- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
I hope this is the right place for this question.
After using the docker version in the TrueNAS catalogue I discovered the AIO has the high performance backend built in, why is it not built into the regular docker? The TrueNAS version deploys this version: GitHub - nextcloud/docker: ⛴ Docker image of Nextcloud I really do not know why they don’t just use GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance. via… nextcloud/all-in-one - Docker Image
So my main question is, I have a lot already loaded on my existing install and want to get the highspeed backend working and switching to the AIO seems like the easiest way to do that. BUT I am very concerned about just switching, how to map new volumes via docker YAML etc without breaking anything existing.
I assume there is likely a way to just switch it over with the right volume maps? Since all of the passwords should also be in nextcloud config files like config.php?
services:
restart: always
ports:
- "9991:9991" # Use your custom port if needed
- "8080:8080"
- "8443:8443"
volumes:
- nextcloud_aio_mastercontainer:/mnt/docker-aio-config #some kind of different mapping here for the user, app and db files?
environment:
- TZ=America/Vancouver
resources:
limits:
cpus: 4
memory: 8192
I really don’t see why there are 2 versions that on a surface level look like they should be equivalent but one is lacking something like this highspeed backend.
32.0.0
TrueNAS 25.04.2.1: Linux 6.12.15-production+truenas x86_64
Not sure where to find this, unmodified from the stock docker
NGINX v2.12.6as another TrueNAS app
- PHP version (e.g, 8.3):
8.3.26
- GitHub - nextcloud/docker: ⛴ Docker image of Nextcloud via TrueNAS catalogue
no
# occ config:list system
"upgrade.disable-web": true,
"htaccess.RewriteBase": "\/",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"redis": {
"port": 6379
"overwrite.cli.url": "https:\/\/localhost",
"dbtype": "pgsql",
"version": "32.0.0.13",
"dbport": "",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "ssl",
"mail_sendmailmode": "smtp",
"mail_smtpport": "465",
"mail_smtpauth": 1,
"twofactor_enforced": "true",
"twofactor_enforced_groups": [],
"twofactor_enforced_excluded_groups": [
"admin",
"no2fa"
"logtimezone": "America\/Vancouver",
"default_phone_region": "CA",
"loglevel": 2,
"overwriteprotocol": "https",
"bulkupload.enabled": true,
"chunkSize": "5120MB",
"forbidden_filename_basenames": [
"con",
"prn",
"aux",
"nul",
"com0",
"com1",
"com2",
"com3",
"com4",
"com5",
"com6",
"com7",
"com8",
"com9",
"com\u00b9",
"com\u00b2",
"com\u00b3",
"lpt0",
"lpt1",
"lpt2",
"lpt3",
"lpt4",
"lpt5",
"lpt6",
"lpt7",
"lpt8",
"lpt9",
"lpt\u00b9",
"lpt\u00b2",
"lpt\u00b3"
"forbidden_filename_characters": [
"forbidden_filename_extensions": [
".filepart",
".part"
"app_install_overwrite": [],
"defaultapp": "files",
"overwritehost": "***REMOVED SENSITIVE VALUE***",
"127.0.0.1",
"192.168.0.51",
"localhost",
"nc.home.mrnewlove.ca",
"nc.home.mrnewlove.ca\/",
"nextcloud",
"nextcloud-init-sync.lock",
"truenas-newlove.local"
# occ app:list
- activity: 5.0.0-dev.0
- circles: 32.0.0
- comments: 1.22.0
- contactsinteraction: 1.13.1
- dashboard: 7.12.0
- dav: 1.34.2
- federation: 1.22.0
- files: 2.4.0
- files_reminders: 1.5.0
- files_sharing: 1.24.0
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0-dev.0
- forms: 5.2.1
- logreader: 5.0.0-dev.0
- notifications: 5.0.0-dev.0
- notify_push: 1.2.0
- oauth2: 1.20.0
- photos: 5.0.0-dev.1
- privacy: 4.0.0-dev.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- richdocuments: 9.0.0
- richdocumentscode: 25.4.504
- serverinfo: 4.0.0-dev.0
- settings: 1.15.1
- sharebymail: 1.22.0
- spreed: 22.0.0
- support: 4.0.0-dev.0
- survey_client: 4.0.0-dev.0
- systemtags: 1.22.0
- text: 6.0.0-dev.0
- theming: 2.7.0
- twofactor_totp: 14.0.0
- updatenotification: 1.22.0
- user_status: 1.12.0
- viewer: 5.0.0-dev.0
- weather_status: 1.12.0
- webhook_listeners: 1.3.0
- workflowengine: 2.14.0
- admin_audit: 1.22.0
- app_api: 32.0.0 (installed 32.0.0)
- encryption: 2.20.0
- files_external: 1.24.0
- user_ldap: 1.23.0
TrueNAS YAML Config:
nextcloud:
ix_certificate_authorities: {}
ix_certificates: {}
ix_context:
app_metadata:
annotations:
min_scale_version: 24.10.2.2
app_version: 32.0.0
capabilities:
- description: Cron, Nextcloud, Nginx are able to change file ownership arbitrarily
- description: Cron, Nextcloud, Nginx are able to bypass file permission checks
- description: Cron, Nextcloud, Nginx are able to bypass permission checks for
file operations
- description: Cron, Nextcloud, Nginx are able to bind to privileged ports (<
1024)
- description: Cron, Nextcloud, Nginx are able to use raw and packet sockets
- description: Cron, Nextcloud, Nginx are able to change group ID of processes
- description: Cron, Nextcloud, Nginx are able to change user ID of processes
- description: Imaginary is able to modify process scheduling priority
categories:
- productivity
changelog_url: https://nextcloud.com/changelog/
date_added: '2024-08-07'
description: A file sharing server that puts the control and security of your
own data back into your hands.
