctly, you would need to add your self-signed root certificate to every relevant AIO container (Nextcloud, Apache, HPB/Signaling, etc.), because each container has its own CA store. Otherwise the signaling request fails with the “self-signed certificate in chain” error.
Maybe someone with a similar internal-only setup can confirm the exact steps, but this seems to be the core issue.
The Talk container is read only filesystem, do you perhaps know how to change this temporarily or something?
Thanks!
I’m not sure, but it’s perfectly possible to obtain Let’s Encrypt certificates without port forwarding. Simply use the DNS Challenge in Nginx Proxy Manager to obtain them. No port forwarding is needed for that to work.