home: https://nextcloud.com/
host_mounts: []
icon: https://media.sys.truenas.net/apps/nextcloud/icons/icon.svg
keywords:
- nextcloud
- storage
- sync
- http
- web
- php
lib_version: 2.1.53
lib_version_hash: 87d1db998a9aab3355a78a686d640251822e640125e65ad1237c9902a59e32f1
maintainers:
- email: dev@truenas.com
url: https://www.truenas.com/
run_as_context:
- description: Nextcloud runs as root user.
gid: 0
group_name: root
uid: 0
user_name: root
- description: Postgres runs as non-root user.
gid: 999
group_name: postgres
uid: 999
user_name: postgres
- description: Redis runs as any non-root user.
gid: 568
group_name: redis
uid: 568
user_name: redis
- description: Nginx runs as root user.
gid: 0
group_name: root
uid: 0
user_name: root
- description: Imaginary runs as non-root user.
gid: 568
group_name: imaginary
uid: 568
user_name: imaginary
screenshots:
- https://media.sys.truenas.net/apps/nextcloud/screenshots/screenshot1.png
- https://media.sys.truenas.net/apps/nextcloud/screenshots/screenshot2.png
- https://media.sys.truenas.net/apps/nextcloud/screenshots/screenshot3.png
sources:
- https://github.com/nextcloud/docker
title: Nextcloud
train: stable
version: 2.0.34
app_name: nextcloud
is_install: false
is_rollback: false
is_update: true
is_upgrade: false
operation: UPDATE
scale_version: TrueNAS-25.04.2.1
upgrade_metadata: {}
ix_volumes: {}
labels: []
network:
certificate_id: null
dns_opts: []
web_port:
bind_mode: published
host_ips: []
port_number: 9991
nextcloud:
additional_envs:
- name: OVERWRITEHOST
value: ***REMOVED SENSITIVE VALUE***
admin_password: ***REMOVED SENSITIVE VALUE***
admin_user: nextcloud_admin
apt_packages:
- ffmpeg
cron:
enabled: true
schedule: '* * * * *'
data_dir_path: /var/www/html/data
db_password: ***REMOVED SENSITIVE VALUE***
db_user: nextcloud
host: 192.168.0.51
imaginary:
enabled: true
max_execution_time: 120
op_cache_interned_strings_buffer: 64
op_cache_memory_consumption: 1024
php_memory_limit: 4096
php_upload_limit: 200
postgres_image_selector: postgres_13_image
redis_password: ***REMOVED SENSITIVE VALUE***
tesseract_languages: []
resources:
gpus:
kfd_device_exists: false
nvidia_gpu_selection:
'0000:37:00.0':
use_gpu: false
uuid: GPU-908f149d-1bdb-45d5-433a-fadea7b03575
use_all_gpus: false
limits:
cpus: 8
memory: 16384
storage:
additional_storage: []
data:
host_path_config:
acl_enable: false
path: /mnt/main-lts/truenas-apps/NextCloud/user_data
type: host_path
html:
host_path_config:
acl_enable: false
path: /mnt/main-lts/truenas-apps/NextCloud/AppData
type: host_path
postgres_data:
host_path_config:
acl_enable: false
auto_permissions: false
path: /mnt/main-lts/truenas-apps/NextCloud/Postgres
type: host_path
